New parts obtained from Advanced Auto parts and the part numbers from them. Parts are for a 1996 F350(also for a F250 and F450) Diesel. This model booster was also optional from 1992 to 1997 on the some F250's F350 and F450.
Parts needed:
Hose from Pump to Hydro unit - 71442 - $22.99
Hose from Hydro unit to Gearbox - 71416 - $20.99
Return hose - 71206 - $11.99
Brake Hydrobooster - 527079 - (total with a core charge) $171.69
Prestone power steering fluid 1 quart - $4.59
Hose clamps for the return hose - 5203v - $4.98
Vacuum cap for old Brakebooster hose line - (I had in my garage already)
Brass T for return Lines - lowes plumbing department - $13.78
Rod, spring and retainer from a used unit from a Junkyard.
Brake Hydrobooster return hose
Brass T for return hose's
Brake Hydrobooster
Picked up a used Hydroboost unit cause my vac booster has gone out and needs to be replaced now. Otherwise I would be looking for a F250/350/450 in a pick n pull now still.Took out the Rod, spring and retainer out of the used one and will be putting them in the new unit I had gotten from discount auto parts. Picks below of the used unit and the parts. When removing the 3 parts from the used unit pull the rod out first than you can work out the retainer with a screw driver. (defenetly wear safety glasses if you dont wear them.....should be wearing them on anywork you do)careful thought cause the retainer will fly out of it very fast and will fly a good distance. mine flew about 8ft from me lol.
used Hydro unit
Parts needed (I also took the rubber booty that goes over the end of the shaft for my new one)
New Hydro booster with the rod, spring, retainer and boot installed.
Parts needed:
Brake Hydrobooster
used Hydro unit
