Crazed 460/ZF swap - FSB Forums
Thread Tools Display Modes
Old 09-13-2010, 09:28 PM   #1
Crazed
F.O.T.Y. 2003
Crazed's Avatar
Bronco Info: '89 XLT SAS ~'78 Ranger, '90 Eddie
Crazed 460/ZF swap
Gonna get both rigs in the driveway and start taking them apart tomorrow.
You should know the "Street Truck", it is my '89 XLT, It started life as a 5.0/aod
I did a 6" superlift TTB lift
Did a 351 swap, mass air
D44 SAS
9" rear
I have never been happy with the 351/aod, I get crap mileage, and It was just time for a change for me.
I picked up this truck
It has a 460 EFI and a ZF 5 speed.
I will post lots of pics as I go along, I wont be spending too much on the swap, I will upgrade things later on as needed.
357W /'64 Fairlane /'90 Eddie /'78 Bronco
Crazed is online now   Reply With Quote
Old 09-13-2010, 09:44 PM   #2
5billiondead
5billiondead's Avatar
Bronco Info: SOLD 90 Eddie Bauer, 351, DANA60 KP/Sterling, 4.56, 37" Military GYs
I'm looking forward to this man
5billiondead is offline   Reply With Quote
Old 09-13-2010, 10:10 PM   #3
beevo
beevo's Avatar
Bronco Info: 1995 Oj special xlt 5.0 mass air
you plan on keeping the mass air with the 460?
beevo is offline   Reply With Quote
Old 09-13-2010, 10:50 PM   #4
Crazed
F.O.T.Y. 2003
Crazed's Avatar
I am gonna put the mass air on the shelf for now and run the stock 250 computer and harness.
I got the trucks up into the driveway
Put my 33s on the front, every little bit helps on these lifted trucks
Old 09-13-2010, 10:59 PM   #5
Kenny's 94
Kenny's 94's Avatar
Bronco Info: 5.0,e40d,9" 4:11,locker AR-23's,BFG 33's,K&N, 5" lift,Bassani headers/Y pipe,BBK 56mm, sliders
Good luck with your swap. I wanted to install a 460 efi with a 5spd. in my Bronco until gas prices went through the roof.
Kenny
Kenny's 94 is offline   Reply With Quote
Old 09-14-2010, 07:53 PM   #6
GearHead
GearHead's Avatar
Bronco Info: 95 xl 351 d60/10.25
I have been wanting to do this to my 95 since I got it.
I have always been a day late and a dollar short when I find donor trucks.
Any plans for the motor while its out? I know there are limitations with the SD system on the 460's just like on the 351's. But if I remember right, there are better cams that will work with Speed density.
Five generations with an unlocked door and a loaded burgular alarm.
http://www.superford.org/registry/ve...il.php?id=2616
GearHead is offline   Reply With Quote
Old 09-14-2010, 07:58 PM   #7
Black93Bronco
Black93Bronco's Avatar
Bronco Info: 89 F350, 460, ZF5, Project Street/Mud Truck
I wanted to do this to my 93 but my parts truck ended up being in better shape than my bronco so I sold the bronco .
Good luck with the swap, are you going to replace anything while the motor is out? oil pump/freeze plugs/timing chain are def a good idea if nothing else, very easy to do while motor is out. You wouldn't believe the slack in the timing chains I've replaced, both the 91 and the 89 looked ready to skip a tooth they were so stretched.
1989 F350 Lariat: 96 Front End, 460, ZF-5 Speed, 4:10's, Comp Cam, Valve Job, K&N Intake, Heddman Headers; soon to be lifted on 38.5's
1978 Bronco Custom: 460, Bored .040 Over, L&L Mounts, Edelbrock Carb, Performer Intake, Cam, Noisy Gears, C6 w/ E4OD Internals, 4 Pt. Roll Bar, 4" Lift.
Black93Bronco is offline   Reply With Quote
Old 09-14-2010, 08:05 PM   #8
RaZOrFLy
RaZOrFLy's Avatar
Bronco Info: 1993 XLT, E4OD, True Ram Air 302CID-SD, 31s, 3.55:1, Detroit Locker D44/Lunchbox 8.8
ROTFLMAO. If you think your fuel economy is bad with the 351, just wait until you have to fill up "the fridge" for the 460--ZF or not.
Either way, I take my hat off to you for your drive and determination. It sounds like a sweet combo, and I'm envious.
Take your time on that engine, and build it like you would if cost were no object. You've got a DD. May as well try to get 600+ LBs per FT of TQ out of that monster. Clearly, the rest of your truck can handle it.
Good luck, and thanks for sharing.
RaZOrFLy is offline   Reply With Quote
Old 09-14-2010, 09:30 PM   #9
norfolkff05
norfolkff05's Avatar
Bronco Info: 1985 EB current 1-ton sas and diesel/zf5 swap in progress
good luck with your swap, im excited for you. it should be a lot of fun when it is all back together.
norfolkff05 is offline   Reply With Quote
Old 09-15-2010, 12:16 AM   #10
Crazed
F.O.T.Y. 2003
Crazed's Avatar
Last shots before the bronco comes apart
Started pulling stuff off,
And some more
Should have it ready to pull the motor and tranny tomorow
Old 09-15-2010, 08:51 AM   #11
Jackson112784
Jackson112784's Avatar
Bronco Info: 90 bronco, rebuilt 302/aod, 4inch lift, 33's, 4.10 gears posi front and rear
Can't wait to see how it turns out. Like many others, I would love a 460 in my bronco as well. In 2004, I had a carbed 460, but went with the 302. EFI 460 is the way I'd like to go now. I only drove my bronco 1,300 miles this last year. I put it away in the winter and it's not a daily driver, so low mpg isn't a huge factor. Good luck. Buying a complete donor truck is the way I'd go as well.
Jackson112784 is offline   Reply With Quote
Old 09-15-2010, 11:16 AM   #12
Drilim
FSB's Bastard Child
Drilim's Avatar
Nice. lll be watching this.
-Zach
http://www.superford.org/registry/ve...il.php?id=3814
Originally posted by Keith_L
But it'll get better with more strokes and at higher speeds...
Originally posted by RavenTBK
With my luck, I'd end up putting undue stress on my balls and screwing them up to the point it will take a helluva lot more than $115.00 to get them fixed.
Drilim is offline   Reply With Quote
Old 09-15-2010, 11:43 AM   #13
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Huh..
That's odd.
I'm stoked with mine, waaaayyyy more power than the 302 and I am getting 12mpg city.
Well I'm sure it will be a top notch swap, as always.
Are you going to do anything to the 460, or just do a straight swap?
Also, I wish I had your funding
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 09-15-2010, 12:01 PM   #14
Crazed
F.O.T.Y. 2003
Crazed's Avatar
Originally Posted by Gacknar View Post
Huh..
That's odd.
Wow you get 12?
after the 351 swap i got 9, did mass air, it dropped to 8, and has progressively got worse till the last year or so it has been in the 6s.
I will do an oil pump, and a timing chain, and I'll clean it up, but for now this swap will be all stock.
Old 09-15-2010, 12:23 PM   #15
Alvin in AZ
AKA: Butthead
Alvin in AZ's Avatar
Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Wow you get 12?
Wish I could tell you what it might have been, but all I can say for sure is
something was wrong with your rig. :/
My junky '91 Bronco I bought abandoned for $700 then threw back
together, swapping parts all over the place, also gets ~12.3 mpg -mixed-.
351w/125k then added a ZF/188k and a '90 F250 EEC... but I did keep up
with my speedometer gearing and/or calculate in the odometer error when
figuring mileage tho...
http://www.panix.com/~alvinj/file12/SpeedTable.jpg
Could your low mileage been this simple? ...were you going to progressively
bigger tires and not figuring in the reduced odometer reading? {shrug}
Alvin in AZ
"wish {and hope and pray} in one hand and spit in the other
and see which one fills up first" - grandpa (he was an orphan)
Alvin in AZ is offline   Reply With Quote
Old 09-15-2010, 02:49 PM   #16
Crazed
F.O.T.Y. 2003
Crazed's Avatar
nope, I have 4.56 gears which works out pretty close with the 37" tires.
Overall I did too many engine things at the same time to be able to pinpoint what went wrong.
The 351 will find new life as a carbed replacement for the 302 in my 64 Fairlane.
Old 09-15-2010, 09:36 PM   #17
Crazed
F.O.T.Y. 2003
Crazed's Avatar
More teardown,
got the radiator out with the fan,
Pulled the 3G alternator and the hoses
Then, of course cause its Oregon, It started raining
I crawled under and pulled the drivelines and the t-case
Done for the day
Old 09-16-2010, 02:42 PM   #18
Mr Bell
Mr Bell's Avatar
Bronco Info: 1996 xlt 351w e4od Sag pump, hydroboost, electric fan, and roller rockers
If some of those fancy 351 parts start collecting too much dust you could always sell them. It just so happens that I am in the market for some of that stuff. PM me if you do decide to get rid of it. On a side note, that is one nice truck. I also have a 1988 f250 with the zf and a 460 with 4.10 gears, it got 10 mpg anywhere, didn't matter if it is loaded or not.
Mr Bell is offline   Reply With Quote
Old 09-16-2010, 04:51 PM   #19
Fireguy50
OUT OF BUSINESS / M.I.A.
Fireguy50's Avatar
Bronco Info: rusty
I wish my projects moved this fast.
Ryan McCormick
Fuel Injection Technical Library
Parts replacement is not auto repair, if you canít diagnose, donít open the hood!
Fireguy50 is offline   Reply With Quote
Old 09-16-2010, 05:41 PM   #20
GKR
GKR's Avatar
Bronco Info: 79 Bronco XLT, 95 Bronco XLT, 96 Bronco XLT
Very cool Tim I've been thinking about the big block swap myself the past few months.
GKR is offline   Reply With Quote
You may not post replies
Forum Jump
