| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Warn Premium Install
#1 |
negative creep
![]() Join Date: Mar 2003
iTrader: (1) Bronco Info: bronco with seats and a steering wheel
I finally got off my lazy ass and upgraded my factory hubs. I figured I should do it while they are still good and can be thrown into my toolbox to use as spares. Just in case you were wondering, my bronco is an 89 351 C6 with factory manual hubs.
Go here for all the nitty gritty on Warn Premium Locking Hubs... ![]() Time for this crap to go... ![]() Start by removing the 6 hex head bolts that hold the cover in place... ![]() This is what you will see, there is a snap ring around the axle shaft, and a locking ring in a groove about 1/2" back from the edge of the rim... ![]() Use a pair of snap ring pliers to remove the axle shaft snap ring... ![]() Somehow you will have to get the lock ring out. It is a girl dog to remove. I used some micro screwdrivers to pry it out, but you can use whatever works... ![]() Now that the hub is just sitting there, put 2 of the hex head bolts back in and use them to pull the hub out... ![]() Like this... ![]() Now would be a good time to do this... ![]() Its like fine art work... ![]() Lightly grease the new hubs and put them in the same way you took the stockers out... ![]() Put the lock ring and the snap ring back in. The hubs should come with new ones, use them... ![]() Make sure that the covers are in the "free" position and bolt them on, engage the hubs and check to see if they lock (Note: these hubs take 9/10 of a turn, and not the pu$$y 1/4 turn). If you can follow pictures, they should... If you get lost, try reading the directions that come with it... If you have any questions or would like higher resolution pictures, PM me Thanks BMC for the wheel bearing write-up ![]() |
| Sponsored Links | |
Advertisement |
#3 |
yeah great write up but you left the part out where oyu modified the out ring by grinding he ends to make it easier to get out later
my bronco 1980 ford bronco 302,2 in body lift, 35*12.50 dunlop mud rovers, np435, 9in rear, dana 44 ft (soon to have 351w, 4 in dickcepek series II lift and 4.11 detroit rear and truetrac front) |
#4 | |
negative creep
they aren't that hard to get out, once you figure out how |
#6 |
Screw the Jeep Thing
I ground a little lip in my ring. This way I can stick to flat head screw driver in each side and it pops right out. Cept the one I made the lip on the wrong side. Not sure what I was thinking on that one:)
'84 Bronco (SOLD) - I6 Motor, ALL STOCK '93 Bronco Eddie Baurer (SOLD) - 302, E40D, 1356, 6" Lift, 35x12.5 BFG AT's '94 Bronco XLT - 351W, E40D, 1356, ALL STOCK |
#7 |
iTrader: (0) Bronco Info: 78 4"lift 42"tsl's 4.88gears
Nice write up Andy! It should help out alot of the noobs.
78 bronco 400cid, C6, NP205, 4''lift, 2'' body lift, 42''tsl swampers, KORE beadlocks, 4.88gears, 14 bolt rear, Detroit, HP 60 front, welded, Warn HS9500i winch, custom rock skids, and winch mount, saginaw steering pump swap, 1410 High Angle Driveshaft, Psycho Fab half doors, Psycho Fab cage. http://www.superford.org/members/profile.php?id=7281 |
#8 |
I think I just got dirty.
iTrader: (0) Bronco Info: 95 XLT, dual exhaust, rest is stock for now
excellent write up! great pics too!
30% Disabled USAF Veteran ![]() Driving a truck is a lifestyle, not a job. If you got it, a trucker brought it! |
#9 | |
Tator Salad
sooner or later im gonna do that ![]()
Cory Seiber 1985 Ford Ranger |
#10 |
BroncSho
iTrader: (1) Bronco Info: 1979 EFI 460, 33x12.5 Yoko Geolander At's
My '79 came with those warn Hubs, the 9/10 turn to engage
1979 Bronco 460 FI/C6/205, 33x12.5 Yokohama Geolandar AT 2000 F150 5.4l/4R100 Supercab, Shortbox, 7700 Package XLT, 4x4 1990 Taurus SHO 3.0/MTX/Fully Loaded/ Lowered/ Chipped (eventual Supercharger) 1995 Taurus SHO 3.0/MTX/Fully Loaded/ Stock Suspension/Stock Engine |
#11 |
iTrader: (0) Bronco Info: 95 F-150 5.0 ZF5 4x4 4" lift 33" MT
The trick to those PITA rings----- theres a small hole in the casing, which can allow a very small screwdriver(i used an akken wrench) you just jam sonething in that lil hole and itl push the ring out, then just slide a screwdriver an pry. saves 10 min of frustratoin and lots of pain(i got very angry and punched something and split 2 knuckles open). this way takes 30 seconds.
Tim |
#12 |
Jer aka Beerman
iTrader: (6) Bronco Info: Sold Bronco, but still live in the off topic threads
Copy cat
I gots one in my SF page.
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan PH.D. |
#13 |
iTrader: (0) Bronco Info: 95' All black 351w, E4OD, 3:55
I put some in my 95 the other day, it has 3 screws, but i couldnt get the small snap ring in, the big one thats a pain in the a** to get out went in fine, i just figured that, its all that holds in autos in and it would be fine. I fought with it for like 1/2 hour before i gave up
#15 |
scrounger extrordinaire
iTrader: (0) Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
wow. think about all that extra time it takes to turn it 9/10s of the way -vs- the old 1/4 turn. thats going to cut into your wheeling time...
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering |
#16 |
What's the benefit to the 9/10's turn? What's wrong with just 1/4 turn? I've been thinking about slapping these on (Def the premiums because they are only $10 more) but I was wondering what the big deal was.
-Robert F '94 XLT 5.8EFI, E4OD - For Sale |
#17 |
Welcome to the jungle
iTrader: (0) Bronco Info: '78 with a tailgate
The gold bling-bling finish helps you over rocks, and nets you another 2-4 hp. Note: those are mid-range figures. Premium hubs don't affect top end power.
Lonestar Bronco on Supermotors.org |
#18 | |
negative creep
#19 |
Okie cool! Sounds like a good upgrade for the truck! So if I already have manuals I don't need the conversion kit right? Just unscrew and pull and the old ones and slap in the new ones?
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
