Rebuilding the 400-Stock Pistons or TMeyer 9,3:1? - FSB Forums
Thread Tools Display Modes
Old 07-17-2010, 01:09 AM   #1
henri
henri's Avatar
Bronco Info: 1981 Bronco XLT..4,2L Turbo diesel MWM International engine, Cast ZF5 , NP 205 ,Fr/ Rear ARB,D44 SAS
Im rebuilding my 400 and I have this 2 options....
-Stock 8,4:1 Federal mogul pistons or TMeyer 9,3:1 CR pistons....???
Im planning to use a performer plus edelbrock cam, 600cfm carb performer intake and Mallory hei ignition.
What do you think about that?
Bronco 1981 XLT 4,2MWM International turbodiesel engine 185hp, ZF5 -NP205-D44 SAS-TRES- ARB Lockers,35" MT KM2 and 4,10 Gears
http://www.supermotors.net/19331
www.u15.forogratis.es
henri is offline   Reply With Quote
Old 07-17-2010, 01:14 AM   #2
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
depends on fuel quaility at your local pumps.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 07-17-2010, 01:28 AM   #3
henri
henri's Avatar
in the city the quality is good.....but when travelling long distances uotside town....it may not be that good.....
Old 07-17-2010, 01:38 AM   #4
jopes
gone fish'n
jopes's Avatar
your typically going to need higher octane gas.
Let's Go Fishing.
Old 07-17-2010, 08:43 AM   #5
46079bronco
46079bronco's Avatar
Bronco Info: 79 ranger xlt
9.3 is not that high and depending on where you have the timming set you could run 87octane.
79 ranger xlt free wheeler
roll bar, factory cb, lighted sun visors, cruise, tilt, ac, factory air assist, front and rear lockers, built 460, 4inch rancho lift with 2 inch body, rebuilt c-6 with shift kit
46079bronco is offline   Reply With Quote
Old 07-19-2010, 09:50 AM   #6
toughhorse1
Bronco Info: 1978 bronco 302 4 speed 36"swampers 1978 bronco 351m rangerxlt air,bar,sliders
i just built a 410 tmeyers with similair compression and it sparked knocked till i dumped 93 in it and clearance issues called for thicker head gaskets the way the pistons are designed or it was cause i 0 decked the block and shaved the heads
toughhorse1 is offline   Reply With Quote
Old 07-19-2010, 09:53 AM   #7
toughhorse1
more compression means higher hp and torque so if thats what u want tmeyers is the way to go
Old 07-19-2010, 10:38 AM   #8
UTfball
UTfball's Avatar
Bronco Info: 1979 w/400, 4" lift, 35's, 3.55's
TMI...would be my pick, no questions asked. As Jopes pointed out though, you'll need to bump to 91, probably 93 octane. Depending on the ethanol content, sometimes I can get away with 91...other times it has to be 93.
Ben
UTfball is offline   Reply With Quote
Old 07-19-2010, 02:25 PM   #9
Night Stalker
Bronco Info: 1979 XLT
Keep in mind gas..... quality is not getting better, but there is always additives....
Night Stalker is offline   Reply With Quote
Old 07-20-2010, 12:12 AM   #10
jopes
gone fish'n
jopes's Avatar
400's had issues with pinging from the factory with 9:1 CR.
additives get expensive, you can gain more power from your cam choice than increasing compression by one point
Let's Go Fishing.
Old 07-20-2010, 11:03 PM   #11
henri
henri's Avatar
This is exactly what I supposed.....But I dont have too much experience with this engines......
I blown up my last diesel engine cos the shity quality of the diesel......and that was my concern about increasing the CR .......and may be is not "necessary"...
I will run an Edelbrock performer plus cam, lifters and springs. ....Performer intake, Edelbrock 600cfm 4bb carb, mallory hei distributor and heddman headers.....and ford motorsports true roller timming chain set....
Old 07-21-2010, 07:48 PM   #12
henri
henri's Avatar
What do you think about the edelbrock performer plus cam running with the stock pistons?
Old 09-02-2010, 01:22 AM   #13
henri
henri's Avatar
well here they are.....T Meyer 9.3:1 CR pistons
By montecarlo at 2010-08-25
Old 09-03-2010, 02:32 PM   #14
OX1
OX1's Avatar
Those look sweet. Running stock heads?
I was going to run about 12:1 with pane, but have since decided to go with some sort of EFI, porbably somewhere around 10.5:1. Hoping to get away with 93.
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 09-03-2010, 03:14 PM   #15
American Thunder
American Thunder's Avatar
Bronco Info: 1978 Bronco 9" lift, 35s, Cummins power
With a small cam and iron heads, 9.3:1 would do best with 93 octane, unless you retard the timing slightly, which will negate the efficiency benefit of the higher compression.
Ox, with iron heads and a truck cam, 10.5:1 will ping unless you retard the timing. My Mustang motor has 10.95:1 with aluminum canted valve hi-swirl heads and a big solid lifter cam. ( 250/260 duration @ .050" ) and it barely gets away with premium gas. Of course, the more aggressive the cam, the lower the cylinder pressure at low rpm and the less octane required. Vice versa for smaller cams.
1978 Bronco 9" lift on 35s, with 1991 Cummins 6BT swap, Denny T fuel pin, pump mods, 3200 gov. spring, Trac-Loc front diff, C6 built by Dynamic Transmissions with billet 1200 rpm converter, 4" exhaust, no muffler. GOT TORQUE?
American Thunder is offline   Reply With Quote
Old 09-06-2010, 10:00 PM   #16
henri
henri's Avatar
Yes I run stock heads....
Old 09-08-2010, 01:51 PM   #17
lucasjackson
Bronco Info: 78 400 4spd 4:11s with a detroit out back
go TMeyer all the way.I just dropped in a 400 he built for me and I love it.I went with his pistons and my setup is about 9.3 to 1 and how it is tuned now it needs 91 octane and I am OK with that.
If you are that worried about it spend about 300 buck more and have Tim set you up with a set of aussie heads and stock pistons.That way you get higher compression but since the aussie heads have the "quench" you can get away with lower quality fuel.
But you should talk to Tim about it,for those of you who do not know he is the expert and he is very honest.
lucasjackson is offline   Reply With Quote
Old 09-22-2010, 04:03 AM   #18
bsnake2
bsnake2's Avatar
Bronco Info: 78 Bronco 400ci, edelbrock 1406 carb, edelbrock performer manifold, C6, NP205, D44, Ford 9"
Any thing new going on here?
bsnake2 is offline   Reply With Quote
Old 09-22-2010, 10:19 AM   #19
henri
henri's Avatar
Hi Lucas I talked to Tim and and then I decided to go with his pistons......since my english is not the best he made a big effort and talked to me.........I think is a great guy.
Old 09-22-2010, 10:22 AM   #20
henri
henri's Avatar
Im waiting for the camshaft and bearings....the block is machined and pistons pressed on the rods....they came in different shippments.
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
