| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Help with VSS
#21 |
A beer and a gun
Ask for the ABS sensor. I dunno if they'll have it, but if they don't, it's less than $20 from the dealer. I think I paid about $12 for mine.
You can lead a horse to water, but it's easier to just shoot him. '92 Bronco XLT 351W '68 F100 Custom Cab Stepside 390 '04 Nissan Titan LE crew cab 5.6L--wife's toy '98 Volvo V70--daily driver |
| Sponsored Links | |
Advertisement |
#22 | |
Stuck in the 70's & 80's
![]() Join Date: Jun 2003
iTrader: (11) Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
F85Z-2L373-AC The parts guys at ford will likely refer to this as the rear diff. ABS sensor. Though we all now know it actually serves ABS and VSS requirements.
______________________ http://www.supermotors.net/registry/628 "TheJuice...yes, that was my name. I come back to you now at the turn of the second decade...my name is Shadofax" |
#23 | |||
iTrader: (91) Bronco Info: '83 Custom w/'95 4.9L & EB paint
Those are the names Ford used back when they were building these trucks. Current documentation probably varies widely. |
#24 |
Taking Advantage
Steve sometimes you just get too technical.
#25 | |
Zombie Hunter
![]() ![]() Join Date: Jan 2005
iTrader: (12) Bronco Info: 1993 Eddie Bauer, 351, 5.8 liter V8, somebody come help me put all this junk i just bought on!!
#26 | ||
OK steve, I forgot about that electrical plug for the cruise....my mistake. I had tunnel vision on that. I agree on calling it the same thing, I was just trying to mention what my book said. I hate how they use different names for the same thing too.
The gears your worring about, are on the cable operated speedo setup pictured previously in this thread. You don't have that because you have a 93'. It does help control how the tranny shifts, because part of the information the tranny needs, is vehicle speed. |
#27 | |
#28 |
Zombie Hunter
Sweet!
This sensor also has something to do with the 4lo option too IIRC. Going to order mine up. Thanks for the help guys i apprecaite it, going to change the diffy fluid while i am at it.... |
#29 |
Rob
You're confusing them again. Your '93 doesn't have a VSS (in the t-case with plastic gears). It ONLY has an ABS (in the rear diff). The ABS has almost nothing to do with 4L. As you can see from these EVTM diagrams, the t-case OSS is integrated into the t-case wiring harness, in the lower R corner. |
#30 |
Zombie Hunter
Thats not my biggest worry right now, i will troubleshoot the 4 low soon, i think i know where the problem is in that. I got 4hi so i am happy. My biggest worry is that i have a sporratic hard shift, and the tranny seems to hesitate to shift when i get on the highway. I am going to post (start a new thread) on it, along with a few other things, i will ask about the OSS sensor there. |
#31 |
Steve, I duno, I think you're confusing him by saying it's just an ABS sensor. On his truck, I believe the transfer case gets the signal from that sensor (because there isn't any other sensor for speed), and it will affect automatic tranny shifts, as well as the speed limiter. I think I'm going to have to sit the rest of this one out and let ya'll work it out. :)
#32 |
Rob
Don't worry about the OSS - concentrate on the ABS sensor. If it's OK, then you probably have internal transmission problems. :( MustangGT221 I'm not saying it's "just an ABS sensor" - I'm saying it's CALLED an ABS sensor, and it's the only thing on his truck that senses speed (for the speedo, EEC, trans, ABS, & cruise). He has no VSS. The t-case has its own internal OSS that's used ONLY for t-case shifting. |
#33 |
Depending on the year(1992 +) it's called a RABS sensor,a DSS(diff speed sensor),Rear axle sensor.At work (Ford dealership),we ask for a rear diff speed sensor.If we want the one on the transmission or transfercase(1991 and older),we ask for the vehicle speed sensor at the trans or tranfercase.In 1993 the sensor is called a DSS,most commonly known as the RABS(rear ABS sensor)because the signal it generates goes to the ABS module first(where the signal is altered to a form that the PSOM will understand)then to the PSOM and what ever else requires a speed signal.
#34 | |
#35 |
I figured there wern't alot of pics of this on here, and I just did it tonight, so here ya go.
![]() this is with the old one out and the new one in. ![]() The other night, it started to shift way late and jolt really bad. Speedo and odometer stopped working and the overdrive "off" light on the shift lever started blinking. I tried just taking the sensor out and cleaning it off. That didn't work so a quick run down to the parts store and $15 later, back to normal. ![]()
Broncodell- 1995 bronco 302- 31" Mastercraft Courser CT's MSD Coil, Cap/rotor, Taylor Spiropro wires, Cheepo Motorcraft plugs, Summit Shorty headers, custom y-pipe to thrush glasspack w/ dump before rear axle |
#36 |
Ask for one, if they tell you it doesn't exist, or the one they bring does not match the one that you pulled from your diff and have in your hand, ask for the other. I have personally asked for and purchased a VSS for a '93 F150 at autozone, it was the proper sensor for the rear diff. Whether it is used to for ABS, cruise, or speedo output, really makes no difference to the sensor, and IMO should not change it's name. After all, whether it is being used for any of the above reasons, it is still measuring rotational speed. The sensors typically send a square wave DC or AC sine wave signal. The electronics interpreting the signal count the "pulses", i.e. how many times the voltage passes the 0 volt threshold, and interprets that as a certain speed that has a direct relationship to the number of teeth on the relucter ring (variable reluctance sensor, what the VSS in question is), number of magnets on a flying magnet wheel (hall effect), and number of shutters in a optical wheel (optical sensor).
To muddy the waters even more. all of these types of sensors can be used to determine exactly where something is in a rotation by removing one or more teeth from the reluctor, closing one or more shutter in a optical wheel, and removing one or more magnets in a flying magnet wheel. This is how newer ecm's get their crank and cam position signals. Anyhow, the basic principles are all the same, and they are all used for measuring rotational speed. What the dealer or auto parts store wants to call them is another story all together though... As for the T-case VSS, the one on my '89 bronco w/ electric shift BK1356 was used for the 4x4 shift computer, and was a different critter all together. It was driven like a normal speedo, with set of speedo gears, and had what looked like a small motor with a wiring harness instead of a cable... I always wondered why ford had to have 3 speed sensing devices in those trucks...
Jason Campbell 2006 Bigblockbuggy: EFI 460/C6/AtlasII 5.0 comp case, D60's locked, full hydro, 42" TSLs on recenterd hummer lock 1988 EB Bronco project starting this winter, EFI 460, NP435/BW1356/205doubler, Hybrid D60 front, Sterling 10.25 rear, 33-35" tire or so. |
#37 |
Never Done
wheel speed sensor, where is this located. would it possibly cause the abs light to stay on and the speedometer to not function? I have already changed out the rear sensor on top of the diff
94 XLT 5.8/E4OD Trans-go stage II 6" Stage II ProComp,35x12.50BFG/MT 4.88 f (aussie) / r (open) / Custom Sliders JBA headers,Custom Y pipe hi flow cat & Full 3" http://www.supermotors.net/vehicles/registry/17069 |
#38 |
in addition to the rear sensor there are 2 sensors at each front wheel. but, I don't think these would have anything to do with the speedo. Are you sure everything is ok with the new rear sensor? have you opened the rear diff cover to inspect the toner ring?
#39 |
Never Done
no i have not inspected the tone ring yet. that is next on the list
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
