Go Back   FSB Forums > Bronco Discussions > Technical Write Ups
Thread Tools Display Modes
Old 07-30-2004, 11:03 PM   #1
Aikidoka
Who needs oil anyways....
Aikidoka's Avatar
Bronco Info: 86 Bronco 351W
Red face V-Belt Saginaw swap (no cutting/grinding!)
I just picked up a saginaw to swap into my 86 Bronco. I found out a few more things that can avoid some cutting/grinding. My donor vehicle was a mid 80's carbed Ford Econoline. It was also a v-belt system. I have a 351W. The donor had a V8, I think it was a 302, but I didn't really care too much.
What you'll need.
Pump and pump bracket.
Belt if it's in good condition. (It's shorter than the stock Bronco belt)
The long bolt in the top hole of the pump bracket and it's spacer.
The bracket connecting the pump bracket to the water pump.
The high pressure line. (The old one is the same size and threads, but the end connection is shaped differently and will not work.)
The engine bracket that holds the A/C has two holes in the bottom right corner for the power steering pump. It has one if you have the crappy stock pump, and a lower one for the saginaw pump. If you have gotten the extra bracket off the van, you will not need to modify your original bracket. I still haven't been able to get my old high pressure line off the steering box.
Here you can see the two bolts showing the holes. The upper right one is the original pump bracket hole. The lower left one is for the saginaw pump bracket.
Another shot with the bolts removed.
Both brackets from the water pump. Top is saginaw, bottom is stock bronco pump.
Here they are with water pump bolt holes matched to show the difference. One on top is from the van.
Here's the bracket installed, showing the top right hole lining up with the extra one. You can see it goes into the lower hole on the bracket attached to the head. Now I know I never forgot a bolt when installing the rebuilt engine!
Tomorrow I should be able to get some shots of the installed pump. Let me just say thing. When pulling someting in a bone yard under the hot baking sun, remember to make sure you put all of your tools back in your bag! Right now there are four lonely wrenches on a econoline core support.
Size does matter. That is why they make 40oz.
I am not a mechanic. I reserve the right for anything I say to be wrong.
1993 EB Bronco
351W w/ 345K!
1990 Bronco
351W clean & rebuild in progress
1986 Bronco XLT
351W HO EFI Conv
Partial F-350 brake conv (still need to do calipers)
Crower 15935 baja beast cam
1985 Parts Bronco.
Also 351W and stripped down
My gallery
Aikidoka is offline   Reply With Quote
Old 07-31-2004, 10:42 AM   #2
Aikidoka
Aikidoka's Avatar
Here are a few more photos. The pump is runing great. However, my high pressure line is leaking at the steering box. Gotta fix that. There is just enough adjustment in the pump to use the existing belt. I haven't run it long enough to see if it will squeal when the engine is warmed up.
EDIT: I finally got my lazy butt to remember to check the E150 belt size against the Bronco's. It's about 1.5" shorter. You can get the one of the donor if it's in good condition or buy a new one. It will tension up much better than the stock Bronco one.
Pump installed.
My leak. Bottom line. The leak is where the line comes out of the fitting on the end. If I can't jerry rig it somehow I'll probably swap out the whole line.
EDIT: For those interested in doing steel braided lines, the fitting to use on the sag is a #6 to 16mm x 1.5 O-ring.
Old 07-31-2004, 02:36 PM   #3
Fireguy50
can I go to bed yet?
Fireguy50's Avatar
Bronco Info: faster than your's
Nice
Ryan McCormick
RJM Injection Tech
My Bronco
Ford Fuel Injection.com Technical Library
Parts replacement is not auto repair, if you can’t diagnose, don’t open the hood!
Fireguy50 is offline   Reply With Quote
Old 07-31-2004, 03:17 PM   #4
TRUCKY18
TRUCKY18's Avatar
Bronco Info: 95' All black 351w, E4OD, 3:55
neato, so that bracket is from the same year van as the pump?? do you happen to know if the same trick will work for serpentine?
The B'co
All Black 95' 351w,E4OD, 2.5" lift, 32x11.50 BFG's, 3:55
TRUCKY18 is offline   Reply With Quote
Old 07-31-2004, 04:55 PM   #5
Aikidoka
Aikidoka's Avatar
There's some bolt size trickiness to the serpentine swap. Run a search for saginaw pump in the tech article forum. You'll find one or two serpentine swap. In my case the bracket that went on the water pump is off the donor van. I got lucky in the fact that the large upper bracket for the A/C has a hole for either style in the lower right.
Old 07-31-2004, 08:34 PM   #6
Zebrafive
Talking
I was in a salvage yard today. I found a 16mm Snap-On wrench on a Ford truck core support. When I first saw it, I figured "China Junk" It was the second time I walked by it, I did a double take and it was Snap-On, so I adopted it.
Zebrafive is offline   Reply With Quote
Old 08-01-2004, 12:21 AM   #7
Aikidoka
Aikidoka's Avatar
Yeah, they were all hand me downs and I can't even remember what brand they are.
Old 08-01-2004, 01:09 AM   #8
Bronco85
Screw the Jeep Thing
Bronco85's Avatar
Hmm thats pretty sweet to know. I may have to go searching for that stuff soon. PLus I need an AC pump for my OBA.
CLICK ON THE BANNER MY 85 BRONCO (PARTING OUT)
'84 Bronco (SOLD) - I6 Motor, ALL STOCK
'93 Bronco Eddie Baurer (SOLD) - 302, E40D, 1356, 6" Lift, 35x12.5 BFG AT's
'94 Bronco XLT - 351W, E40D, 1356, ALL STOCK
Bronco85 is offline   Reply With Quote
Old 11-15-2004, 11:03 AM   #9
Aikidoka
Aikidoka's Avatar
Finally remembered to compare the E150 and Bronco P/S belts. E150 is a little shorter so I modified my instructions to include getting a new or the donor's belt.
Old 11-16-2004, 05:26 PM   #10
Sixlitre
Practicing Infidel
Sixlitre's Avatar
Bronco Info: 86 Eddie Bauer; EFI 5.0 liter, AOD, optimized ignition system, external tranny filter, urethane bush
Nice job
Less grinding than mine took
Sixlitre
My Superford site
http://www.superford.org/registry/vehicles/detail.php?id=4970&s=17328#content
Sixlitre is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
