Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 03-26-2006, 08:16 PM   #1
stressed
stressed's Avatar
Bronco Info: 95.. white..
95 Bko" e4od to c6 trans swap issues....
I swapped out my e4od for a c6 and am having some issues. The bronco is a 1995 with mass air.. I used a 95 mustang(manual) computer and hooked up the wires per Fireguys instructions (reverse light, neutral safety, tcase) using a B&M floor shifter. Onto the issues.. Any ideas on how to resolve any of these is appreciated..
When in reverse you have to rev it up quite a bit for it to move.. In drive or any forward gears it will not move at all. If you play with the gas a bit and find its sweet spot it will move a little. I was able to back it out of the driveway and after a bit i got it moving forward but after a quick drive around the block (2 minutes tops) the temp was at 210 degrees. The first thing that came to mind was that maybe the lines going into and out of the fluid filter were crossed. I swapped those when it cooled but i still got the same result. The torque converter is brand new and i filled it halfway before i installed it then ran the engine when i added the ATF. Could the fu@#$ing trans be toast already.
Help.
(Site Back Up) http://www.Bronkzilla.com
(4x Pics) http://www.Bronkzilla.com/4xpics.html
stressed is offline   Reply With Quote
Old 03-26-2006, 08:23 PM   #2
84x4bronco
Bitchin.
84x4bronco's Avatar
Bronco Info: 84 bronco 351W, C6, 79 D44, 9", Twinstick 205
sounds like a toasty transmission to me. thats what my F150 did.
84x4bronco is offline   Reply With Quote
Old 03-26-2006, 08:33 PM   #3
BRONCFOOT
FSB Peckerhead!!
Bronco Info: 93 XLT, 93 EB, 90EB, 93EB 302
Try: Ford Transmission Forum.com--try the search heading first,if no luck post a question,try it before pulling that heavy mofo
Dont drink & drive-pull over & finish your beer!
BRONCFOOT is offline   Reply With Quote
Old 03-26-2006, 09:19 PM   #4
stressed
stressed's Avatar
site wont load up... i added www. and took out the spaces.
Old 03-26-2006, 09:24 PM   #5
locopny
They call me "MR FLAT TIRE"
locopny's Avatar
Bronco Info: Bronco parked and broken
sounds like the seals are not good...among other problems. my old C6 would do that, but once warm, problem wouldn't show up.
Now here to check Classifieds mostly.
Originally Posted by 90Beater
locopny is offline   Reply With Quote
Old 03-26-2006, 10:30 PM   #6
stressed
stressed's Avatar
is that repairable without dropping the the trans?
i need to have the bronco loaded up on the trailer by thursday night..
Old 03-26-2006, 10:54 PM   #7
stressed
stressed's Avatar
would a loose vac line going to this thing cause any problems.. i couldnt get it to fit snug.. ive never seen one installed, just heard about it...
Old 03-26-2006, 11:09 PM   #8
kf4amu
FSB's airline pilot
kf4amu's Avatar
Location: hotels, Charlotte, Roanoke VA, the cockpit...time split equally between all of them.
Bronco Info: 1989 460 EFI/C6/BW1356 electric/6 inch Rough Country lift/York OBA/Warn hubs/electric fans/14 bolt
Raf if its that bad I think its internal. My vacuum line is held on by its own friction over the nipple. I've noticed when cold or having sat for a while I get a slight hesitation before it wants to put the power to the rear. It goes away quick enough that I doubted it existed until a thread last week about this same subject.
-Will
-Will
064 tlx 98
http://www.supermotors.org/registry/...ail.php?id=819
The best electric fan writeup out there
http://fullsizebronco.com/forum/showthread.php?t=40564
kf4amu is offline   Reply With Quote
Old 03-26-2006, 11:17 PM   #9
peteyg
Token Jeep Guy
peteyg's Avatar
Bronco Info: 1978 Bronco XLT, 6" lift, 31's/35's/37's
The vacuum modulator will cause very weird shifting problems. If there is a vacuum leak, it will not work. I know on my TH400 I had in the Caddy, it caused all kinds of havok
Also, when I rebuilt my '400, it took a LOT of fluid to get it filled. Way more than seemed reasonable, but once it was within a quart of full it started shifting good. I don't know how it works for the C6, but it's something to look at. Also, are you sire the TC was engaged properly? If I remember, the Ford TC needs to rotate three clicks to engage right...
I'm Bronco-less again, but it was For A Good Cause
peteyg is offline   Reply With Quote
Old 03-27-2006, 12:08 AM   #10
Clarko
Can't afford it!
Clarko's Avatar
Bronco Info: 88 351 AOD 94 351 E4OD
The C6 I have, before it was rebuilt that is, did that same thing in the ole' F-250 it was in and it was shot, and got rebuilt.
Brian
Click the pic for SuperFord.
Clarko is offline   Reply With Quote
Old 03-27-2006, 12:31 AM   #11
Davids78Bronco
Davids78Bronco's Avatar
Bronco Info: I may be slow, but I'm expensive!
You're sure it has the right amount of Type F? I know you stated you added more, but ...
Davids78Bronco is offline   Reply With Quote
Old 03-27-2006, 12:55 AM   #12
stressed
stressed's Avatar
theres about 14 ot 15 quarts in it.. 12 + whatever it took to fill the longer hoses, filter and new cooler.. the dip stick shows fluid just a nut hair past the fill line..
Old 03-27-2006, 12:56 AM   #13
imlikeojnow
green ones make me horny
imlikeojnow's Avatar
Bronco Info: 1994 w/ built 302, E4OD, 33in tires, custom exhaust, upgraded ign. running like a raped ape
http://www.network54.com/Forum/searc...archterm=E4OD+
ford tranny forum
Originally Posted by SigEpBlue View Post
No, I don't have this problem. Money grows on trees here in Michigan, and my Bronco gets 45 mpg. It emits sunshine and a light berry scent, and it never needs service or parts.
imlikeojnow is offline   Reply With Quote
Old 03-27-2006, 02:04 AM   #14
stx4wheeler
stx4wheeler's Avatar
Bronco Info: 95bronco(dd) 78 bronco trail rig
i would say check the fluid one more time or hell even try and pur some more in if it says its full, when i changed the fluid, and filter on my 78 last year, i filled it up, with what i thought was the same amount that came out. i started he up, put it in reverse to leave the driveway and it rapped up and kinda slammed into gear. Then once i got backed out i figured it just need some time to get fluid everywhere again, well that wasn't it i had to do exactly what you are explaining you are having to do with yours. So since i couldnt see(it was dark) i jsut poured another 1 or 2 quarts in her and one the second one that was it, and problem was solved. good luck man i hope the tranny aint toast.
its a jeep thing eh, your right i wouldnt understand!!
95 bronco (DD) light bar four pro comp 130's, true dual exhaust through hollowed cats, and flowmaster 40's
78 bronco 460/c-6/205/60 front/ sterling 10.25 rear/hydro assist steering,lincoln locked front/rear, cage to the frame, and a garage full of parts.
stx4wheeler is offline   Reply With Quote
Old 03-27-2006, 02:51 AM   #15
Chris85xlt
Chris85xlt's Avatar
Bronco Info: 85xlt with stuff
do C6 use TV cables like on AODs. maybe check that
Chris85xlt is offline   Reply With Quote
Old 03-27-2006, 02:57 AM   #16
Clarko
Can't afford it!
Clarko's Avatar
Nope, they use a vacuum modulator/kickdown combo.
Old 03-27-2006, 06:52 AM   #17
87EBBronco
Back in TEXAS
87EBBronco's Avatar
Bronco Info: 87 Eddie Bauer 5.0/C6/BW1356
My C6 uses Dexron III not Type F. I thought all the later C6's used Dexron.
Mike
My Super Motor's Link
87 EB, EFI 5.0, C6, Manual 1356, 32x11.50Rx15 Buckshot Mudders, Ravin exhaust, 9mm Ford Racing Wires, KN filter, Yukon 31 spline axles, Uniden 510 Pro CB
"Do not meddle in the affairs of dragons, for thou art crunchy and taste good with ketchup!"
"The difference between fiction and reality, fiction has to make sense" Tom Clancy
87EBBronco is offline   Reply With Quote
Old 03-27-2006, 09:03 AM   #18
stressed
stressed's Avatar
hmmm.. i was told type f.. could that cause the symptoms above?
Old 03-27-2006, 09:33 AM   #19
imlikeojnow
No it wouldnt fry the tranny like that. you may want to drain it though and put the right stuff in it. To me it sounds like the tranny itself is fried
Old 03-27-2006, 10:07 AM   #20
Washburn
Explorer driving
Washburn's Avatar
Bronco Info: Sold
Here's some help possibly...
It states in 1976, the C6 used Type F, from 1977-1986, Dexron II
http://www.autozone.com/servlet/UiBr...3d800a4cbd.jsp
A sharp tongue can cut your own throat.
Washburn is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
