No oil pressure 351M - FSB Forums
Thread Tools Display Modes
Old 10-24-2010, 01:54 PM   #1
69SCJ
69SCJ's Avatar
Bronco Info: 1989, 5.0, auto, Eddie
The quick version:
I have zero oil pressure. 0 when cold, 0 when warm. Needless to say I don't run it very long. I added a mechanical oil pressure gauge and it doesn't even push any oil up in to the tube.
The long version:
When I bought the Bronco the PO said it had a blown head gasket and that it was showing no oil pressure, and that he had just installed a high volume oil pump because it had no pressure. He said it still had no pressure after the new pump. I noticed the gauges didn't work at all so I was hoping once I got the gauges working it would show oil pressure. I never could get the gauges working so I hooked up a mechanical oil pressure and temp gauge yesterday, and as mentioned above it doesn't even push any oil up in to the tube for the gauge.
I'm looking for any advice or experience here. Are the 351M's bad about snapping oil pump drive shafts? Or stripping at the pump or distributor?
I did search, but all the serches came up low oil pressure rather than zero. :(
Thanks
Tyler
No fullsize right now, but acquired an uncut I could not resist!
69SCJ is offline   Reply With Quote
Old 10-24-2010, 03:55 PM   #2
Rusty Shackelford
Bronco Info: 79 Bronco
try using a priming shaft and a drill and see what you can do.
Rusty Shackelford is offline   Reply With Quote
Old 10-24-2010, 07:54 PM   #3
Macmillan1
Macmillan1's Avatar
Bronco Info: 1996 eddie bauer, 351w, 6 inch lift 36" tsl's/78 bronco custom 400/4spd, all kinds of fun
If i remember correctly the oil galley's are undersized and tend to clog up easy..... someone else could chime in and add to it but im pretty sure thats what it is. i had a 351M in a 76 F250 and it has about 5 lbs of oil pressure all the time
1996 Ford Bronco Eddie Bauer "Tony the Tiger"//1978 Ford Bronco Custom//1979 Ford Bronco woods beater//1976-78-89 Ford pickup//1978 Ford Granada//1971 Ford Maverick Grabber//1968 Chevrolet Chevelle SS clone
Mark
Macmillan1 is offline   Reply With Quote
Old 10-24-2010, 07:55 PM   #4
Macmillan1
Macmillan1's Avatar
This may help too http://www.automotiveforums.com/t336...351m_swap.html
Mark
Old 10-24-2010, 08:14 PM   #5
351w500
Ok, Ill admit it's Vagish
351w500's Avatar
Bronco Info: '90 xlt 351w E40D Truetrac I GOT ROLLER ROCKERS !
When you run the motor is there the knocking or tapping that is associated with no oil pressure ?
351w500 is online now   Reply With Quote
Old 10-25-2010, 10:32 AM   #6
phred
phred's Avatar
351m don't have a lot of OP to start with. My engine never had more than about 10 psi hot idle. 40psi under load. If no knocks or rattles I'd say you have blocked port at the location of the sender.
phred is offline   Reply With Quote
Old 10-25-2010, 10:48 AM   #7
69SCJ
69SCJ's Avatar
It has been 22 years since I built a motor, a 302, and I can't remmeber what I used to prime the motor. All I remember is using a drill to do it.
What size fitting is the end of the pump shaft? Can you just buy a priming shaft?
Thanks
Old 10-25-2010, 10:49 AM   #8
69SCJ
69SCJ's Avatar
It idles fine, but any gas and it sounds like a knock and or collapsed lifter. Definitely no oil.
Old 10-25-2010, 10:51 AM   #9
69SCJ
69SCJ's Avatar
I wish I had 5 lb's. of pressure. Absolutely nothing though. Thanks for the link also. I'll do some reading.
Old 10-25-2010, 01:11 PM   #10
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
For one thing dont take the last owner word that he changed to oil pump. Does it look like the oil pan has been off? The pump might be locked up, the oil pump rod might be broke shit it even might not be in there. STOP starting it for one cause that is just KILLING the main and rod bearings.
If I was you I would pull the distributor and see if the rod is in there. And if it is see if you can rotate it.
I take Prayer Requests. God Bless
LarryP is online now   Reply With Quote
Old 10-25-2010, 01:23 PM   #11
69SCJ
69SCJ's Avatar
Yea, the pan has fresh sealant around it evidencing recent removal. The old oil pump is sitting in the floor board so I feel pretty confident it got changed. I am suspicious of the work though.
The rod/main bearings already worry me. I drove it on/off the trailer, a couple times to check the gauges, and once after installing the mechanical gauges. :( I'm considering pulling it and going thru the whole thing including putting new bearings in it. I don't want to spend money on machine though. May change my mind once I get into it though.
Trying to keep this project very cheap. Into it for $303.49 as it sits.
Old 10-25-2010, 01:48 PM   #12
BigWheelz
Bronco Info: 1978 Bronco, 466 EFI
Knocking....time for a 460 IMO
if you gotta keep the M-block, start with this:
Remove your distributor and check the oil pump shaft, it is a 5/16" hex shaft. If it is twisted, your pump is locked up.
If it is twisted, get a new oil pump and a new pickup tube. Always replace as a pair.
It is a good idea to also get new valve seals and a new timing set. These parts came from ford made of nylon, and after 30 years the nylon gets brittle and brekas into pieces. If one of these pieces is small enough it will get lodged in the pump rotor and lock up the pump.
good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work- Thomas A Edison
BigWheelz is offline   Reply With Quote
Old 10-25-2010, 02:17 PM   #13
LarryP
Thanks 351w500
LarryP's Avatar
Well lets hope he even put one back in lol. But really the pick up tube might have just feel off the pump to.
Old 10-25-2010, 03:14 PM   #14
69SCJ
69SCJ's Avatar
good luck
Funny you mention a 460. I was checking this out:
http://panamacity.craigslist.org/cto/2018795096.html
I was gonna wait until I clear some room in the garage to get back on this, but I may have to do some investigating sooner than later. Thanks for the info.
Old 10-25-2010, 03:16 PM   #15
69SCJ
69SCJ's Avatar
It would be nice if the oil problem is something simple. It sure does look easy to drop the the pan on vehicle. Like nothing is in the way. :)
Old 10-25-2010, 03:53 PM   #16
Handy_andy_cv64
House of Windsor 4ever!
Handy_andy_cv64's Avatar
Bronco Info: Eddie's gone/79 Ranchero (for sale)/97 Eddie Bauer Exploder 5.0 AWD
Take my word, as a Master Tech and a Ford guy: pull the dizzy. It's easier than laying on your back on the floor. If the pump drive rod is in there, you'll see it. Use a magnet to pull it out, so you can see if it's "barber-poled" (meaning it's twisted like taffy). That would indicate a locked pump. But if not, you can put it back in, along with the dizzy. Pull the filter, and pump some oil backwards into the pump. If the PO never properly primed the pump before installing it, it won't make any suction to draw the oil from the pan. Try those before removing the oil pan.
[379sinvb] I dropped my shaft off for a rebuild & lube
Handy_andy_cv64 is offline   Reply With Quote
Old 10-25-2010, 03:54 PM   #17
JKossarides
JKossarides's Avatar
Moroso makes the "oil pump primer" tool, part number 62210, cost me $35.00 and it's an 8 inch long round bar shaped tool and one end fits over the "intermediate oil pump shaft" that has an octagonal shape....th
Old 10-25-2010, 04:11 PM   #18
DGW1949
Bronco Info: 1989 4X4 351W C-6 3.54/3.55
A Ford OP drive is designed to be removed from the pump side, not out the top. So what I wanna know is..... How are you guys pulling your OP drives without knocking off the drive-retainer and having it fall into the oil pan?
DGW
1989 Bronco 4X4 351W EFI C-6 3.54/3.55 Gears.
DGW1949 is offline   Reply With Quote
Old 10-25-2010, 04:33 PM   #19
69SCJ
69SCJ's Avatar
Oh yea, definitely pulling the dizzy first. Was just saying there appears to be a lot of room under there compared to my 'Stang and 89 Bronc' if I have to pull it.
If I were to try to pull the shaft out from above wouldn't there be a retaining clip from preventing that? Same one that keeps it from coming out with the distributor? I'm not familiar with the 351M, but assume they are the same as 302's.
Thaks for the info. Heck, I may pull the dizzy this evening if I get a chance.
Old 10-25-2010, 04:38 PM   #20
69SCJ
69SCJ's Avatar
Originally Posted by JKossarides View Post
Moroso makes the "oil pump primer" tool, part number 62210, cost me $35.00 and it's an 8 inch long round bar shaped tool and one end fits over the "intermediate oil pump shaft" that has an octagonal shape....the other end goes into the drill, distributor completely out you need to get the end of the tool on the intermediate oil pump shaft inside the little galley there, run the drill for approx 5 minutes so the oil circulates thru the oil pump and galleys etc......
I've heard of guys here making their own PRIMER TOOL with small mm sockets but be carefull if you do something like that, you don't want sockets coming off and dropping down inside the engine you know.....ain't no magnet gonna help there....lol lol
* This is the procedure for new or rebuilt engines before firing it up the first time.
Obviously it's easier if the engine is out of the vehicle on a stand so you can simply turn it upside down and perform this procedure...
Keep in mind there is a little round "CLIP or KEEPER" on the intermediate shaft which prevents it from droping out of the oil pump when upside down......ROYAL PITA to get that shaft with it's octagonal shape back into the pump thru the top distributor hole "galley".....EEHHH!
I'm assuming with the mechanical guage you don't need the oil
pressure sending unit...?
Good Luck ~
If I make my own primer I think I'll tack weld the socket to the extention to be safe. If I remember right it is easy to tell when the oil pressure is up as the torque on the drill becomes obvious.
I took the sending unit off when I added the mechanical gauge.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
