| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Reviving the Turd.....
#41 |
PM for pics of my
![]() Join Date: Oct 2003
iTrader: (0) Bronco Info: You mean Bonneville, right?
Hope all fairs well, Raf.
I hope the fix is cheap and she gets up and running again. It's a shame o see it sit. :(
My Superford [dougs89] 1:57 am: i was flipping through channels and saw an old man with wood [chambiec1] 1:57 am: like dick wood? [dougs89] 1:58 am: no like big piece of wood wood -Just call me "Casey" |
| Sponsored Links | |
Advertisement |
#42 | |
FSB Owner/Admin
Joe FullSizeBronco.com |
#43 | |
Put a C6 in it..get it over with. Good luck Raf.
Jeff The Alpha Male Mobiles 88 Bronco XLT 4" superlift, D44 SAS, 8.8 rear, 33.12.50 BFG MT's 302/AOD/208 SOLD http://www.supermotors.org/vehicles/...il.php?id=4849 85 Bronco XLT 2.5" rough country lift 351W/C6/208 9" rear TTB up front. http://www.supermotors.org/vehicles/...il.php?id=9181 Quote:
#44 |
Token Jeep Guy
![]() Join Date: Apr 2004
iTrader: (4) Bronco Info: 1978 Bronco XLT, 6" lift, 31's/35's/37's
Raf, it was a pleasure introducing you to Truckhaven. Hopefully you'll be ready in time for TDS. I'm goin for sure.
I understand how it is when you're trying to get a rig running that just wants to be a biatch. Good luck with it. If there's anything I can do to help, let me know.
I'm Bronco-less again, but it was For A Good Cause |
#45 |
negative creep
![]() Join Date: Mar 2003
iTrader: (1) Bronco Info: bronco with seats and a steering wheel
i was just wondering where you've been dude. just throw an np435 in there. it would be sick if you made it to arizona with me and damon
#46 |
just got the call.. the tranny is toast... $2800 to rebuild whats left of it and add a new torque converter.. the culprit was the tranny cooler that is in the radiator.. i added a seperate cooler but i didnt bother to bypass the crappy cooler in the radiator..
(Site Back Up) http://www.Bronkzilla.com (4x Pics) http://www.Bronkzilla.com/4xpics.html
#47 |
Guest
Shitty.
#48 | |
FSB Owner/Admin
#49 |
the fluid wasnt able to flow and thats why it got as hot as it did and boiled out of the fill hole. im still undecided as to what im going to do. there is no way im dishing out that amount of money to fix it.. other options come to mind but at the time i dont think i have the patience for them.
imagine having morning wood and then this happens--> thats how im feeling at the moment.. my noooooooooootz |
#50 |
can I go to bed yet?
Time for a C6 trans. I can make the electrical work
Ryan McCormick RJM Injection Tech My Bronco Ford Fuel Injection.com Technical Library Parts replacement is not auto repair, if you can’t diagnose, don’t open the hood! |
#51 |
i know we talked about this before ryan and you mentioned a computer out of a t-bird or something.. this was well over a year ago.. how confident are you in what you have learned about the swap since then. in a scale of 1 to 10.. 1 being the first fan harness you sent me and 10 being the 2nd fan harness you sent me...
any info is appreciated.. |
#53 |
how hard would it be for me to install that and rewire whatever needs to be rewired..?
how much does something like that cost? if i cant get an e4od from my buddy tom (locopny) im going to seriously consider the c6 swap.. it all depends on da moniez... |
#56 |
Token Jeep Guy
I know where there is a C6 from an '82 right this minute. I'll bet I can get it for you very, very cheap. It's sitting in a buddy of mine's yard right now. The tranny is in Hemet.
Edit: It was running and driving before he started parting it out. Last edited by peteyg; 01-31-2006 at 09:31 PM.. |
#57 | ||
All the engine controls are on the same terminal locations Simply plug in the new computer, ignor the old trans wiring under the truck Quote:
#59 |
1994-95 5.0L Mustang (manual trans)
F4ZF-12A650-EA T4M0 A1 CARDONE Part # 785918 STANDARD MOTOR PRODUCTS Part # EM10101 I have first dibs on your old computer! |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
