Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 12-26-2005, 01:32 PM   #1
smokeytires
swapping 1 ton 2 wheel drive to 4x4
I have a 1 ton cc dually when I bought the truck it has a 500 c.i. cad engine 400 turbo.I bought an adapter to put a 700 R4 in it. Since then I've heard you can swap a 4x4 into it direct. Ijust was wondering if anyone had any ideas which would be the best swap. Don't need to keep the cad engine.
smokeytires is offline   Reply With Quote
Old 12-26-2005, 01:43 PM   #2
BigBroncoXLT
BigBroncoXLT's Avatar
Bronco Info: 1985 XLT
WTF?? Is this a cross breed or are you messin with a chebby?
Jeff
The Alpha Male Mobiles
88 Bronco XLT 4" superlift, D44 SAS, 8.8 rear, 33.12.50 BFG MT's 302/AOD/208 SOLD
http://www.supermotors.org/vehicles/...il.php?id=4849
85 Bronco XLT 2.5" rough country lift 351W/C6/208 9" rear TTB up front.
http://www.supermotors.org/vehicles/...il.php?id=9181
Originally Posted by MANNY
I love when i can play with my stuff.
BigBroncoXLT is offline   Reply With Quote
Old 12-26-2005, 01:47 PM   #3
smokeytires
cheap buy
I bought it a police auction $900.00 . No rust southern truck. Good shape. Can't complane.
Old 12-26-2005, 01:56 PM   #4
derrick36
derrick36's Avatar
Bronco Info: 1991 302, E4OD, 1356
That didnt really answer the question. WTF is it? Some Frankenstein Ford, or a Chevy?
Lock the door, kill the light.
derrick36 is offline   Reply With Quote
Old 12-26-2005, 02:34 PM   #5
adrianspeeder
deployed C-17 MX
adrianspeeder's Avatar
Bronco Info: '92, '90, '88, and '84 Broncos
Well whatever you have ford or chevy, you need a tranny from a 4x4 so you can bolt a transfer case to it.
Adrianspeeder
adrianspeeder is offline   Reply With Quote
Old 12-26-2005, 03:11 PM   #6
cadaver
cadaver's Avatar
Bronco Info: 80(4sale)87 EB
And a complete 4x4 front end and driveshaft and a 4x4 rear shaft. Dont know what brackets, members as we still dont know what the truck is
Originally Posted by Sway
The point was for a newbie to look gay.
Give me fuel, give me fire, give me that which I desire
cadaver is offline   Reply With Quote
Old 12-26-2005, 09:09 PM   #7
smokeytires
FORD 1ton 4x4 swap
This truck is a ford 1 ton .Igot pulled away from thisforum just got back. I'd like to keep the rear duals so I don't know as what would be best front end etc. to swap into it. I also bought a 1984 4x4 3/4ton at the same auction the same day for $600.00 . Deal is it only has a 351 C6 setup.So I can drop a 460 as long as I reshaft the trans. Or go chevy drive line and keep the cad. or ?.S/T
Old 12-27-2005, 01:09 AM   #8
BigBroncoXLT
You need to Search on that 460 swap..it takes a bit more than a reshaft.
Old 12-27-2005, 01:13 AM   #9
ToddACimer
1-tons aren't
ToddACimer's Avatar
Bronco Info: 93 F250... TTB and shit
Good luck. I'm still kind of confused as to what you want to do. From what I can tell you have 2wd dually and you want to make it a 4x4. You'll need a front axle probably a D60 since it's a 10 ton. You will also need transfercase and a transmission that can connect to the transfer case.
Recipient of multiple driving awards from State and Local officials.
ToddACimer is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
