Go Back   FSB Forums > Bronco Discussions > Technical Write Ups
Thread Tools Display Modes
Old 04-27-2006, 11:22 AM   #1
Ditch Baby
formerly Nascarfreak88
Ditch Baby's Avatar
Bronco Info: '89 SAS leaf D60 front, D70 rear, etc etc etc
100% bolt-up saginaw pump
my stock PS pump took a dump on me a few weeks ago, gave me an exucse to upgrade to MUCH better saginaw pump. Yeah most of you guys think sag pump=custom mods/brackets. well i was talkin to a fellow FTW member, told be about the sag pump that directly bolts up. Ordered the pump and installed it on Sunday. I didnt get pics of the "swap" becuse its the same steps that you have to do to replace the stock pump. Though i did steal a bunch of pics of 94bronco351's swap Get a Haynes/Chiltons book, helps a bunch.
autozone Part #206244 print this page out when you go to get the pump- makes what ur tryin to explain much easier
http://www.partsamerica.com/ProductD...tnumber=206244
the powersteering pump bracket out
remove pump pully, i got this pully remover from autozone loan-a-tool
after the pully is off remove the 3 bolts that holds the pump on then it comes right off. bolt the new pump up and use the included bolt, washer and nut to install the pully
installed back in the truck blead and ready to go
note- the pics are a collection from when we did the swap on a 351 (who is now runnin the Redneck ram steering with this) and my 300.
Ditch Baby is offline   Reply With Quote
Old 04-27-2006, 11:53 AM   #2
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
This is the same pump I plan on using.
http://www.rockauto.com/ref/Cardone/...pg&20-6244.gif
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 04-27-2006, 11:59 AM   #3
sewiv
i like monkeys
Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
What is it from originally?
I have access to a shelf full of Sags, mostly off chevy 350s. I'm just hoping that one of them is the right one.
Sandy
sewiv is offline   Reply With Quote
Old 04-27-2006, 12:10 PM   #4
Gacknar
The Anti Yam!
Gacknar's Avatar
It's not from anything originaly.
It's a special built Saginaw hybrid built by A-1 Cardone designed to replace factory ford pumps.
It's basicly a regular Ford van Sag with a big horseshoe shaped adapter bracket on the front and connections that should mach up to the regular truck hoses.
Old 04-27-2006, 12:14 PM   #5
sewiv
i like monkeys
gotcha.
What do they take for core, then? Any Sag?
Old 04-27-2006, 12:14 PM   #6
imlikeojnow
green ones make me horny
imlikeojnow's Avatar
Bronco Info: 1994 w/ built 302, E4OD, 33in tires, custom exhaust, upgraded ign. running like a raped ape
Will that work as a direct swap on a 94. i am about to have to get one so if it will im all over it.
Originally Posted by SigEpBlue View Post
No, I don't have this problem. Money grows on trees here in Michigan, and my Bronco gets 45 mpg. It emits sunshine and a light berry scent, and it never needs service or parts.
imlikeojnow is offline   Reply With Quote
Old 04-27-2006, 01:07 PM   #7
Gacknar
The Anti Yam!
Gacknar's Avatar
It will bolt up forsure. The most you would need is a diferant pressure hose.
Old 04-27-2006, 01:25 PM   #8
bearfoot_25
bearfoot_25's Avatar
Bronco Info: 2008 Traxxas T-MAXX 3.3 ,2002 Ford Expedition 4x4. Nitto Terra Graplers. Triton 5.4
Awesome, i know this regedy pump i have now wont hold up after my D-60 Swap!!!
My Bronco and other pics
Click here to see the Bronco in action!!
If I wanted a Hummer I'd ask your sister! Barbie called, she wants her Jeep back
bearfoot_25 is offline   Reply With Quote
Old 04-27-2006, 01:31 PM   #9
hmthesing
hmthesing's Avatar
Bronco Info: '89 EB 302 C6
Would that work for the 302 as well?
hmthesing is offline   Reply With Quote
Old 04-27-2006, 01:35 PM   #10
imlikeojnow
he just answered that.
where would one get a different pressure hose?
Old 04-27-2006, 01:45 PM   #11
Redwagon
rolling Rolling ROLLING....
Redwagon's Avatar
Bronco Info: 85 with junk on it.
parts stores...I ended up using one off a ford van.
Tim
Redwagon is online now   Reply With Quote
Old 04-27-2006, 01:48 PM   #12
hmthesing
hmthesing's Avatar
Okay, just wanted to make sure the brackets weren't different between the years.
Old 04-27-2006, 01:51 PM   #13
plug ugly
Master Bater
plug ugly's Avatar
Bronco Info: 4 wheels, 4 sticks and 3 pedals
what does the hi press fitting look like? Can you mod it for more flow like the regular sag box?
Stupid is as Stupid does
mostly a 94 Bronco
wt4wheeling
plug ugly is offline   Reply With Quote
Old 04-27-2006, 01:52 PM   #14
Gacknar
The Anti Yam!
Gacknar's Avatar
Here is the thread where I learned about the pump.
http://fullsizebronco.com/forum/showthread.php?t=30444
Post #4 by Dogonmut.
He says
Originally Posted by Dogonmut
You will need to swap to a high pressure line from a 78/79 Bronco. I don't have the part # for that item but it's only $14.99 at Auto Zone.
Old 04-27-2006, 02:00 PM   #15
TTBlows
TTB Hater of course
NO you didn't. You thought
He sure schooled us.
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline   Reply With Quote
Old 04-27-2006, 02:16 PM   #16
Gacknar
The Anti Yam!
Gacknar's Avatar
Old 04-27-2006, 05:00 PM   #17
imlikeojnow
So this one will bolt up right to the stock bracket without modding or building a new brackst the only thing is the high pressure line. does anyone have a part number on the high pressure line.
Old 04-27-2006, 05:42 PM   #18
Gacknar
The Anti Yam!
Gacknar's Avatar
It's for a 78-79 Bronco.
You have an internet connection.
Look it up at any parts store website.
Old 04-27-2006, 06:44 PM   #19
Dangling_Dave
Support our troops!
Dangling_Dave's Avatar
Bronco Info: 1996 Bronco, D-60 5.13 gears Detroit Locked front, Sterling 10.25, 5.13 gears, Detroit locked rear
Geeze I don't know why you guys have so much trouble finding the right bracket. I see them all the time at my local yard. If I had any ambition I would gather them up and start whoreing them out.
dc
Dangling_Dave
Only WE can prevent Illegal Aliens!
Round them up and send them home
Dangling_Dave is offline   Reply With Quote
Old 04-27-2006, 06:50 PM   #20
imlikeojnow
dc
no one is having a problem apparently this one will bolt right up to the stock bracket. i was asking about the high pressure line
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
