Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 05-26-2010, 10:21 PM   #1
Ewgoetz
Ewgoetz's Avatar
Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 145,000Miles
Engine light on Code P1351
Fixed a issue with teh vacum leak my old brake booster was causing. Now I have another code which is
P1351 - Ign Diagnostic Monitor input Ckt
Any Ideas what could be the cause? engine seams to be running fine.
Ewgoetz is offline   Reply With Quote
Old 05-26-2010, 11:41 PM   #2
Tony R
Cleaning the trails
Tony R's Avatar
Bronco Info: 96 OBDII Forest Service Retired
Here is the Ford OBDII information
See page 31 for your code. Not sure if it helps much..
http://www.motorcraftservice.com/vdi...f/obdsm963.pdf
96 US Forestry Surplus Vehicle
5.8L XL 4" BDS Lift 35" Goodyear Wrangler SA
KI6FGI
Tony R is offline   Reply With Quote
Old 05-28-2010, 01:11 PM   #3
Ewgoetz
Ewgoetz's Avatar
If there is not an IDM edge (coil firing) for every PIP edge (commanded spark event), the PCM will look for a pattern of failed IDM events to determine which ignition coil has failed. If the ignition coil cannot be identified or if the engine is running and there are no IDM edges, the IDM circuit is malfunctioning (P1351).
So how do I go about repairing this issue?
Actualy I think I know why the code is coming up now.
Before I did the Hydro brake booster swap I had a engine light coming up for a vacum leak cause my old vac brake booster was leaking. during that time as I was gathering parts stil for the hydro booster I had swaped out the ignition modulle, and it ran fine. looked at the old ignition module and new one and realized the last 2 alpha letters had been both different. I went over to teh dealer and had the parts guy run both numbers and the old one pointed to a different alpha letter as well. So I' waiting for tuesday to get here to get the new one that I need. I read on the board somewhere that thye had created 2 different Ign modules and one sends a signal to the ecm telling it that the spark had fired to the coil.
Old 05-29-2010, 09:01 AM   #4
miesk5
I used to know this stuff
miesk5's Avatar
Location: USE FORD PARTS, let da ZONE handle ice scrapers
yo,
I think you have it solved.
http://web.archive.org/web/200408281...80/ai_76665483
by David S in Motor Service, June, 2001 via web.archive.org
Should be Black in color for the CCD Type Module.
See our Big Bronco Technical, Parts Sources & Technical Service Bulletins Links site
Our SF Site
THANKS to ALL WHO SERVE!
Old 05-29-2010, 09:14 AM   #5
miesk5
miesk5's Avatar
Sorry, filed to add this due to lag by Comcast and I then I over-wrote it.
DTC P1351 Ignition Diagnostic Monitor Circuit Input Fault "...P1351 can occur if the Igniton Module was replaced with the Gray one instead of a Black one. The ICM Should be Black in color for the CCD Type Module. Many Ford parts sources are incorrect and show that this vehicle should have a Grey module. The Motorcraft part number for the Black ICM is a DY-679..."
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
