Help! Can't move the shifter - FSB Forums
Thread Tools Display Modes
Old 05-08-2011, 10:27 PM   #1
Full Size'n It
Full Size'n It's Avatar
Question Help! Can't move the shifter
1996 5.8L automatic. Stopped at the store and couldn't shift into park. Then I couldn't really move the shifter into any gear. I had to slam it into park to get the key out. Assumed something broke inside the steering column. Un hooked the cable and tried to get it into park so I could start and manually shift it into drive to get it home. I could pull the cable out but couldn't get it into park.
Got it in N and pulled it home. Took the steering column apart and the aluminum shifter is intact except there appears to be a plastic bushing that has slid down and the shifter is really sloppy.
Is this enough for it to not shift?? Or is there another issue since I couldn't get it in park by pushing the cable in by hand??
Any help would be appreciated. Don't want to take it to Ford unless I have to.
Full Size'n It is offline   Reply With Quote
Old 05-09-2011, 10:37 AM   #2
miesk5
miesk5's Avatar
yo, is it #28 in this diagram by Ford via Steve83?
If so, Yes..prob is the issue
inspect items #26, 27, 28, & 34 in this diagram for looseness:
Items #26 & 34 are known to get loose; #28 is known to wear.
Items #19 & 25 are known to break, and Ford offers upgraded versions.
For more info, see this page:
http://www.p71interceptor.com/steeri...mbled/pictures
1 Driver Side Air Bag Module 043B13
2 Steering Wheel Pad Horn Switch 13A80
3 Steering Wheel Bolt N804385-S100
4 Steering Wheel 3600
5 Air Bag Module Retaining Nuts 621903 (N805572-S36)
6 Screw, Clock Spring 390345-S36
7 Air Bag Sliding Contact (Clock Spring) 14A664
8 Turn Indicator Cancel Cam 13318
9 Bearing Retainer, Upper 3C610
10 Steering Column Upper Shroud 3513
11 Steering Column Upper Bearing Spring 3520
12 Steering Column Bearing Sleeve 3518
13 Steering Column Bearing Tolerance Ring 3L539
14 Steering Column Bearing 3517
15 Shroud Retaining Screws 55929-S2 (4 used)
16 Multi-Function Switch (MFS) 13K359
17 Screw, MFS 390345-S36
18 Steering Column Lock Actuator Lever Pin N805857
19 Column Shift Selector Lever Plunger 7361 (Automatic Only)
20 Tilt Wheel Handle and Shank 3F609
21 Steering Column Release Lever 3D544
22 Gearshift Lever 7210 (Automatic Only) may include TCS & TCIL (Electronic Automatic Only)
-- Steering Column Shifter Opening Weather Seal 3530 (Automatic Only, Not Available)
23 Gearshift Selector Tube Spring 7379 (Automatic Only)
24 Gearshift Lever Pin 7G357 (Automatic Only)
25 Transmission Column Shift Selector Tube 7212 (Automatic Only)
26 Screw, Shift Tube Clamp N806584 (Automatic Only)
27 Gearshift Tube Clamp 7E400 (Automatic Only)
28 Gearshift Lever Socket Bushing 7335 (Automatic Only)
29 Transmission Shift Selector Position Insert 7A216 (Automatic Only)
30 Screw, Actuator N806584 (Automatic Only)
31 Shift Lock Actuator 3Z719 (Automatic Only)
32 Shift Cable and Bracket 7E395 (Automatic Only)
33 Transmission Selector Lever Arm and Support 7302 (Automatic Only)
34 Screws, Arm N806584 (Automatic Only)
35 Gearshift Lever Interlock Pawl (Automatic Only)
36 Interlock Pawl Pin 7W441 (Automatic Only)
37 Transmission Control Selector Lever Spring Clip 7C464 (Automatic Only)
38 Wiring Shield 14A099 (Electronic Automatic Only)
39 Pivot Bolts N806582
40 Steering Column Lock Pawl 3E691
41 Steering Column Instrument Panel Bracket 3676
42 Steering Column Lower Bearing Retainer 3D681
43 Screws, Retainer N806583-S36
44 Steering Column Bearing Sleeve 3518
45 Steering Column Bearing Tolerance Ring 3L539
46 Steering Column Lower Bearing Spring 3520
47 Steering Angle Sensor Control Ring 3C131
48 Steering Column Lower Bearing 3517
49 Lower Bearing Housing Retaining Screws N806583-S36
50 Lower Column Mounting Nuts N806423 (4 used)
51 Wiring Harness Retainer 14A163
52 Parking Brake Release Vacuum Hose Extension 2B654
53 Steering Actuator Housing 3F723
54 Steering Column Lock Lever Pin 3B663
55 Screw, Switch (Tamper Torx Head) N806584-S36
56 Ignition Switch 11572
57 Steering Column Position Spring 3D655
58 Steering Shaft Assembly 3524
59 Steering Column Lock N805856
60 Steering Column Lock Lever 3D653
61 Steering Column Lock Lever Lower Actuator 3E715
62 Steering Column Lock Spring 3E696
63 Steering Column Lock Pawl 3E691
64 Steering Column Lock Lever Upper Actuator 3E715
65 Steering Column Lock Cam 3E695
66 Wiring Harness Retainer 14A163
67 Steering Column Tilt Flange Bumper 3D656
68 Steering Column Position Lock Spring 3B768
69 Steering Column Lower Shroud 3530
70 Steering Column Lock Gear 3E717
71 Steering Column Lock Cylinder Housing 3511
72 Steering Column Lock Housing Bearing 3E700
73 Ignition Switch Lock Cylinder 11582
74 Bearing Retainer 3C610
75 Bolt, Shaft N803942-S100 (4 used)
76 Screw, Brush 390345-S2
77 Wiring Harness Retainer 14A163
78 Speed Control Brush 9C899
79 Steering Column Lock Actuator Lever Pin 3F530
80 Key Release Lever Spring 3F532
81 Steering Column Key Release Lever 3F527
82 Steering Column Lock Actuator Cover 3E745
83 U-Joint 3N725
84 Lower Steering Column Shaft Extension Assy. 3B676
85 Steering Column Gear Input Shaft & Coupling 3A525
86 Steering Shaft U-Joint Shield 3F540 (2 used)
87 Firewall
Install transmission column shift selector tube (column shift only). Coat gearshift lever socket bushing (7335) with Ignition Lock Grease F0AZ-19584-A or equivalent meeting Ford specification ESA-M1C232-A. Tighten screws to 7-11 Nm (62-97 lb-in).
Shift Cable Adjustment
CAUTION: Under no circumstances should the cable be adjusted in any position other than D (drive) for the C6 transmission (7003) or (D) (overdrive) for the E4OD transmission.
1. From inside the vehicle, place the transmission range selector lever in the DRIVE position (C6) or the OVERDRIVE position (4R70W and E4OD). Hang an improvised three-pound weight (#1) on the transmission range selector lever (#2).
2. Raise vehicle on a hoist and position suitable safety stands under vehicle.
3. Remove the shift cable (#5) from the transmission lever ball stud.
4. Pull down the lock tab on the shift cable body.
5. Position the transmission range selector lever (#2) in the DRIVE position (C6) or the OVERDRIVE position (E4OD). This is three detents from the front-most lever position with the first position counting as one.
6. Connect the cable end fitting to the transmission lever ball stud.
7. Push up on the lock tab to lock the cable in the correctly adjusted position.
8. Remove safety stands and lower vehicle from hoist. Remove the three-pound weight from the transmission range selector lever.
9. After making the adjustment, check for park engagement. Check the transmission range selector lever in all detent positions with the engine (6007) running to make sure correct detent/transmission actions. Readjust if necessary.
Shift Indicator Cable
1. Remove the four screws from the lower steering column shroud. Remove the lower steering column shroud.
2. Rotate transmission range selector lever clockwise until it bottoms out in first gear.
3. Rotate transmission range selector lever counterclockwise three detents (overdrive position).
4. Hang a three pound weight on the transmission range selector lever.
5. Center pointer in the middle of D if equipped with C6 transmission, or (D) if equipped with E4OD transmission, by rotating the thumbwheel located on right-hand side of steering column actuator housing.
For more info, see these photos & diagrams:
http://www.supermotors.net/vehicles/...y/6098/31472-4
by Steve83
Parts by a Sponsor here 1ATony
CLICK LINK BELOW FOR CURRENT PRICING
http://www.1aauto.com/1A/ChassisSusp...aign=Shopzilla
1992 - 1997 Ford F150 Truck Steering Column Shift Tube Assy with Bushing SET
This replacement 4 piece steering column shift tube assy is just what you need to get your vehicles steering coulmn in good working condition again!
As this assy wears, it causes the sticky and wobbly feeling in your shift lever. Also, if exposed to moisture, this can cause the assy to rust up causing the normal smooth shifting motion to become hard to move.
Features:
Located in the center of the steering column ( See location diagram)
Steering column will need to be disassembled to replace parts
Consists of the following pieces:
(1) Shift Tube
(1) Selector Plunger
(2) Selector Bushings
Replaces dealer part numbers: F3TZ 7L278 A, F3TZ7L278A, F3TZ 7212 A, F3TZ7212A, 1F1Z 7212 AA, 1F1Z7212AA, F7DZ 7R264 AA, F7DZ7R264AA
Built to strict quality control standards
Direct replacements
Fits all models with or without tilt steering
Correct for models with Column Shift
Does not fit models with floor shift
This Steering Column Shift Tube Assy is a great replacement part and provides a good cost savings over the price of dealer parts.
or is it;
Ford04-F3TZ 7L278 A Shift Tube Bushing
$4.14 (ea)
If so, Then Dorman has them @ http://www.dormanproducts.com/p-25005-905-103.aspx
read thru;
Disassembly & Assembly in a 2000 Mustang; steering column parts- specifically the bearing sleeves and collars...found pics- from a Mustang but it's the same column internals. This is an excellent write-up for working on the steering column including the ignition actuator; BTW- to pull the steering wheel in the late models, a 2-jaw puller is needed. There are no holes to thread in the usual bolts for a steering wheel puller..."
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at FSB
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 05-09-2011, 11:19 AM   #3
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E4OD, D44 SAS w/Trutrac,Detroit locked 8.8, MAF conv, Tweecer tuned
I'd be willing to bet it is the tranny shifter cable. Same thing happened with mine and I had a tough time getting it in and out of gear.
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 05-09-2011, 01:22 PM   #4
Mike310
Mike310's Avatar
Bronco Info: 1995 Black on Black XLT
I had a fuse that blew that prevented the interlock pin from dropping, check to make sure your brake lights are working. If not, check fuse.
my 2 cents.
Mike310 is offline   Reply With Quote
Old 05-09-2011, 02:26 PM   #5
Full Size'n It
Great advise. Thanks for the help. The bushing is definately worn out. Thinking it could be more than that since I can't move the cable in by hand. I will check the break lights and fuse latter today and report back with the findings.
Old 05-10-2011, 06:32 AM   #6
miesk5
miesk5's Avatar
yo
ck fuses 13 and 10 in cab block
Diagram in a 96
Besides the Visual look at each fuse; ck for 12 v w/resr light or meter because the Maxi Fuse may be shot
Diagram in a 96; Miesk5 Note; Box is Located under the hood on the drivers side fenderwell, on driver's side of the air cleaner housing; there is a change from Letters to Numbers in 96
Source: by Ford via HardMaple at Ford Bronco Zone Forums
Old 05-11-2011, 04:54 PM   #7
Full Size'n It
Finally got to work on it last night. Shifter tube is good. Bushings where shot. I replaced those and put it back together. Made sure shifter moves smoothly without cable hooked up. Unhooked cable from tranny and tranny shifts fine. Hooked cable to shifter and tried to shift it without it being hooked to tranny and it was a no go. The cable is shot. picked up a new one today. Hopefully install that tonight.
Old 05-12-2011, 10:20 AM   #8
miesk5
miesk5's Avatar
yo,
ok
Are bushings the #28 Gearshift Lever Socket Bushing 7335 ?
Shift Indicator Cable Repair in a 96; "...Mine broke a couple years ago. I replaced the cable with 80# fishing line. Works great..."
Source: by Rons beast at Ford Bronco Zone Forums
Transmission Shift Control Cable and Bracket from 1996 F-150, F-250, F-350 F-Super Duty and Bronco Workshop Manual
Source: by Ford
From inside the vehicle, place the gearshift lever (7210) in the DRIVE position (C6) or the OVERDRIVE position (4R70W and E4OD). Hang a three-pound weight on the gearshift lever.
Remove the shift cable from the transmission lever ball stud.
Position the gearshift lever in the DRIVE position (C6) or the OVERDRIVE position (E4OD). This is three detents from the front-most lever position with the first position counting as one.
Remove safety stands and lower vehicle from hoist. Remove the three-pound weight from the gearshift lever.
CAUTION: Under no circumstances should the cable be adjusted in any position other than D (drive) for the C6 automatic transmission or (D) (overdrive) for the E4OD automatic transmission.
After making the adjustment, check for park engagement. Check the gearshift lever in all detent positions with the engine (6007) running to make sure correct detent/transmission actions. Readjust if necessary.
If image disappears or won't load, see it here
Item Part Number Description
1 — Three-Pound Weight (to Be Improvised in Shop)
2 7210 Gearshift Lever
3 3514 Steering Column
4 7B229 Transmission Shift Cable Bracket
5 7E395 Cable Assembly, Transmission Shift
6 56137-S100 Bolt, 3/16-16 x .62 Hex Flange Head
Rotate gearshift lever (7210) clockwise until it bottoms out in first gear.
Rotate gearshift lever counterclockwise three detents (overdrive position).
E4OD Transmission Selector Indicator
or see image here
Shift Indicator Adjustment; "...I always unhook the cable (shifting to L or 1 makes it easier), then spin the wheel. You can't really get to the indicator end to unhook it - I do it at the shifter (wheel) end. There's nothing inherently wrong with removing the wheel assy. But when you're trying to pull the cluster, it's easier to feed the bare cable end back around the column & thru the wiring harness. If the cable sheath is white, it's probably about to break no matter how careful you are. If it's black with mesh reinforcement, you almost can't break it; "...the adjusting wheel is for 92-up columns..."
Source: by Steve83 (Steve, That dirty old truck) at FSB
Here is that thumbwheel in,
Shift Indicator Replacement info & pics in a 94
Source: by Chris A (blueoval78) at SuperMotors.net
Old 05-12-2011, 02:55 PM   #9
Full Size'n It
[quote=miesk5;2634163]yo,
ok
Yes it was the #28 Gearshift Lever Socket Bushigs.
Old 05-12-2011, 11:21 PM   #10
Full Size'n It
Finally stopped snowing and raining and got the gear shift cable replaced. Truck shifts as good as new. Cable was suprising easy to swap. Only took 15 min. Thanks for the all the help.
Old 05-13-2011, 08:56 AM   #11
miesk5
miesk5's Avatar
yo
Great DIY work, you saved a bundle of $
YW
GL!
You may not post replies
Forum Jump
