| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Pulling EEC-IV codes
#1 |
Perspicuously Pernickety
![]() Join Date: Jul 2003
iTrader: (91) Bronco Info: '83 Custom w/'95 4.9L & EB paint
BEFORE POSTING IN ANY TECH WRITEUP THREAD, read this post.
![]() This is from the Ford Service CD, but I've edited & reorganized it so it's easier to follow. I deleted the info about the STAR testers since I doubt anyone has one and doesn't know how to use it. For the full code list & the abbreviated procedure, click this link. Self-Test Description The Self-Test is divided into three specialized tests: Key On Engine Off Self-Test, Engine Running Self-Test, and Continuous Self-Test. The Self-Test is not a conclusive test by itself, but is used as a part of the functional Quick-Test diagnostic procedure. The PCM stores the Self-Test program in permanent memory. When activated, Self-Test checks the EEC system by testing memory integrity and processing capability, and verifies that various sensors and actuators are connected and operating properly. Continuous Self-Test · Continuous Memory DTCs are issued as a result of information stored during Continuous Self-Test, while the vehicle was in normal operation. These DTCs are displayed only during Key On Engine Off Self-Test and after the separator pulse. Intermittent faults that have not occurred in the last 80 warm-up cycles (40 cycles on some applications) are erased from Continuous Memory and will not produce a Continuous Memory DTC. · During this mode of testing the PCM continuously monitors inputs for opens and shorts. The Continuous Memory DTCs must be retrieved within 40 (for some applications) or 80 engine temperature warm up cycles. On the 41st or 81st Engine Temperature cycle, the DTC will be automatically erased. The Continuous Memory DTCs can also be erased by deactivating Self-Test while the DTCs are being outputted. The Key On Engine Off and Engine Running Self-Tests are functional tests which only detect faults present at the time of the Self-Test. Continuous Self-Test is performed during normal vehicle operation and stores any fault information in Keep Alive Memory (KAM) for retrieval at a later time. Special Notes: · The Key On Engine Off and Engine Running Self-Tests detect faults that are present at the time of testing. Faults that occur only when the vehicle is operating or intermittent faults that have occurred in the last 80 warm-up cycles are detected during Continuous Self-Test, stored in Continuous Memory and displayed during Key On Engine Off Self-Test. · When directed to a Pinpoint Test, always read the cover page(s) for special notes and look carefully at the Pinpoint Test Schematic. · After service, rerun Quick Test to ensure that service was effective. · It may be necessary to disconnect or disassemble harness connector assemblies to do some of the inspections. Pin locations should be noted before disassembly. Visual Check 1. Inspect the air cleaner and inlet ducting. 2. Check all engine vacuum hoses for damage, leaks, cracks, blockage, proper routing, etc. 3. Check EEC system wiring harness for proper connections, bent or broken pins, corrosion, loose wires, proper routing, etc. 4. Check the Powertrain Control Module (PCM), sensors and actuators for physical damage. 5. Check the engine coolant for proper level and mixture. 6. Check the transmission fluid level and quality. 7. Make all necessary repairs before continuing with QUICK TEST. Vehicle Preparation and Equipment Hookup Vehicle Preparation 1. Perform ALL safety steps required to start and run vehicle tests - apply parking brake, put shift lever firmly in PARK position (NEUTRAL on manual transmission), block drive wheels, etc. 2. Turn off ALL electrical loads--radios, lights, A/C, heater, blower, fans, etc. Using an Analog Volt/Ohm Meter (VOM) 1. Turn the ignition key off. 2. Set the VOM on a DC voltage range to read from 0 to 15 volts. 3. Connect the VOM from the battery positive post to the Self-Test Output pin of the large Data Link Connector (DLC) (Figure 3). 4. Connect the timing light. Using the Malfunction Indicator Lamp (MIL) No special equipment hookup is required. STI is jumpered to SIG RTN at Self-Test Input (STI) connector and the Data Link Connector (DLC). This is where you can use a paperclip. ![]() Using the Message Center on Continental Applications Only No special equipment hookup is required. STI is jumpered to SIG RTN at Self-Test Input (STI) connector and the Data Link Connector (DLC). Using the Transmission Control Indicator Lamp (TCIL) on 7.3L Diesel Engines Only No special equipment hookup is required. STI is jumpered to SIG RTN at Self-Test Input (STI) connector and the Data Link Connector (DLC). Key On Engine Off Self-Test At this time, a test of the EEC system is conducted with power applied and engine at rest. To detect errors during Key On Engine Off Self-Test, the fault must be present at the time of testing. Special Notes: · Continuous Memory Diagnostic Trouble Codes (DTCs) recorded in this step will be used for diagnosis after a PASS code 11 or 111 is received in both the Key On Engine Off and the Engine Running Self-Tests. · Deviation from this procedure may cause the output of false DTCs. · On all vehicles equipped with a 4.9L ENGINE, the clutch must be depressed during the Key On Engine Off Self-Test. · On all vehicles equipped with a 7.3L DIESEL ENGINE, the throttle must be depressed (WOT) during the entire Key On Engine Off Self-Test. How To Run The Key On Engine Off Self-Test DO: · Verify that the vehicle has been properly prepared. · Start engine and run until it reaches operating temperature. · Turn engine off and wait 10 seconds. · Activate Self-Test. . . Analog VOM: Jumper STI to SIG RTN at the DLC and STI connectors. . . Malfunction Indicator Lamp (MIL): Jumper STI to SIG RTN at the DLC and STI connectors. DTCs will be flashed on the Malfunction Indicator Lamp (MIL). . . Transmission Control Indicator Lamp (TCIL) 7.3L Diesel only: Jumper STI to SIG RTN at the DLC and STI connectors. Service Codes will be flashed on the TCIL. . . Message Center (Continental Applications Only). Refer to "Self-Test with Message Center." · Place ignition key in the ON position. · For 7.3L Diesel vehicles only, depress the throttle fully, and hold for the entire test. · Record all Diagnostic Trouble Codes (DTCs) displayed. DON'T: · Depress throttle during Key On Engine Off Self-Test on gasoline engine applications. Separator Pulse A single 1/2 second separator pulse is issued 6-9 seconds after the last Key On Engine Off DTC. Then, 6-9 seconds after the single 1/2 second separator pulse, the Continuous Memory DTCs will be issued. NOTE: The separator pulse and Continuous Memory DTCs follow Key On Engine Off DTCs ONLY. Engine Running Self-Test At this time, a test of the EEC system is conducted with the engine running. The sensors are checked under actual operating conditions and at normal operating temperatures. The actuators are exercised and checked for expected results. Special Notes: · On vehicles equipped with the Brake On/Off (BOO) circuit, the brake pedal MUST be depressed and released AFTER the ID code. · On vehicles equipped with the Power Steering Pressure (PSP) switch, within 1 to 2 seconds after the ID code, the steering wheel must be turned at least one-half turn and released. · On vehicles equipped with E4OD transmission, the Transmission Control Switch (TCS) must be cycled after the ID code. · The Dynamic Response code is a single pulse (or a 10 code on the STAR Tester) that occurs 6-20 seconds after the engine running identification code. (See Code Output Format in this section.) · When/if the Dynamic Response code occurs, perform a brief wide open throttle. How To Run Engine Running Self-Test DO: · Deactivate Self-Test. · Start and run engine at 2,000 rpm for two minutes. This action warms up the HO2S. · Turn engine off, wait 10 seconds. · Activate Self-Test. · Start engine. · After the ID code, depress and release the brake pedal if appropriate. See Special Note on previous page. · After the ID code, within 1 to 2 seconds, turn the steering wheel at least one-half turn and then release it, if appropriate. See Special Notes above. · If a Dynamic Response Code occurs, perform a brief wide-open throttle (WOT). · Record all Diagnostic Trouble Codes (DTCs) displayed. DON'T: · Depress the throttle unless a Dynamic Response code is displayed. Self-Test with Analog Voltmeter DTCs will be represented by pulsing or sweeping movements of the voltmeter's needle across the dial face of the voltmeter (Figure 9). A single-digit number of three will be reported by three needle pulses (sweeps). However, a DTC is represented by a two-digit or three-digit number, such as 2-3. As a result, the DTC of 2-3 will appear on the voltmeter as two needle pulses (sweeps). After a two-second pause, the needle will pulse (sweep) three times. The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second sweep, and another six-second delay. Self-Test with Malfunction Indicator Lamp (MIL) During Self-Test, a DTC is reported by the Malfunction Indicator Lamp (MIL). It will flash the "CHECK ENGINE" or "SERVICE ENGINE SOON" light on the dash panel (Figure 10). A single-digit number of 3 will be reported by three flashes. However, a DTC is represented by two or three digits, such as 2-3 or 1-1-9. As a result, the Self-Test DTC of 2-3 will appear on the MIL as two flashes, then, after a two-second pause, the MIL will flash three times. Three-digit DTCs are flashed out similarly. The Continuous Memory DTCs are separated from the Key On Engine Off DTCs by a six-second delay, a single half-second flash, and another six-second delay. |
| Sponsored Links | |
Advertisement |
#2 |
Self-Test with Message Center (Continental Only)
1. On the Electronic Instrument Cluster (Figure 11), hold in all three buttons (Gauge Select, English Metric and Speed Alarm) at the same time. a. Key On Engine Off Self-Test: While holding in all three buttons, place ignition switch in the ON position. Release buttons. b. Key On Engine Running Self-Test: While holding in all three buttons, start engine. Release buttons. 2. Press the Gauge Select button three times, until cluster mode "dEALEr 4" is displayed. 3. To initiate Self-Test, jumper STI to SIG RTN at the DLC and STI connectors. 4. DTC output will be displayed on the message center. 5. To exit Self-Test, turn ignition switch to OFF and remove jumper. Self-Test with Transmission Control Indicator Lamp (TCIL) The TCIL serves a dual purpose on the 7.3L Diesel vehicle with E40D transmissions. · The light stays OFF when the Transmission Control Switch (TCS) is toggled once on the instrument panel--indicating the vehicle can attain the overdrive gear position. · The light stays ON when the Transmission Control Switch (TCS) is toggled again on the instrument panel--indicating the vehicle is prevented from shifting into the overdrive gear position. If the light flashes, perform Key On Engine Off Self-Test. The light under this condition serves as a Transmission Malfunction Indicator Lamp. Refer to "Self-Test with Malfunction Indicator Lamp (MIL)" to perform Self-Test. Code Output Format The EEC system communicates service information through the Diagnostic Trouble Codes (DTCs). These DTCs are two-digit or three-digit numbers representing the results of Self-Test. The DTCs are transmitted on the Self-Test Output (STO) circuit found in the Data Link Connector (DLC). They are in the form of timed pulses, and are read by the technician on a voltmeter, STAR tester, Malfunction Indicator Lamp (MIL), Transmission Control Indicator Lamp (TCIL) or on the Continental message center. Fast DTCs/Slow DTCs Fast DTCs are issued before slow service DTCs. These DTCs contain the identical information as the slow DTCs, but are transmitted at 100 times the normal rate. These DTCs are interpreted by special equipment at the end of the assembly line by the Body and Assembly Division, as well as the SUPER STAR II tester. After Fast DTCs have been output, Self-Test should not be exited (remove jumper, unlatch button, etc.) until all the Slow DTCs have been output. Exiting before slow DTCs have been output will erase any Continuous Memory DTCs. Some meters in service detect these codes as a short burst of information (slight meter deflection). Engine Identification Codes (ID Codes) Engine ID codes are issued at the beginning of the Engine Running Self-Test and are one-digit numbers represented by the number of pulses sent out. For gasoline engines, the engine ID code is equal to one-half the number of engine cylinders (i.e. 2 pulses = 4 cylinders). For the 7.3L Diesel engine, the ID code = 5. These codes are used to verify the proper PCM is installed and that the Self-Test has been entered. Dynamic Response Check The dynamic response check is used on some applications to verify operation of the TP, MAF, MAP and KS sensors during the brief Wide-Open Throttle (WOT) performed during the Engine Running Self-Test. The signal for the operator to perform the brief WOT is a single pulse or 10 code on the STAR Tester. Power Steering Pressure (PSP) Switch Test On vehicles equipped with Power Steering Pressure (PSP) switch, the steering wheel must be turned one-half turn and released AFTER the ID Code has been displayed. This tests the ability of the EEC system to detect a change of state in the PSP switch. Brake On/Off Test On vehicles equipped with Brake On/Off (BOO) input, the brake pedal MUST be depressed and released AFTER the ID Code has been displayed. This tests the ability of the EEC system to detect a change of state in the Brake Lamp Switch. Transmission Control Switch (TCS) Test On vehicles equipped with TCS, the switch must be cycled after the ID code has been displayed. This tests the ability of the EEC system to detect a change of state in the TCS. Adaptive Fuel Self-Test Adaptive fuel logic is used in fuel injection systems primarily to account for normal variability in fuel system components. When the fuel system is detected to be biased rich or lean during steady state vehicle operation, Adaptive Fuel will make a corresponding shift in the fuel delivery calculations so an unbiased condition will exist. The adaptive fuel "shift" is stored in Keep Alive Memory (KAM), which is powered by the vehicle battery. This prevents Adaptive Fuel from being lost when the vehicle is turned off. MAF/TP/Injector Pulse Width In-Range Self-Test The In-Range Self-Test was designed to detect in-range failures of the MAF/TP or fuel delivery systems. The PCM will use information from these three systems to generate three independent values. The three independent values will be continuously monitored. If one of the values differ significantly from the others during normal vehicle operation, a Continuous Memory DTC 121, 124, 125, 184, 185, 186 or 187 will be displayed. ************************************* 11 orc System PASS 12 r Cannot control rpm during Self-Test high rpm check 13 r Cannot control rpm during Self-Test low rpm check 14 c PIP circuit failure 15 o EEC processor Read Only Memory (ROM) test failed 15 c EEC processor Keep Alive Memory (KAM) test failed 18 r SPOUT circuit open 18 c Loss of IDM input to processor/SPOUT circuit grounded 19 o Failure in EEC processor internal voltage 21 or Engine Cooling Temperature (ECT) sensor out of Self-Test range 22 orc Manifold Absolute Pressure (MAP) sensor out of Self-Test range 23 orc Throttle Position (TP) sensor out of Self-Test range 24 or Air Charge Temperature (ACT) sensor out of Self-Test range 25 r Knock not sensed during Dynamic Response Test 29 c Insufficient input from Progammable Speedometer/Odometer Module (PSOM) 31 orc EVP circuit below minimum voltage 32 orc EVP voltage below closed limit 33 rc EGR valve opening not detected 34 orc EVP voltage above closed limit 35 orc EVP circuit above maximum voltage 41 r HEGO sensor circuit indicates system lean 41 c No HEGO switching detected 42 r HEGO sensor circuit indicates system rich 44 r Thermactor air system inoperative 45 r Thermactor air upstream during Self-Test 46 r Thermactor air not bypassed during Self-Test 51 oc ECT indicated -40øC (-40øF)/circuit open 52 o Power Steering Pressirue Switch (PSPS) circuit open 52 r PSPS circuit did not change states 53 oc TP above maximum voltage 54 oc ACT indicated -40øC (-40øF)/circuit open 61 oc ECT indicated 123øC (254øF)/circuit grounded 63 oc TP circuit below minimum voltage 64 oc ACT indicated 123øC (254øF)/circuit grounded 67 o Neutral Drive Switch (NDS) circuit open; A/C ON (Manual) 72 r Insufficient MAP change during Dynamic Response Test 73 r Insufficient TP change during Dynamic Response Test 74 rc Brake On/Off (BOO) circuit openÄnot actuated during Self-Test 77 r Operator error Dynamic Response Test 81 o Air Management 2 (AM2) circuit failure 82 o Air Management 1 (AM1) circuit failure 84 o EGR Vacuum Regulator (EVR) circuit failure 85 o Canister Purge (CANP) circuit failure 87 oc Primary fuel pump circuit failure 95 oc Fuel Pump circuit open - EEC processor to motor ground 96 oc Fuel Pump circuit open - battery to EEC processor 98 r Hard fault present 111 : System pass 112 : Intake Air Temp (IAT) sensor circuit low voltage/ 254°F indicated 113 : Intake Air Temp (IAT) sensor circuit high voltage/ -40°F indicated 114 : Intake Air Temp (IAT) sensor circuit voltage high or low 116 : Engine Coolant Temp (ECT) sensor circuit voltage high or low 117 : Engine Coolant Temp (ECT) sensor circuit low voltage/254°F indicated 118 : Engine Coolant Temp (ECT) sensor circuit high voltage/ -40°F indicated 121 : Closed throttle voltage high or low 122 : Throttle Position (TP) sensor circuit low voltage 123 : Throttle Position (TP) sensor circuit high voltage 126 : MAP sensor circuit voltage high or low 128 : MAP sensor vacuum hose damaged/disconnected 129 : Insufficient MAP change during dynamic response test KOER 167 : Insufficient throttle position change during dynamic response test KOER 171 : Fuel system at adaptive limits 172 : System indicates lean 173 : System indicates rich 179 : Fuel system at lean adaptive limit at part throttle, system rich 181 : Fuel system at rich adaptive limit at part throttle, system lean 211 : Profile Ignition Pickup (PIP) circuit failure 212 : Loss of Ignition Diagnostic Monitor (IDM) input to PCM/SPOUT circuit grounded 213 : SPOUT circuit open 312 : Secondary Air Injection (AIR) misdirected during KOER 313 : Secondary Air Injection (AIR) not bypassed during KOER 327 : EGR (EVP) circuit low voltage 328 : EGR (EVP) closed valve voltage lower than expected 332 : Insufficient EGR flow detected 334 : EGR (EVP) closed valve voltage higher than expected 337 : EGR (EVP) circuit high voltage 411 : Cannot control RPM during KOER low RPM check 412 : Cannot control RPM during KOER high RPM check 452 : Insufficient input from Vehicle Speed Sensor (VSS) to PCM 511 : PCM Read Only Memory (ROM) test failure KOEO 512 : PCM Keep Alive Memory (KAM) test failure 513 : PCM internal voltage failure (KOEO) 522 : Vehicle not in PARK or NEUTRAL during KOEO 536 : Brake On/Off (BOO) circuit failure/not actuated during KOER 538 : Insufficient RPM change during KOER dynamic response test 539 : A/C or Defrost on during KOEO 542 : Fuel pump circuit open; PCM to motor ground 543 : Fuel pump circuit open; battery to Powertrain Control Module (PCM) 552 : Secondary Air Injection Bypass (AIRB) circuit failure KOEO 553 : Secondary Air Injection Diverter (AIRD) circuit failure KOEO 556 : Fuel pump relay primary circuit failure 558 : EGR Vacuum Regulator (EVR) circuit failure 565 : EVAP Canister Purge circuit failure KOEO 569 : Auxiliary EVAP Canister Purge circuit failure 617 : 1-2 shift error 618 : 2-3 shift error 619 : 3-4 shift error 621 : Shift Solenoid 1 (SS1) circuit failure KOEO 622 : Shift Solenoid 2 (SS2) circuit failure KOEO 624 : Electronic Pressure Control (EPC) circuit failure 625 : Electronic Pressure Control (EPC) driver open in PCM 626 : Coast Clutch Solenoid (CCS) circuit failure KOEO 628 : Excessive converter clutch slippage 629 : Torque Converter Clutch (TCC) solenoid circuit failure 631 : Transmission Control Indicator Lamp (TCIL) circuit failure KOEO 632 : Transmission Control Switch (TCS) circuit did not change states during KOER 633 : 4x4L (Low) switch closed during KOEO 634 : Transmission Range (TR) voltage high or low 636 : Transmission Fluid Temp (TFT) high or low 637 : Transmission Fluid Temp (TFT) sensor circuit high voltage/-40°F indicated 638 : Transmission Fluid Temp (TFT) sensor circuit low voltage/290°F indicated 654 : Transmission Range (TR) sensor indicating not in PARK during Self -Test 691 : 4x4 Low Circuit Failure 998 : Hard fault present FMEM MODE For the full code list & abbreviated procedure, look here. |
#3 |
Diagnostic Aids
Continuous Monitor Diagnostic Test Mode (Wiggle Test) Special Note: The technician can ATTEMPT to re-create and detect an intermittent fault using the Continuous Monitor DTM (Wiggle Test) procedures. Key On Engine Off Wiggle Test Procedure 1. Hook up a STAR Tester, VOM or Scan Tool. 2. Turn the ignition key to the ON position. 3. For STAR Tester or VOM, activate, deactivate and reactivate Self-Test. You are now in the Continuous Monitor Diagnostic Test Mode (DTM). For Scan Tool, enter DTM, then enter wiggle DTM. 4. Tap, move, and wiggle the suspect sensor and/or harness. When a fault is detected, a Continuous Memory DTC will be stored in memory. This will be indicated as follows depending on the type of equipment being used: * STAR Tester: Red LED lights and/or continuous tone. * Malfunction Indicator Lamp (MIL): Lights * VOM: Needle Sweep * Transmission Control Indicator Lamp (TCIL) * Scan Tool: Continuous Tone Engine Running Wiggle Test Procedure Special Note: The Engine Running Wiggle Test may be activated any time the engine is running. 1. Hook up a STAR Tester, VOM or Scan Tool. 2. Key off. 3. Start the engine. 4. For STAR Tester or VOM, activate Self-Test, deactivate and reactivate Self-Test. DO NOT shut the engine off. You are now in the Engine Running Continuous Monitor DTM. For Scan Tool, enter DTM, then enter wiggle DTM. 5. Tap, move, and wiggle the suspect sensor and/or harness or drive the vehicle. When a fault is detected, a Continuous Memory DTC will be stored in memory. This will be indicated as follows depending on the type of equipment being used: * STAR Tester: Red LED lights and/or continuous tone. * Malfunction Indicator Lamp (MIL): Lights * VOM: Needle Sweep * Transmission Control Indicator Lamp (TCIL) * Scan Tool: Beeps How to Clear the Continuous Memory NOTE: Do not disconnect battery to clear Continuous Memory. This will erase the Keep Alive Memory (KAM) information which may cause a driveability concern. 1. Run the Key On Engine Off Self-Test. 2. When the DTC's begin to be displayed, deactivate Self-Test: -- STAR Tester: Unlatching the center button (up position). -- All others: Remove the jumper wire from between Self-Test Input (STI) connector and the Signal Return Pin of the DLC. -- Scan Tool: Pushing the STOP button. 3. Continuous Memory will be erased in the PCM. How to Clear Keep Alive Memory (KAM) The PCM stores information about vehicle operating conditions and uses this information to compensate for component tolerances. When an emission related component is replaced, Keep Alive Memory (KAM) should be cleared to erase the information stored by the PCM from the original component. To clear KAM: Disconnect the negative side of the battery for a minimum of five minutes. After KAM has been cleared, the vehicle may exhibit certain driveability concerns. It will be necessary to drive the vehicle 10 miles or more to allow the processor to relearn values for optimum driveability and performance. (Distance is dependent on the vehicle application.) Output State Diagnostic Test Mode (DTM) The Output State DTM aids in servicing output actuators associated with the EEC system. It enables the technician to energize and de-energize most of the system output actuators on command. This DTM is entered after all DTC's have been received from Key On Engine Off and Continuous Testing. At this time, leave Self-Test activated and depress the throttle. Each time the throttle is depressed the output actuators will change state from energized to de-energized or from de-energized to energized. 1. Enter Self-Test. 2. DTC Output Ends. 3. Do Brief WOT. 4. EEC Output To Actuators Energized. 5. Do Brief WOT. 6. EEC Output To Actuators De-Energized. 7. For vehicles with LFC and HFC circuits: To cycle the LFC and HFC outputs after code output ends, depress and hold throttle. For LFC, wait until the MIL flashes once (10 seconds). For HFC, wait until MIL flashes twice (15 seconds). Release throttle. The LFC or HFC output is now on (to cycle output off, depress and release throttle). Cylinder Balance DTM--SFI Engines Only The purpose of the cylinder balance test is to assist the mechanic in finding a weak or non-contributing cylinder. The test is entered by depressing and releasing the throttle within two minutes after the Engine Running Self-Test DTC's have been output. Once the test is entered, the IAC duty cycle is fixed and the engine is allowed to stabilize. Engine rpm is measured and stored for later use. Next, the fuel is shut off to cylinder number 4, 6 or 8, depending on engine. After a brief stabilization period the engine rpm is again measured and stored. The injector is turned on again and the process is repeated for each of the injectors down to one. At this point, the maximum rpm drop that occurred is selected from the table of rpm drops for each cylinder. This maximum rpm drop is now multiplied by a calibratable percentage. The resulting number (rpm) is now used as the minimum rpm that each cylinder must have dropped to pass this test. Example: 150 rpm x 65% = 98 rpm If all cylinders drop at least this amount, then a code 90 is output indicating a pass. No further testing is necessary. If a cylinder did not drop at least this amount, then the cylinder number would be output. For example, 30 for cylinder number 3. This indicates that cylinder number 3 is either weak or non-contributing. The test can now be repeated a second time if the throttle is depressed and released within two minutes of the last code output. This time the maximum rpm drop that occurs is multiplied by a lower percentage. This number is now used as the minimum rpm drop for each cylinder to pass this test. Example: 150 rpm x 43% = 65 rpm If all the rpm drops are greater than 65 rpm, then a code 90 is output. If cylinder number 3 had failed the first level and passed the second, then cylinder number 3 is considered to be weak. If cylinder number 3 again failed, the code 30 would be output again. The test can be repeated a third time by depressing and releasing the throttle within two minutes of the last code output. This time the maximum rpm drop that results is multiplied by a still lower percentage. This number is now used as the minimum rpm drop for each cylinder to pass this test. Example: 150 rpm x 20% = 30 rpm If all the rpm drops are greater than 30 rpm then a code 90 is output. If cylinder number 3 had failed the first and second level, but passed the third, then it is considered to be a very weak cylinder. If cylinder number 3 failed the third level then a code 30 would again be output. In this case, cylinder number three would be considered a non-contributing cylinder. The Cylinder Balance DTM may still be repeated as many times as desired by depressing and releasing the throttle within two minutes of the last code output. All further testing (i.e. 4th, 5th pass) will be done using the third level percentage. Failure Mode Effects Management (FMEM) FMEM is an alternate system strategy in the PCM designed to maintain vehicle operation should one or more sensor inputs fail. When a sensor input is perceived to be out-of-limits by the PCM, an alternative strategy will be initiated. The PCM will substitute a fixed in-limit sensor value and will continue to monitor the faulty sensor input. If the faulty sensor operates within limits, the PCM will return to the normal engine running strategy. Engine Running DTC 98 or 998 will be displayed when FMEM is in effect. The Malfunction Indicator Lamp (MIL)/Message will remain on when FMEM is in effect. Malfunction Indicator Lamp (MIL)--All Applications Except Continental The Malfunction Indicator Lamp (MIL) is intended to alert the driver of certain malfunctions in the EEC-IV system. The MIL is a light in the dash that reads either "CHECK ENGINE" or "SERVICE ENGINE SOON." If the light is on, the driver of the vehicle should take the car in for service as soon as possible. NOTE: It is not necessary to immediately turn the engine off and have the vehicle towed when the MIL comes on. The MIL will come on while the engine is operating in Failure Mode Effects Management (FMEM) or Hardware Limited Operation Strategy (HLOS) modes. The light will stay on for at least 10 seconds, then stay on as long as the fault causing it is present. If the MIL flashes quickly (less than 10 seconds) the MIL circuit should be checked for concerns. Refer to «Quick Test». In FMEM mode, the PCM is receiving a sensor signal that is outside the limits set by the calibration strategy. In this mode the PCM uses an alternate engine control strategy to maintain reasonable vehicle operation in spite of the fault. The DTC associated with this fault is stored in Keep Alive Memory (KAM). If the fault is no longer present, the light will turn off and the vehicle will return to the normal vehicle strategy. The DTC stored when the light was on is kept in Continuous Memory for the next 80 warm-up cycles (40 cycles on some applications) and then erased. This DTC is one of the Continuous Memory and it can be accessed by running the Key On Engine Off Self-Test. HLOS mode is used when the system fault(s) is too extreme for the FMEM mode to handle. In HLOS mode, all software operations have stopped and the PCM is running on hardware control only. The default strategy for this mode has a minimal calibration strictly to allow the vehicle to operate until it can be serviced. NOTE: In HLOS mode Self-Test DTC's will not be output. How the Malfunction Indicator Lamp (MIL) Operates System OK The Malfunction Indicator Lamp (MIL) is turned on as a bulb check when the ignition key is first turned on. The EEC-IV processor turns the bulb off as soon as it receives the PIP (cranking) signal. System Not OK If the Malfunction Indicator Lamp (MIL) should remain on after the vehicle has started, run Quick Test and has had service any DTC's. If Self-Test has pass DTC's, the (MIL) is always on, and the vehicle has no drive symptoms, go to «Section 2A». If the MIL never comes on, go to «Section 2A». If the vehicle is a no start, go to Pinpoint Test Step «AA1», «AB1», or «AC1». NOTE: When in Self-Test the MIL is not limited to Continuous Memory Codes and will also flash other DTC's. Also, Continuous Memory Codes are erased from Continuous Memory if the original fault has not occurred in the last 80 warm-up cycles (40 cycles on some applications). |
#4 |
iTrader: (0) Bronco Info: 1991 Eddie Bauer, 351, E4OD, 3.55 8.8" limited slip rear.
Ok, how do I know if I need to do any of the things listed in the special notes section? (other than the e4od, I know I have that) Just trying to figure out how to do the tests so I dont have to keep asking questions. Thanks
Paul The Dune Project 91 Eddie Bauer 351 cid 140000+miles E4OD 8.8" 3.55 Limited slip rear 33 x 12.50 x 15 |
#5 |
![]() Join Date: Apr 2005
iTrader: (0) Bronco Info: 1994 351 V8 Automatic
I was looking around for learning how to pull codes on my bronco and I know this is the best thread for doing this. It probably makes perfect sense to most people but if you ate a lot of paintchips as a child AND fell on your head several times then maybe this website will help out too: http://fordfuelinjection.com/?p=13
And if I'm not mistaken there are 3 different ways of doing this: 1. sit in your truck and count check engine lights after you set proper jumpers 2. use a digital volt meter, analog volt meter or simply a test light, or 3. use one of 'em fancy shmancy code readers out there randing from $10-$50, for example: Equus Digital Code Reader |
#6 |
ISSUE: Occasionally, there are reports of the Malfunction Indicator Lamp (MIL) "Check Engine" Lamp (CEL) or "Service Engine Soon" (SES) lamp being lit with no Self-Test codes in Continuous Memory. An explanation of three digit EEC IV Self-Test Codes has been developed along with reasons for the MIL lamp being lit with no accompanying Continuous Memory Self-Test codes.
ACTION: Refer to the following explanation of three digit EEC IV Self Test Codes to determine why the MIL lamp is sometimes lit with no accompanying Continuous Memory Self-Test codes. OVERVIEW OF THREE DIGIT EEC IV SELF-TEST CODES Ford went from two digit to three digit EEC IV Self-Test codes in 1991 to service the increasing number of service codes required to support various government On-Board Diagnostic (OBD) regulations. The phase-in from two digit to three digit codes started in the 1991 model year and is largely complete except for some medium/heavy trucks that will retain two digit codes through the 1994 model year. MIL LAMP ACTIVATION Following is a list of reasons why a technician may see the MIL lamp lit with no accompanying Continuous Memory Self-Test codes. 1) Technician Not Familiar With Self-Test Code Output There are two types of EEC Self-Tests, Key On Engine Off (KOEO) and Key On Engine Running (KOER). While both of these will test for various "hard faults" that are present when the test is run, the processor continuously monitors various operating parameters whenever the engine is running. If the processor detects a problem, it will store a "Continuous Memory" code and light the MIL. These Continuous Memory codes are put out during KOEO Self-Test after any codes associated with hard faults are output. Self-Test Codes are displayed by flashing the MIL. They are also output as voltage pulses on the Self-Test Output (STO) circuit in the Self-Test connector. In either Self-Test mode, all codes are output twice and in KOEO, the hard fault codes are separated from the Continuous Memory codes by a "separator" pulse. A technician that is unfamiliar with the EEC Self-Test can mistakenly believe that continuous Memory codes are not present when they really are. He may run KOER Self-Test and get a pass code (lll) and not realize that KOEO Self-Test must be run to receive any Continuous Memory codes. He may run KOEO Self-Test while counting MIL flashes and misinterpret the repeated hard fault pass code (lll) to mean that Continuous Memory does not contain any codes. 2) Inadvertent Erasure Of Continuous Memory Self-Test Codes Continuous Memory Self-Test codes are erased by ungrounding STI before KOEO Self-Test is complete and all KOEO and Continuous Memory codes have been displayed. It is possible to inadvertently erase Continuous Memory codes by ungrounding STI without realizing that KOEO Self-Test is not complete or the processor has not finished displaying all the codes. The EEC Self-Test codes are not only used by service technicians, they are used as a final system test in the assembly plants. To make this test as efficient as possible, Self-Test codes are output as a very fast, short pulsewidth signal before the codes are displayed by the flashing MIL. These "FAST" codes can only be interpreted by end-of-line equipment or code-reading testers like Ford's Self-Test Automatic Readout (STAR) testers. The EEC IV processor puts out both 2-digit and 3-digit Self-Test codes in both formats, "FAST" pulsewidth mode and "SLOW" pulsewidth mode. While all "STAR" type testers display 2-digit codes, the original STAR tester cannot display 3-digit service codes. If the STAR tester is used on 3-digit service code applications, the display will be blank but the tester will beep. The beeps can be counted to determine service codes. The SUPER STAR II tester will only display 3-digit service codes in "FAST" code mode. If slow code mode is used on 3-digit service code applications, the display will be blank but the tester will beep. The beeps can be counted to determine service codes. For more information on running Self-Test, refer to the "EEC IV Quick Test Procedures and Appendix" section of the Powertrain Control/Emissions Diagnosis Service Manual. Since certain STAR testers are capable of reading and displaying fast codes before the slow codes are finished being output on the MIL, a technician can assume that since he sees codes displayed, he can unground STI and move on. If he ungrounds STI before all slow codes are output, Continuous Memory will be erased and could put out a pass code (ll/lll) the next time KOEO Self-Test is run. The technician may also realize that his tester is in "SLOW" mode after he has initiated the KOEO test and stop the test to change tester settings. Another possibility is that another person, a vehicle owner or another technician, could have erased the codes before the technician reporting the situation has run Self-Test. In any of these situations, the vehicle must be driven until the Continuous Memory codes are reset. 3) The Concern That Set The Continuous Memory Code Is No Longer Present The EEC processor will erase a Continuous Memory code if the concern that caused it has not been present for 40 or 80 warm-up cycles, depending on the vehicle. A warm-up cycle occurs when the vehicle is started with the coolant temperature below 120° F (49° C) and then shutdown with the coolant temperature above 150° F (66° C). If a vehicle is brought in for service with a MIL complaint and the vehicle is driven or otherwise allowed to warm-up before Self-Test is run, the code may be cleared before the technician tests it. 4) Grounded STO/MIL Circuit The processor controls the MIL by grounding the STO/MIL circuit (Pin 17). If this circuit shorts to ground, whether the processor is controlling it or not, the MIL will be lit. Starting in 1991, if the processor has lit the MIL, it will hold it on for a minimum of 10 seconds. If the MIL flashes quickly, the concern is probably the STO/MIL circuit shorting intermittently to ground. 5) Engine Running In HLOS The EEC processor will enter Hardware Limited Operation Strategy (HLOS) if it detects a problem that could cause further damage to the system. Under HLOS, the processor modifies its operating strategy so that certain functions are disabled but the vehicle can be safely driven in for service. If the vehicle is in HLOS, Continuous Memory codes will not be set and Self-Test cannot be initiated. However, Continuous codes that were set before the processor entered HLOS will be retained. 6) Misinterpretation Of MIL Bulb Check The MIL will light as a bulb check if the key is on and the engine is not running. If the engine is running and stalls or stops for any reason with the key on, the MIL will be lit and no Continuous Memory codes will be set. When the key is first turned on, the MIL will stay lit briefly after the engine is started as part of the bulb check feature. 7) MIL Flashes During Self-Test The circuit that controls the MIL is also the Self-Test Output (STO) circuit that goes to the Self-Test connector. The MIL will flash during Self-Test as the STO circuit is cycled on and off. This is normal and no Continuous codes are set. 8) Processor KAM Is Erased Or Fails The Keep Alive Memory (KAM) within the processor must always have voltage supplied to it. This voltage is supplied by the Keep Alive Power (KAPWR) circuit (Pin 1) that connects directly to the battery. KAM contains adaptive parameter tables that allow the processor to adapt to different operating requirements. It also contains the Continuous Memory codes. Continuous Memory codes will be erased any time KAPWR is disconnected (i.e. battery disconnected, processor disconnected, breakout box installed, open in the wire, etc.). If KAM fails within the processor, all Continuous codes will also be erased. 9) Damaged STAR Tester A damaged STAR tester can produce erroneous code output or accidentally erase Continuous Memory. 10) KOEO Processor RAM Test Failed The processor's Random Access Memory (RAM) is tested during KOEO Self-Test. If the processor's RAM has failed, the MIL will light and no codes are output. 11) Intermittent VSS Fault Detected In Wiggle Mode If in wiggle mode (STI grounded) and an intermittent Vehicle Speed Sensor (VSS) fault is detected, the MIL can be lit momentarily. If the VSS signal returns to normal, the associated code is erased. In normal operation, the VSS will not light the MIL. 12) IDM Pulsewidth Not Recognized By Processor (EDIS Vehicles) EDIS vehicles can have the MIL on with no Continuous codes if the processor does not recognize the Ignition Diagnostic Monitor (IDM) pulsewidth. In this case, coil pack failure codes may not be set since the fault filters can be erased before they reach the threshold that sets the code. 13) Intermittent Ignition System Fault Vehicles with a Cylinder Identification (CID) sensor can light the MIL with no Continuous codes present if an intermittent ignition system fault is present long enough to activate the MIL and then goes away. The CID sensor can indicate that the fault was momentary and clear the coil pack faults but the CID fault may not register if the fault goes away fast enough. 14) Intermittent Open STI Circuit If the Self-Test Input (STI) circuit opened during KOEO Self-Test or code output, Continuous Memory would be cleared. 15) Power Lost To EEC Processor On some applications, the processor can lose power while the MIL stays powered. The MIL can light if a ground path is present through the processor. 16) Other Warning Lamps Mistaken For MIL The MIL can sometimes be confused with other warning lamps like the amber Air Bag lamp if they are located near each other in the dash panel. 17) Development Testing Or Wrong Processor Released To Production The MIL can be lit without Continuous codes during testing or if the wrong processor is installed. |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
