Transfer case oil or fluid? - FSB Forums
Thread Tools Display Modes
Old 02-26-2011, 08:16 PM   #1
69SCJ
69SCJ's Avatar
Bronco Info: 1989, 5.0, auto, Eddie
I probably didn't search correctly since I'm surprised I couldn't find a definitive answer, but here goes......
What fluid or oil does my 79 transfer case take? It's the one with the shifter like this:
low lock
low
n
high
high lock
The Haynes manual says 140w, but that that seems way thick. Funny thing is it appears to have auto tranny fluid in it!!!!
Thanks for the help and feel free to rip me a new one if I missed the obvious answer somewhere.
Tyler
No fullsize right now, but acquired an uncut I could not resist!
69SCJ is offline   Reply With Quote
Old 02-26-2011, 08:43 PM   #2
colobronco
colobronco's Avatar
Bronco Info: 79 Ranger XLT 400CID C6 2" Lift on 33's
Someone has put the lovely NP203 into your Bronco. Full time 4 wheel drive.
It uses 80W-90 gear lube.
Originally Posted by InfoFord View Post
if you still can't figure it out put it back together and take it to a mechanic
"Under my plan electricity prices would necessarily skyrocket" BHO
Truck was stolen & sold for parts Wheat Ridge Colo Black with Red 2 tone. About $20K in the truck. VIN U15HLEC0170
colobronco is offline   Reply With Quote
Old 02-26-2011, 09:01 PM   #3
69SCJ
69SCJ's Avatar
Thanks. That 's what I ended up putting in there. 140 seemed crazy heavy to me.
I think this t-case was one of the option in 79??????
Old 02-26-2011, 10:06 PM   #4
John in AZ
I believe the 203 should have straight 30 weight oil in it.
John in AZ is offline   Reply With Quote
Old 02-26-2011, 10:10 PM   #5
redbeast9
Bronco Info: 80 BRONCO 400 NP435 NP205 Detroits , SAS, 5'' lift on 36'' TSL's
Use to have a rig with a NP203 and used 80-90 dope with never a problem.
redbeast9 is offline   Reply With Quote
Old 02-26-2011, 10:46 PM   #6
magnumpi
Wrenching for a Livin'
magnumpi's Avatar
Bronco Info: '85 Ford Bronco XLT.
Theres no oil pump IIRC. its just splash lube. The weight isnt critical....heck the type of fluid isn't that critical. 80w90 or 75w90 would be a good choice because of its avaliability. 530w engine oil would be fine too. I think thats what was in it from ford.
And the np203 was a factory option in the 78-79 ford. You don't have lockout hubs in the frontend do you?
My SuperFord
'85 Bronco......
Welded 14 bolt, HPKingpin D60 w/ lockright, ZF5, NP205, 4.88 gears, SMPFI 393 w/ EDIS(gufx strat), Chevy 52s Front, Inboarded Chevy 63s Rear, DOM heim steering, DOM cage, Saginaw pump, 3/8" fuel system, 200amp 3G Alternator....
ASE Master Automotive Technician
ASE Master Medium/Heavy Truck Technician
magnumpi is offline   Reply With Quote
Old 02-26-2011, 10:49 PM   #7
John in AZ
only read this yesterday was why I remembered. Here is the link from the thread I read & a quick search
30wt motor oil speced from new process.
http://www.ford-trucks.com/forums/43...-capacity.html
http://www.google.com/search?q=np203...rchBox&ie=&oe=
Old 02-27-2011, 01:19 AM   #8
Smok3y
FSB's Dirty Jersian
Smok3y's Avatar
Bronco Info: 89 EB, 91 Silver Anniv, 91 F250, 79 F250
low lock
low
n
high
high lock
Tyler
140w is a pretty heavy oil. I'd go with a little bit lighter. straight 90 weight is perfect. I've been using 90 weight since I've owned my 250 and per new standars I believe 80-90 is what manufacturer calls for now.
The original OEM maintenance listing has 30 weight as the recommended weight for tcase fluid. But actually I'm 95% sure that NVG (the new company name of NP [new process] recommends 80-90 now per new testing standards.
Some people even recommend ATF fluid, which you can use, but I'd use gear oil.
89 Eddie Bauer - 6" RC Lift, 35" KO's, 302/c6 swap, Ford 9"
79 F250 Ranger Lariat - 9" Lift, 40" Ground Hawgs, 400/435/205, D60/D70 LOCKED
Originally Posted by SigEpBlue
All I want people to do is STOP, THINK, and SEARCH. Only post if those three fail after thoroughly repeating.
Smok3y is offline   Reply With Quote
Old 02-27-2011, 08:22 AM   #9
Scoop
Scoop's Avatar
Bronco Info: 78 Custom, 84 Custom, 69 Half Cab, 74 Ranger - stock, 76 Trail Rig
Just had my 203 gone through and resealed by my tranny guy. He recommended either 0W30 or 5W30 Mobil1 synthetic. I'll probably go with the 5W30.
Round headlights are COOL (on '78's!)
September 2012 F.O.T.M.
78 Custom EFI Build Thread
84 300 I6 Build Thread
Scoop is offline   Reply With Quote
Old 02-27-2011, 09:25 AM   #10
69SCJ
69SCJ's Avatar
I think I have atf and 90w mixed together now.
Is there a drain plug I can't find?????
Old 02-27-2011, 09:26 AM   #11
69SCJ
69SCJ's Avatar
It is not supposed to, but somebody added them at some point.
Old 02-27-2011, 10:30 AM   #12
Scoop
Scoop's Avatar
The drain is the bottom bolt on the rear cover plate. The guy who resealed mine painted both the fill and the drain yellow - see this pic.
Old 02-27-2011, 10:31 AM   #13
Scoop
Scoop's Avatar
Then you may have a 203 that's been converted to part time. Same as mine.
Old 02-27-2011, 11:06 AM   #14
69SCJ
69SCJ's Avatar
Any way to identify these changes if made?
Also, thanks for the pic above. I wish it was the same for my 9" rear. Perplexes me that I'd have to pull the third member to drain it!!!! All the other nine inch rears have had drain plugs that I have had in the past.
Old 02-27-2011, 01:18 PM   #15
Scoop
Scoop's Avatar
All the mods are internal so the only way to tell is to verify the shift pattern. Here is the shift pattern for a converted 203 -
lo 4wd
lo 2wd
n
hi 2wd
hi 4wd
Let us know what you find out.
Old 03-01-2011, 07:16 PM   #16
OffOrWFO
The actual viscosity of 30w an SAE 90W are not too far apart at operating temp. I would run a 75w-90 syn were it mine. Gear oil has more extreme pressure anti wear additives. Way better for gear boxs.
http://www.bobistheoilguy.com/cms/in...d=48&Itemid=55
OffOrWFO is offline   Reply With Quote
Old 03-02-2011, 08:34 AM   #17
69SCJ
69SCJ's Avatar
Good chart to have as a reference.
Thanks
Old 03-02-2011, 10:58 AM   #18
BLenker09
Bronco Info: 1979 Bronco Ranger XLT
What about a NP205? 80w-90?
BLenker09 is offline   Reply With Quote
Old 03-02-2011, 11:59 AM   #19
magnumpi
magnumpi's Avatar
Prettymuch the same rules apply to the np205. I run 75-90 because i can get it almost free.
Again, theres no oil pump. Its just splash lube. And its completely gear driven, no chain. Just need something thats really slippery in there.
motor oil, gear oil, or even trans fluid. (Chevy used ATF in some of the later np205s)
My SuperFord
'85 Bronco......
Old 03-02-2011, 12:30 PM   #20
BLenker09
Thanks
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
