Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 09-13-2006, 02:59 AM   #1
runder
Bronco Info: 1990, 5.8l, ZF-5
E4OD to ZF-5 Swap
I have a 90 Bronco with a 351 and an E4OD in it and I'm swapping in a ZF-5. So, I have a couple of questions:
1. Will the transfer case from the E4OD bolt up to the ZF5?
2. I have an F-150 with an inline six and a MDO5 in it to use for parts, will the dust cover from between the engine and flywheel fit the ZF5?
3. Will the transmission cross member from the MDO5 work for the ZF5?
Thanks, Robert.
runder is offline   Reply With Quote
Old 09-13-2006, 03:03 AM   #2
ToddACimer
1-tons aren't
ToddACimer's Avatar
Bronco Info: 93 F250... TTB and shit
Thanks, Robert.
1. Yes
2. Yes
3. Yes, the holes should already be in the frame also.
Recipient of multiple driving awards from State and Local officials.
ToddACimer is offline   Reply With Quote
Old 09-13-2006, 03:05 AM   #3
runder
Cool, thanks for the reply.
Old 09-13-2006, 03:07 AM   #4
ToddACimer
1-tons aren't
ToddACimer's Avatar
I just ZFed my 94, hopefully your parts truck is of the same generation 87-91 or 92-96 as your Bronco then all the parts will swap over
Old 09-13-2006, 03:27 AM   #5
runder
Thankfully it is.
Old 03-01-2007, 03:59 PM   #6
goof008
goof008's Avatar
Bronco Info: 1992 Bronco XLT 351/auto
does switching to a ZF do anything to the computer? Does it need to be reprogrammed...also, are there vacuum lines that need to be plugged?
goof008 is offline   Reply With Quote
Old 03-01-2007, 04:40 PM   #7
Hopper
Hopper's Avatar
Bronco Info: Stockish 93 5.8L, E4OD, BW1356; 79, 400/T-18/NP205, D44/9"
The computer just thinks you are sitting still all the time after you swap for the ZF... If it bothers you that the computer is wrong, swap for an F250 351 computer.
Hopper is offline   Reply With Quote
Old 03-01-2007, 04:58 PM   #8
Bronco4Life
Bronco4Life's Avatar
Bronco Info: smells like gear oil
Well, you can't reprogram our computers, but for the most part it shouldn't have any ill-effects on it. Maybe you'll get a higher idle because it will be expecting TC load, but from what I understand, it should drop it back down a bit. If not, there's some tweaking you can do with your TPS/TB.
92 EB - 302/E4OD (205,000mi) - Eric
+ lots of cool crap.
Originally Posted by dgmid61
I am sorry to have bothered you on your forum, you should post on the home page though, dont ask any questions cause if you dont know you are stupid...
Bronco4Life is offline   Reply With Quote
Old 03-01-2007, 06:59 PM   #9
ToddACimer
1-tons aren't
ToddACimer's Avatar
I've never had any problems but I havent driven mine a whole lot
Old 03-01-2007, 09:00 PM   #10
runder
Smile
I got the swap done last week, wow what a difference . I did swapped out the computer as well as the E4OD wiring harness for one from the donor truck’s M5OD.
Old 03-01-2007, 09:08 PM   #11
ToddACimer
1-tons aren't
ToddACimer's Avatar
I got the swap done last week, wow what a difference . I did swapped out the computer as well as the E4OD wiring harness for one from the donor truck’s MDO5.
Did you swap in a ZF or a M5OD
Old 03-01-2007, 09:14 PM   #12
runder
A ZF-5, the wiring harness is has the correct plug for the back up lights on it.
Old 03-01-2007, 09:19 PM   #13
ToddACimer
1-tons aren't
ToddACimer's Avatar
Well then whats a MD05 wiring harness
Old 03-01-2007, 09:33 PM   #14
runder
The wiring harness that goes between the green connector on the left inter fender to the back-up light plug on the transmission and the plugs on the transfer case.
Old 03-01-2007, 09:53 PM   #15
Hopper
Hopper's Avatar
What kind of difference is there in felt power? Is it pretty drastic from the E4OD? More power is always good, but I really like the auto for crawling with the Bronco's relatively high gears (makes things much more smooth).
How does the typical ZF-5 shift? The last one I had I remember it being really notchy; however, it was in a diesel, and it had been through hell and back numerous times...
Old 03-01-2007, 10:00 PM   #16
ToddACimer
1-tons aren't
ToddACimer's Avatar
Power is awesome. It's easy to lite up my 35's through first and into second with 3.55 gears. Wheelin is great too. I can start in any gear in low range and just crawl along in first or second. I really like it
Old 03-01-2007, 10:02 PM   #17
runder
It is pretty drastic change. It fells like the engine has a lot more power than it did, bear in mind the old E4OD was petty much shot, the clutches where gone and the T/C was shot. The ZF-5 shifts great, wish I had done 6 mouths ago were I bought the ZF.
Old 03-01-2007, 10:09 PM   #18
Hopper
Hopper's Avatar
Well damn...the Bronco just got a new E4OD not long ago...maybe a shift kit will keep me happy
Old 03-02-2007, 03:17 PM   #19
s1120
s1120's Avatar
Bronco Info: 95 Bronco 5.0HO shortblock, Crane 2030 roller cam,powerheads early 351w heads, shorties w/Ypipe
So runing the E4oD computer with the manual trans works? I would thinking it would kick a light on.
Paul B
'95 Bronco XLT 5.0L/e40d working on 5.0HO Crane 2030 cam,early 351W heads ported w/194 valves,shorties,Homemade Ypipe,K&N CAI,Flowmaster cat back,procomp 3000 shocks,MM manual hubs
s1120 is offline   Reply With Quote
Old 03-02-2007, 04:04 PM   #20
ToddACimer
1-tons aren't
ToddACimer's Avatar
No lights on, no rough idle
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
