yo,
FYI & for posterity;
I will address only Ford MC parts.
This is the Optional Upgrade Pad;
Motorcraft BRSD632 Front Severe Duty Pad
Price: $59.96 & this item ships for FREE with Super Saver Shipping
as shown in Ford Motorcraft® (fordinstallersupport.com) - Brake Parts Catalog, Bronco/Ford truck & all Fords w/Ford Part Numbers & Cross References (96MB pdf file) (
http://www.fordinstallersupport.com/files/catalogs/brakeparts.pdf)
see page 274
95 Bronco
Pads - SuperDuty . Notes; D632,I,SM ... Ford MC Part # BRSD-632
Notes;
R = Riveted
I = Integrally Molded
B = Bonded
SM = Semi-Metallic
ORG = Organic
D-Plate numbers for friction parts, Pads & Shoes, are noted within the Qualifier text for easier part identification.
Rotor BRR-56
Pad, Material Safety Data Sheet for "SuperDuty Part Number BRSD-632 for 94-96 Bronco; Miesk5 NOTE; this is not for the SD Model but it is the FORD MC part name
Source: by Ford fcsdchemicalsandlubricants.com
Rotor Dimensions, Fluid Specifications & Torque Specifications in a 96 from 1996 F-150, F-250, F-350, and Bronco Workshop Manual
Source: by Ford
Bronco (Integral)
Minimum Rotor Thickness (Discard Thickness) 24.45 mm - 0.96"
Rotor Thickness Maximum Variation 0.013 mm - 0.0005"
Brake Surface Lateral Runout (Maximum) 0.08 mm - 0.003
Rotor Surface Finish 0-1.6 mm - 0-65 micro"
Bronco (2-Piece)
Rotor Thickness Maximum Variation 0.018 mm 0.0007"
Brake Surface Lateral Runout (Maximum) 0.13 mm 0.005 "
Whee Lug Torque Specifications 1/2-20 100 Lb-Ft
NOTE: Torque specifications are for clean, dirt- and paint-free, dry bolt and nut threads. Never use oil or grease on studs or nuts.
2010 Aftermarket Brake Pad Evaluation, November 2010
Source: by Michigan State Police Precision Driving Unit
(same for 93-96)
Bleeding in a 96 from Workshop Manual
Source: by Ford via miesk5 at FSB
4WABS Hydraulic Control Unit (HCU) Bleeding Procedure (DIY)
Source: by SigEpBlue (Steve) at FSB
Significant Excerpts; "... For the longest time, I've felt that my brakes were too soft and not as responsive as they should be. Particularly during emergency stops, when the 4WABS would become active, the pedal would drop to the floor, requiring me to pump the brakes occasionally. After replacing almost all of the brake system components that were faulty and/or worn, the only thing left was to bleed the HCU. I had removed it once from the truck to rebuild the electric motor's brush holder, so I knew there was air in the HCU from that.
Ford has a special tool that goes between the ABS controller and harness, and it has nifty little switches for grounding the appropriate circuits according to the bleed procedure. Taking Ford's HCU bleed procedure, understanding how the system works, and using a few schematics, I've come up with a ghetto way to bleed the HCU, and I confirmed that it does indeed work just as well as the factory-approved method..." Read MORE
Miesk5 Note; Perform this procedure only if the Hydraulic Control Unit (HCU) has been replaced. Follow conventional bleed procedures if the HCU is not being replaced. \
And the Ford method; "Perform Pressure Bleeding procedure in this section.
Connect Anti-Lock Brake Adapter T90P-50-ALA (bleeder box) and Anti-Lock Brake Adapter T93T-50-ALA (jumper cable).
Press down on the brake pedal and depress the VALVES button on the bleeder box (brake pedal will fall).
Release the VALVES button and release the brake pedal.
Repeat Steps 3 and 4 once more.
Depress the MOTOR START button and let the pump motor run for one minute.
Perform Pressure Bleeding procedure in this section..."
Anti-Lock Brake Adapter (Bleeder Box)
Item Part Number Description
1 T90P-50-ALA Anti-Lock Brake Adapter (Part of T90P-50-ALA)
2 � Bleed/Harness Selector (Part of T90P-50-ALA)
3 � Green MOTOR ON Lamp (Part of T90P-50-ALA)
4 � Red MOTOR OFF Lamp
5 � Valve Button
6 � Abort Button
7 � Motor Start Button
Fluid Specifications; "...Use Ford High Performance DOT 3 Brake Fluid C6AZ-19542-AA or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A; CAUTION: Never reuse brake fluid that has been drained from the hydraulic system or has been allowed to stand in an open container for an extended period of time..." in a 96 from 1996 F-150, F-250, F-350, and Bronco Workshop Manual
Source: by Ford
Brake and Rotor - Service Tips Article No. 97-19-4
LIGHT TRUCK:
1993-96 BRONCO
1993-97 AEROSTAR
1993-98 RANGER, VILLAGER
1995-98 WINDSTAR
1997-98 EXPEDITION
ISSUE: This TSB article is intended to give a technician information regarding brake repairs to help reduce unnecessary repairs. ACTION: Refer to the following list when performing brake repairs. ^ Where rotors are the causal part, linings should only be replaced if they are damaged, e.g., cracked, taper wear, heavily grooved, etc., or if specifically instructed in a TSB.
^ Where linings are the causal part, rotors should not be machined unless they are heavily grooved or if specifically instructed in a TSB.
Other exceptions would include instances where the non-causal parts are found to be below minimum serviceable thickness or if the technician estimates that the parts will not last until the next service interval. Since these parts are classified as wear items (such as: linings, pads, rotors, and drums) replacement is not covered under warranty. OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 301000
