Excessive Frame Flex/Fatigue - FSB Forums
Thread Tools Display Modes
Old 09-04-2010, 10:20 PM   #1
SomeDude451
Bronco Info: 1989 F350 XLT Lariat, 4x4, 7.5L SD, E4OD
I'm trying to determine where to draw the line in regards to frame flex. I know these trucks can flex the frame when offroading. I have no issue with that. However, mine will twist when driving on the street. During normal street driving, while going through a turn I can see the bed twisting a good inch or inch and a half in relation to the cab. I can also see the bed move fore and aft independently when going over bumps. It's like the frame where the cab and the bed meets is weakened. This is the second truck I've had like this and I really don't remember the other one flexing and moving around this much. I personally haven't abused it in the last two years that I had it, but there's no telling what the previous owner did to it, and i have my suspicions that it was used a tow vehicle before I got it.
Are there any ways to test for frame fatigue? How much is to much frame flex? Am I just being paranoid?
-Travis
My Supermotor(What's left of it.)
SomeDude451 is offline   Reply With Quote
Old 09-04-2010, 10:32 PM   #2
Northernguy
4:20 Enthusiast!
Northernguy's Avatar
Bronco Info: 82 Bronco 300/4.9,wee little stock carb. T-18.NP 208,9" Gotta love stock!
That is a lot of twist! Have you checked the frame for cracks?
What do your body mounts look like?
Are they tight?
Northernguy is offline   Reply With Quote
Old 09-04-2010, 10:59 PM   #3
SomeDude451
I haven't looked at the frame with a magnifying glass or anything like that, but every time I've been under the truck it looks fine. A bit of surface rust here and there and some dirt, but other wise in decent shape. I'll have a good look tomorrow at the frame and the body mounts tomorrow.
-Travis
Old 09-04-2010, 11:19 PM   #4
theramsey3
#1 Asshole
theramsey3's Avatar
Bronco Info: 90 5.0 H.O. E4OD BW1356 3.54 3L55 32/11.50R15 Black not the one in the pic ^^^
check the body mount bolts and rubber mounts. the bed is mounted directly to the frame and the cab is on rubber mounts.
Gotta get going again soon. my supermotors for before and after.
Originally Posted by ford_munky_man View Post
I was always taught u got to lube it up before you stick it in. My friends said the teacher yesterday said that too.
theramsey3 is offline   Reply With Quote
Old 09-04-2010, 11:53 PM   #5
kf4amu
Try it now!!
kf4amu's Avatar
Location: hotels, Charlotte, Roanoke VA, the cockpit...time split equally between all of them.
Bronco Info: 1989 460 EFI/C6/BW1356 electric/6 inch Rough Country lift/York OBA/Warn hubs/electric fans/14 bolt
I would bet your body mounts are shot before the frame. I've never heard of any Broncos/150's having frame problems, even with all the flexing.
-Will
064 tlx 98
http://www.supermotors.org/registry/...ail.php?id=819
The best electric fan writeup out there
http://fullsizebronco.com/forum/showthread.php?t=40564
kf4amu is offline   Reply With Quote
Old 09-05-2010, 12:05 AM   #6
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
gm frames, on the other hand....
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Nemo nisi per amicitiam cognoscitur -- No one learns except by friendship.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 09-05-2010, 08:48 AM   #7
SomeDude451
I checked it out today. The rear section of the frame, particularly on the driver side is more corroded than the front, but is not what I would call excessive. It's a twenty year old truck that originally lived in California. Some surface rust and a bit of pitting. The body mounts look fine to me. They're not rusted, the bushings are a bit compressed, but not horribly. I checked what I could of the frame and aside from the noted rust, I didn't see any large defects or cracks. Also, unlike the Broncos the F150s only have four body mounts. Two for the core support and two for the cab. Both of mine for the cab look the same.
-Travis
Old 09-05-2010, 02:01 PM   #8
theramsey3
#1 Asshole
theramsey3's Avatar
Really only 4 total it should be 6; 2 on the core support and 2 on the left side of the cab and 2 on the right side of the cab. Try to replicate the frame flex by jacking the front of the truck up and leave the rear on the ground see where it is flexing from out side of the truck.
Old 09-05-2010, 02:08 PM   #9
Northernguy
4:20 Enthusiast!
That looks new still!lol I don't understand where you would get 1-1 1/2" of flex or twist from with a frame and mounts that looks that good.I would check the bolts on the box and see if they are loose or missing.
theramsey3 has a good idea to jack it up and look for anything that might be giving you the problem.
Old 09-05-2010, 03:14 PM   #10
SomeDude451
You would think there would be more, but the Ford shop manual I have confirms that there are only four total for F150s. It's dark out right now, but I'll try to get out the jack tomorrow and see if I can make it twist.
-Travis
Old 09-05-2010, 03:19 PM   #11
Dustball
shibby
Dustball's Avatar
You have two bushings at the rear of the cab on top of the frame rails.
Dustball is offline   Reply With Quote
Old 09-05-2010, 11:24 PM   #12
KC200787
Kitteh Commandaar!
KC200787's Avatar
Bronco Info: 2006 F150 Lariet 4x4 ECSB - 5.4 Trition
When you jack it up, take a picture. My white F150, aka rusty, didn't even flex that bad. :
KC
My Supermotors PageMy vehicles:
DD - Truck: 2006 Ford F150 Lariet, Ext. Cab, 5.4, Auto, 82K
Truck: 1995 Ford F150, Ext. Cab, 5.0L, 5sp, 189k miles, 4x4, 31" Trailblazer Mud Terrains - currently broken
KC200787 is offline   Reply With Quote
Old 01-17-2011, 11:40 PM   #13
SandStallion
SandStallion's Avatar
Location: Santa Maria Ca., right close to pismo Dunes. :)
Bronco Info: 1990 Bronco XLT. 4in. New and Improved 5.8L sand lovin' machine.
This is probably a stupid question, but is your frame flexing or are you suffering from body roll in turns? if your frame was flexing that bad you would have cracked your fiberglass shell. I suggest, that during a turn, you look at the top of your tailgate corners in relation to your bedsides. if your frame is flexing that much you should see a huge gap between your shell, tailgate and bedsides. After you eliminate that, check your rear sway bar bushings and rear leafspring bushings.
Support your local Mobber.
SandStallion is offline   Reply With Quote
Old 01-18-2011, 12:25 AM   #14
vintagestrat08
vintagestrat08's Avatar
Bronco Info: 1995 XLT, 5.8W, E4OD, 8.8, Dana 44 ttb, BW1356
he is talking about an F150
ΜΟΛΩΝ ΛΑΒΕ
vintagestrat08 is offline   Reply With Quote
Old 01-18-2011, 05:02 AM   #15
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' EB 5.0, E4OD, OBDII, Mass Air, Saginaw, Hydroboost, 3G alt
I have seen some gnarly frame flex out of the F-150s personally. What configuration is yours? Single cab long bed? My dad's old 86' (now my sisters) had flex like no tomorrow. But you also have to look at how long those frames are without much in the way of supports. If you are truely worried I would see about fish plating the sides of the frame to beef it up. But that would make for a lot of work for something that is not causing you a ton of problems. I would throw a nice new set of body mounts on the truck and see if that helps any.
cajunrebel is offline   Reply With Quote
Old 01-18-2011, 08:10 PM   #16
SomeDude451
Both. The body rolls as you would expect a truck to, and the bed flexes independently of the cab. The bed also moves along a vertical (pitch) axis when going over bumps. Leaf spring bushings look ok. Not amazing, but not horrible. The front and rear sway bars are in a trash pile somewhere.
Supercab shortbed. It hasn't gotten any worse since I've had it. It's enough that I keep an eye on it, but not enough for me to do something about it just yet. It's an old, tired truck. It's not really surprising at this point. Also, I'm lazy and it still goes from A to B.
-Travis
Old 01-19-2011, 04:22 PM   #17
helirich
helirich's Avatar
I have a bronco stripped to the frame right now. I moved it with a tractor/front end loader by lifting one frame rail at the front. While rolling on the back wheels over little bumps at slow speed, I noticed alot of flex. This is with no engine, trans or tranfercase. This Bronco has very little rust. Now I know why the bodys always crack at the rain gutter.
helirich is offline   Reply With Quote
You may not post replies
Forum Jump
