Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 02-17-2006, 06:05 PM   #1
Swampwalker3
Swampwalker3's Avatar
Bronco Info: Red '89 YJ: I6; Ax15; D60/14B: 38.5" Boggers; 5.13s; SOA, SYE, 6" stretched front
Getting closer; more questions about the Saginaw pump. (Pics)
Well, after work yesterday I went and checked out a new junk yard in town due to boredom and found a few rows of old vans and old model F series trucks, so as you can imagine, there's a great surplus of sag pumps.
To keep a long post short; is there a certain way to have a sag sitting? Such as, tilt to the left- right- sitting straight up? I figure if I drill a hole for the top mount into the sag bracket and then mount that up, I will be set but it will leave me with it tilting inward: Good or Bad?
I figure if that's a bad idea, I can take one of those slider things similar to the bracket the adjusting bolt sits on the Alternator to line it up.
It looks as if it will work since the lines are at the base of the pump, but just wanted to make sure since I have to space the bracket a little to get the pulleys to line up.
Also, I found a huge ass V-belt pulley that looked like it was 8" across on one of the sags. If it would fit in my situation, I can only imagine that it would be superior compared to the pulley I have now? Bigger the pulley the faster it turns, and I've never heard anyone say their pump sucks because of the high amount of flow. Any ideas on that?
Anyway, here is how the pump is bolted up as of now, Tell me it looks awesome...
Don't mind the belt, I decided to fiddle before I took the pics, I will be wanting to put the belt on the empty pulley, which you can see in the second pic. (?) The fan will clear the belt.
And just so everyone knows this is for a FE 360/390 engine. Info. on the swap with this block is non-existing; it seems.
Swampwalker3 is offline   Reply With Quote
Old 02-17-2006, 06:09 PM   #2
Redwagon
rolling Rolling ROLLING....
Redwagon's Avatar
Bronco Info: 85 with junk on it.
cool... just getting ready to start my swap.
Tim
Redwagon is online now   Reply With Quote
Old 02-17-2006, 06:17 PM   #3
kf4amu
FSB's airline pilot
kf4amu's Avatar
Location: hotels, Charlotte, Roanoke VA, the cockpit...time split equally between all of them.
Bronco Info: 1989 460 EFI/C6/BW1356 electric/6 inch Rough Country lift/York OBA/Warn hubs/electric fans/14 bolt
Bigger the pulley SLOWER it turns.
-Will
064 tlx 98
http://www.supermotors.org/registry/...ail.php?id=819
The best electric fan writeup out there
http://fullsizebronco.com/forum/showthread.php?t=40564
kf4amu is offline   Reply With Quote
Old 02-17-2006, 07:31 PM   #4
RLKBOB
Ex Navy Nuke
RLKBOB's Avatar
Bronco Info: 1990 EB, 357, E4OD
I can't answer your question for sure as I have a different body style and setup for mine but it looks like it should work fine. As long as it doesn't interfere with anything else or spill the fluid out the top you should be good.
And
You need a smaller pulley if you want it to spin faster.
Bob Kulhanek, My Superford
Hit it harder or get a bigger hammer!!!
Originally Posted by DcSkater602
slap me silly im a mother F^%#$%*($ retard
Originally Posted by Bonzai View Post
Oh yea! Im definitely interested in a rear.
RLKBOB is offline   Reply With Quote
Old 02-17-2006, 07:34 PM   #5
Redwagon
Redwagon's Avatar
would a smaller pulley cause the pump to wear more? or is it ok to run one?
Old 02-17-2006, 07:35 PM   #6
Swampwalker3
Well, screw that idea then.
Guess I'll test it out.
Thanks.
Old 02-18-2006, 05:53 PM   #7
Swampwalker3
Day started off well,
I found the slider bracket I was looking for to save me some drilling and I got the whole thing mounted up, lined up and was about to call it colplete until I went to tighten the bolt on the bottom and broke apart the hole the held the bolt onto the engine. Never fails.
Lucky for me, the old bracket was only held in by the top bolt and the bolt on the back, so at least I wont have to guess on that...
Looks like I'll have shitty steering for awhile..
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
