Shifter Cable Adjustment? - FSB Forums
Thread Tools Display Modes
Old 08-30-2010, 06:07 PM   #1
Bar - T
Bronco Info: '92 EB 351w E40d w/6" lift and 35's
Hello all...just replaced my Neutral Saftey Switch and now I think I need to make an adjustment to my shifter cable. Tried following the instructions below but just dont know enough about the parts to identify the correcct parts:
CAUTION: Under no circumstances should the cable be adjusted in any position other than D (drive) for the C6 transmission (7003) or (D) (overdrive) for the E4OD transmission.
1. From inside the vehicle, place the transmission range selector lever in the DRIVE position (C6) or the OVERDRIVE position (4R70W and E4OD). Hang an improvised three-pound weight (#1) on the transmission range selector lever (#2).
2. Raise vehicle on a hoist and position suitable safety stands under vehicle.
3. Remove the shift cable (#5) from the transmission lever ball stud.
4. Pull down the lock tab on the shift cable body.
5. Position the transmission range selector lever (#2) in the DRIVE position (C6) or the OVERDRIVE position (E4OD). This is three detents from the front-most lever position with the first position counting as one.
6. Connect the cable end fitting to the transmission lever ball stud.
7. Push up on the lock tab to lock the cable in the correctly adjusted position.
8. Remove safety stands and lower vehicle from hoist. Remove the three-pound weight from the transmission range selector lever.
9. After making the adjustment, check for park engagement. Check the transmission range selector lever in all detent positions with the engine (6007) running to make sure correct detent/transmission actions. Readjust if necessary.
My questions are:
Step 3 - Where is the transmission lever ball stud located (if you have a pic that would be great). And how do I go about removing the shift cable from it?
Step 4 - Where is the lock tab located? (again if you have a pic that would help)
Step 5 - Where is the transmission range selector lever located?
Thanks for your help.
Bar - T is offline   Reply With Quote
Old 08-30-2010, 06:10 PM   #2
Dustball
shibby
Dustball's Avatar
3- side of the transmission where the shift cable attaches
4- on the shift cable
5- side of the transmission where the shift cable attaches
Dustball is offline   Reply With Quote
Old 08-31-2010, 08:08 AM   #3
Bar - T
So how do I remove the shifter cable from the ball stud?
Old 08-31-2010, 01:47 PM   #4
miesk5
miesk5's Avatar
this is from the 1996 F-150, F-250, F-350 F-Super Duty and Bronco Workshop Manual
Transmission Shift Cable and Bracket
Removal
From under instrument panel, remove shift cable and bracket (7E395) from steering column.
Remove cable plastic terminal from gear shift lever pivot ball by prying with a screwdriver between cable plastic terminal and gearshift lever (7210).
Remove transmission shift cable from transmission shift cable bracket (7B229) by carefully lifting on the locking tab while pulling up on the fitting.
From engine compartment, pry cable grommet from dash panel.
Remove the plastic slide adjuster from manual lever pivot ball, prying with a screwdriver between the slide adjuster and manual control lever (7A256).
Remove transmission shift cable from transmission shift cable bracket by carefully lifting on the locking tab while pulling up on the fitting.
From engine compartment, pull cable through the instrument panel opening.
Installation
From instrument panel, feed plastic terminal end of cable through opening in dash panel to engine compartment.
Press cable grommet on transmission shift cable into dash panel.
From engine compartment, install transmission shift cable into transmission shift cable bracket and make sure locking ears are properly located and seated into bracket.
Place transmission shift cable on manual lever pivot ball and press into place.
From the passenger compartment, install cable-to-steering column transmission shift cable bracket onto transmission shift cable and make sure locking tab is fully seated and locked into place.
Snap cable plastic terminal to shift control selector lever pivot ball on steering column.
Adjust transmission shift cable. Refer to Transmission Shift Control Cable and Bracket in the Adjustments portion of this section.
Remove cable lock tab and replace with new lock tab.
see Image if it does not appear here @ http://www.thedieselstop.com/faq/949...es/d12801b.gif
LEGEND:
http://www.thedieselstop.com/faq/949...j/stj75009.htm
USN & DoD Planner (ret)
THANKS to ALL WHO SERVE!
Old 09-03-2010, 03:30 PM   #5
Bar - T
Can someone show or direct me to where in the hell the Lock tab is or what it looks like in step 4.
Old 09-03-2010, 05:28 PM   #6
Bar - T
Disregard my last...i finally figured it out.
Old 09-05-2010, 05:03 PM   #7
Bar - T
I believe I need a new shifter cable. However, I've searched and can't find a replacement shifter cable. Anyone out there know where I can pick one up besides the jy?
Old 09-06-2010, 08:43 AM   #8
miesk5
miesk5's Avatar
yo,
7E395 Shift Cable and Bracket\
F5TZ7E395A .. Transmission Shift Control Cable Assy / F5TZ7E395A replaced: F2TZ7E395B & F2TZ7E395A.
Fits 1992/96: F150/350, F(Super Duty) & Bronco all w/E4OD.
MSRP: $64.98 Y2KFORDPARTS.COM price: $47.38
http://www.amazon.com/dp/B0036ZKKB0/...0&linkCode=asn
$49.00
o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o
Usually ships within 6 to 10 days.
Ships from and sold by Tasca Parts.
F5TZ 7E395 A Cable Asy - Selector
Sale Price: $50.52
http://store.crownmotorsredding.com/...-13707-68.html
http://www.carpartsestore.com/prodde...d=F5TZ-7E395-A
Old 09-06-2010, 08:51 AM   #9
Bar - T
Miesk5....thanks for for your help.
Old 09-07-2010, 08:57 AM   #10
miesk5
miesk5's Avatar
yo BT,
YW
Let us know where you buy if from, price and ask em how many they have left.
Old 09-14-2010, 08:11 AM   #11
Bar - T
I went with the one from Crown motors.
$58 with shipping... I got no response to the question on how many more he had left.
Old 09-14-2010, 09:13 AM   #12
miesk5
miesk5's Avatar
yo BT!
Thanks for the info.
Old 09-18-2010, 09:55 AM   #13
miesk5
miesk5's Avatar
yo,
Is there a problem replacing it? I didn't check your PM or my Reply date just now before deleting it... I shoulda kept it in-place for awhile.
Shift Indicator Cable; "...Shift Cable and Bracket, 7E395 #32 Location in Parts Break-Out Diagram in a 95
You may not post replies
Forum Jump
