Go Back   FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
Thread Tools Display Modes
Old 04-07-2005, 04:15 PM   #1
89bronc
Power Steering Box
does anyone know what year power steering box i can put in my 79 bronco?
89bronc is offline   Reply With Quote
Old 04-07-2005, 04:47 PM   #2
axaviere
scrounger extrordinaire
axaviere's Avatar
Bronco Info: 79 460 6" coming soon...39.5s, D60/D60 ARB/Detroit w/ 4.88s
is this a trick question? 78-79 f150 or bronco
take a look at TRUCK my 79 custom. 6" front, 4" rear, 460, 37s, 8 lug conversion. F&R discs. this season, i will have the D60/D60 installed, rear detroit and front ARB with 4.88s and 39.5 IROKs on hummer double bealocks, hydro assist and crossover steering
axaviere is offline   Reply With Quote
Old 04-07-2005, 06:33 PM   #3
89bronc
i wasnt sure if a newer one would work or not
Old 04-07-2005, 06:56 PM   #4
axaviere
axaviere's Avatar
newer years had the box inside the frame i think. ours go outside the frame
Old 04-07-2005, 09:30 PM   #5
Spookshow ONE
Bronco Info: 1979 XLT MADE IT 7513 MILES HA!
Frames were wider on the 1980's and up. Ax is right.
The only fish that go with the flow, are the dead ones.
Spookshow ONE is offline   Reply With Quote
Old 04-07-2005, 09:40 PM   #6
jopes
balls deep with my
jopes's Avatar
Bronco Info: pile of parts
I have taken PS boxes off of earlier F-150's that fit as well.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd.
Originally Posted by gillamonster
i like ranch flavored shit
Originally Posted by 95thebroncoman351 View Post
played with one of my buddies... its sick
jopes is offline   Reply With Quote
Old 04-08-2005, 12:34 PM   #7
Gub_Ni
www.easttn4x4.com
Gub_Ni's Avatar
Bronco Info: 78 Bronco, 460, C6, 38's
You should be able to use one from 73 to 79 F-150 or 78-79 Bronco. You cannot use a newer one or F-250 gear box. I wouldn't reccomend getting a used one. It will most likely be worn out anyway. You can get a rebuilt one for $100 to $150 at your local parts store with a lifetime warranty.
Boggers, lockers, winch, and a big motor. What else do you need?
Gub_Ni is offline   Reply With Quote
Old 04-08-2005, 04:36 PM   #8
axaviere
axaviere's Avatar
locally they are $249 rebuilt + core. rebuild kits are $30
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
