| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Bronco Tranny and T-Case Info
#1 |
USAF C-17 Avionics
![]() Join Date: Dec 2004
iTrader: (1) Bronco Info: '92, '90, '88, and '84 Broncos
With all the posts on what trannys are what, or "what do I have" I thought it would be a good idea to make a total list for the full size fords. Just now I wipped this up to start off, but will keep workin. Please post any corrections ya'll see so I can edit.
For the engine listings. I'll break the shared bell housing patterns in {}. Heavy Duty Automatics Model: C6 Type: three speed non electronic Years: '66-'90 F-series '78-'89 Bronco '91-'96 ('97?) F-2/3/superduty Engines:{300, 302, 351w}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.} Fluid: Pre '77: Type F Post '77: Mercon Display: PRND21 Pan 17 bolts "Utah" shape Ratios: 1st 2.46:1 2nd 1.46:1 3rd 1.00:1 Trans code: K Model: E4OD Type: Electronic Four speed Over Drive Years: '90-'96 Bronco, '89-'98 F-Series Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L} Display: PRN(D)21 w/ overdrive lockout switch Pan: 20 bolts Fluid: Mercon Ratios: 1st 2.71:1 2nd 1.54:1 3rd 1.00:1 4th 0.71:1 Trans code: E Model: 4R100 Type: Four speed, Rear wheel drive, and 100(x10)lbs of torque Years: '99-'01 F-150's (rare) '99-'04 Lightning's, F-150 7700' '99-'03 superdutys '03-'04 gas superdutys Engines: {5.4L, 6.8L}, {7.3L PSD} Display: PRN(D)21 w/ overdrive lockout switch Pan: 20bolts Fluid: Mercon Ratios: 1st 2.71:1 2nd 1.54:1 3rd 1.00:1 4th 0.71:1 Trans code: E (gas), 9 (diesel) Model: 5R110 “Torqshift” Type: Five speed, Rear wheel drive, and 110(x10)lbs of torque Years: '03-'04 6.0L '05-'07 Superdutys Engines: {5.4L, 6.8L, 6.0L}, Display: PRN(D)321 w/ tow haul lockout switch Pan ? Fluid: Mercon SP Ratios: 1st 3.09:1 2nd 2.20:1 3rd 1.538:1 4th 1.00:1 5th 0.71:1 Trans code: B Light Duty Automatics Model: AOD Type: Four speed non electronic Years: '85-'93 F-150 '85-'89 Bronco Engines: 302 Display: PRN(D)D1 Pan ? Fluid: Mercon Ratios: 1st 2.40:1 2nd 1.47:1 3rd 1.00:1 4th 0.67:1 Trans code: T Model: 4R70w Type: Four speed, Rear wheel drive, and 70(x10)lbs of torque Years: '94-'07 F-150 Engines: 302, 4.2L, 4.6L, 5.4L Display: PRN(D)21 w/ overdrive lockout switch Fluid: Mercon V Ratios: 1st 2.84:1 2nd 1.55:1 3rd 1.00:1 4th 0.70:1 Reverse 2.32:1 Trans code: U Model: 4R75E Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque Years: '04-'07 F-150 Engines: 5.4L Display: PRN(D)21 w/ overdrive lockout switch Fluid: Mercon V Ratios: 1st 2.84:1 2nd 1.55:1 3rd 1.00:1 4th 0.70:1 Reverse 2.32:1 Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT) Manuals Model: M5OD-R2 Type: Five speed Mazda Overdrive Years: 88-96 Bronco, F150s ..........97-03 F150s ..........05 F150 (v6) Engines: 300, 302, 4.2L, 4.6L Fluid: Mercon Display: 1.3.(D) 2.4.R Ratios: 1st 3.90:1 2nd 2.25:1 3rd 1.46:1 4th 1.00:1 5th 0.80:1 Construction features: External Ribs in square patterns Trans code: M Model: SROD Type: Four speed overdrive w/ push down reverse Years: 80-83(4?) Engines: 300, 302 Fluid: ? Display: P..R..1..3 U S.....2..OD H Ratios: 1st 3.25:1 2nd 1.92:1 3rd 1.00:1 4th 0.78:1 Reverse 3.25:1 Construction features: Aluminum, shifter near back Trans code: B Model: NP-435 Type: Four speed non overdrive Years: 80-87? Engines: 300, 302, Your mostly gonna find it behind a 300. Display: 1.2 3.4.R Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side Fluid: 140w Ratios: 1st 6.69:1 2nd 3.34:1 3rd 1.79:1 4th 1.00:1 Reverse 3.25:1 Trans code: A Model: T18 Type: Four speed, non overdrive, non syncro first gear Years: ? Engines: 300, 302, 351, 460 Fluid: ? Display: 1.3 2.4.R Construction features: Cast iron throughout Ratios: Gas 1st 6.32 2nd 3.03:1 3rd 1.79:1 4th 1.00:1 Diesel 1st 4.02:1 2nd 2.41:1 3rd 1.41:1 4th 1.00:1 Trans code: F or P Model: T19 Type: Four speed, non overdrive, syncro first gear Years: ? Engines:460?, 6.9L, 7.3L Fluid: ? Display: 1.3 2.4.R Construction features: Cast iron throughout Ratios: Gas 1st 6.32 2nd 3.03:1 3rd 1.79:1 4th 1.00:1 Diesel 1st 4.02:1 2nd 2.41:1 3rd 1.41:1 4th 1.00:1 Trans code F or P Model: ZF5 Type: Five speed heavyduty overdrive Years: 87-99 F2/3/450/superduty Engines: 300, 351, 460, 7.3 Fluid: Mercon Display: 1.3.(D) 2.4.R Ratios: S5-42 (Diesel) 1st: 4.14 2nd: 2.37 3rd: 1.42 4th: 1.00 5th: 0.77 Reverse: 3.79 S5-47 (diesel) 1st: 5.08 2nd: 2.61 3rd: 1.53 4th: 1.00 5th: 0.77 Reverse: 4.66 S5-42 and S5-47 (gas) 1st: 5.72 2nd: 2.94 3rd: 1.61 4th: 1.00 5th: 0.76 Reverse: 5.24 Trans code: 2 Model: ZF6 Type: Six speed heavyduty overdrive Years: 99-06 F-superduty Engines: 5.4, 6.8, 7.3, 6.0 Fluid: Mercon Display: R.1.3.(D) L.2.4 Ratios: L 5.79:1 1st 3.30:1 2nd 2.10:1 3rd 1.31:1 4th 1.00:1 5th 0.72:1 R 5.23:1 Trans code: 6 (diesel), 5 (gas) Adrianspeeder
'08 F250 6.4 PSD ZF-6 4x2, '02 F250 7.3 PSD 4R100 4x4 CC, '97 F150 4.6 M5OD-R2 4x4, '79 F100 302 TOD 4x2 Custom, '79 F150 351 C6 4x2 Dually Lariat, '74 F250 360 C6 Hiboy 4x4, '71 F100 302 4x2 3 on tree, '66 F250 352 4x2 3 on tree, Broncos: '95 XLT 351 E4OD up 6", '92 XLT 302 M5OD-R2, '90 XLT 302 AOD, '88 XLT 302 AOD, '84 Lariat 351HO C6, '85 M-1009 (K-5 Blazer) 6.2 TH400 US Army Surplus ReDEPLOYED x2 C-17 Avionics AMXS Journeyman USAF Last edited by adrianspeeder; 03-04-2007 at 07:43 PM.. Reason: updates |
| Sponsored Links | |
Advertisement |
#2 |
FSB warrior
iTrader: (5) Bronco Info: was an 81, GT-40P, NP-435, NP208, 36s, 0" lift
Heres my contribution
NP-435 What a clean NP-435 looks like from the passenger side it has an Aluminum top cover that the Shifter actually comes out of. It says NP on it above the PTO cover It has a PTO cover the shifter goes 1 3 2 4 R 6.69,3.34,1.79,1.00 are the ratios SROD An SROD (Single Rail Over Drive) Trans Code B Made by Tremec for Ford (T150FS, it has a Ford symbol on the side) From a site that said that the Top shifter version was mostly in Ford broncos (so may/may not be correct) 3.01 1st, 1.78 2nd 1.00 3rd .79 4th and 3.01 Rev or 3.25 1st, 1.92 2nd, 1.00 3rd, .78 4th and 3.25 Rev It has the shifter behind the tranny Is one of the only Ford trannys that you have to Push down to get into reverse (its brother the SR4 has to do that as well) ![]() ![]() Pass side (tag and Fill/drain plug) ![]() Drivers side... thats a Ford Symbol ![]() Is made entirely of aluminum(case) and may be found with the T case adapter cracked (also aluminum) To get rid of the crap and put a diamond in its place.. In order to swap in an NP-435 in an 80-83 Bronco with an SROD Trans Code Boriginally You need NP-435, T case adapter, Bellhousing for a Smallblock with 11" manual clutch, and the shifter for the 208/NP-435 End of story these are the only things you need to change. You need a grinder and a Drill w/ 3/8" drill bit to do the only fabrication mod. It involves the T case shifter, Bolt the NP shifter to the case with the big bolt. Take the SROD shifter link (12-14" long or so) and grind of the nub on it. Drill the hole that is just the right size for the nub on the NP shifter to go threw it.
Vote for FOTM and Top 4x4 site 1BadBronco MAFBFD was a81 Bronco Custom. Sold See my superford link for how I built her! NOW83 F-250 6.9L IDI, C-6 1345 D44HD and D70 rear with 3.55 gears |
#4 |
Practicing Infidel
![]() Join Date: Dec 2003
iTrader: (1) Bronco Info: 86 Eddie Bauer; EFI 5.0 liter, AOD, optimized ignition system, external tranny filter, urethane bush
Great idea Adrian
especially when it figures as the most expensive single component in the Bronco/F-150. In most cases, the stock engine isn't worth as much to rebuild as the trannies can cost. If DarkSide or the moderators go for it, I'd like to suggest we add pics of things like the remote filters, auxillary coolers, routing diagrams for the coolers, etc. Also maybe a write up on each tranny's filter change, torque converter drain plug, etc. Another item would be a drain plug mod and the different aftermarket pans available. Shift kits that helped, shift kits that botched the tranny too. Special mention about the electronic equipped trucks habit of the in-rad cooler loop sludging up and killing the electronic trannies. That special retrofit TV brass bushing available from Ford, that for one dollar, could save your tranny; Think of the carpel it would save us ! Great idea Adrian Sixlitre
My Superford site http://www.superford.org/registry/vehicles/detail.php?id=4970&s=17328#content |
#5 | |
FSB warrior
Can you throw a pic in of each after the Heading???? |
#7 |
sticky sticky sticky sticky!
Rune 94 EB 351W 200000 custom exhaust msd components "yea well I'm an expert in *nameology*"~agent smecker "so is there still tread on those tires of yours or is it like throwing a hot dog down a hallway?"-stewie griffin |
#8 | |
Lick my
Ive been looking to do this to my Bronco for a while now. Am I correct that the 300 bellhousing is the same as the 351W bellhousing? I can get a complete donor truck for $150 w/ a 300 np435 combo in it. I want to make my truck move a bit faster than it is now. Thanks, Tony |
#9 |
FSB warrior
Yup they both are the same bolt pattern. Is the donor truck an 80-83 as well, cuz you have mechanical linkage in your 83 and your donor truck may not.
Using an NP-435 probably wont make your truck move faster, sure you can lift the front tires off the ground... but you gotta shift in 5 feet. I usually start in 2nd, so I only have to shift 3 times, works pretty good. The 435 is a very good tranny though. What do you have in there now??? |
#10 |
Lick my
The truck is an 81. I got a 351 C6 combo in my Bronco now. Its good and pretty tough, but I want a manual. I had an F150 a few years back almost identical to this one, just a long bed. A total POS but man did that thing RUN! Im pretty sure it was an 80 or so. I had the 300/NP435 combo in it. I could pull a house off its foundation, but it couldnt get out of its own way on the highway. I had to get rid of it because I had no gas tank (besides a 3 gallon under the hood), no interior besides one seat, no back brakes, F'ed up electrical system, and it was in total black primer. I do miss it.
#11 |
FSB warrior
Well cool then, you should have all the parts to do it. keep in mind that the 2" tab that goes from the pedal to the 20" rod that goes threw the floor is no longer made anymore, so you will probably have to weld a bead in your oval shaped one(I never found one that wasnt
) but a guy at a local pump/machine shop did it for free. |
#12 | |
no prob, I dont want to rush things either. Also can we get a compatability list for years and trannies? ![]() |
#14 | |
USAF C-17 Avionics
Adrianspeeder |
#16 |
iTrader: (3) Bronco Info: 86 Bronco 351W HO 670 truck avenger 35's 4.10's front LS rear Locked
http://raceabilene.com/kelly/hotrod/trans.html GREAT info here on C6 Tranny etc.
#17 | |
FSB warrior
#18 | |
iTrader: (0) Bronco Info: 91 302/E4OD/3.55, F-150 cab
#19 | |
FSB warrior
Oh and the 2.3 I4 is the same as a 5.0. My buddy took the T-5 out of a Turbo Coupe (T-bird) and put it behind his Mustang with a 5.0 |
#20 | |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
