How To: Bypass Dash Rear Window switch. - FSB Forums
Thread Tools Display Modes
Old 05-17-2010, 08:49 PM   #1
BeastBronk
BeastBronk's Avatar
Bronco Info: 175k+ 92 Bronco, 351W,E4od, 35 x 12.50 x R15 Tires
Here is my way to give back to the site!
A simple write up on how to track down those rear window problems. You will need 2 strips of wire.
To remove the switch,you have to remove the cluster panel to get to the two phillip screws behind the panel that hold the switch in.
Dash harness with switch removed.
How to roll window down.
How to roll window up.
Connector pinout
If this solves Your rear window problems,you have a bad dash switch. You can either clean or replace yours.
Thanks for looking!
92 Bronco, 351 Motor.
BeastBronk is offline   Reply With Quote
Old 09-29-2010, 08:10 PM   #2
garys b.b.b.
garys b.b.b.'s Avatar
Bronco Info: 93'XLT 302 v8 e40d 4" rc lift 35x12.5x15 bfg at
k that didnt work so now im blaming the t.g. saftey switch ,must be bad since motor still works and ive tryed moving t.g. around and slammed it shut a few times with no luck ..so now i need to figure out how to bypass that saftey switch ..
garys b.b.b. is offline   Reply With Quote
Old 09-30-2010, 04:23 AM   #3
whoa5oh
whoa5oh's Avatar
Bronco Info: 81 bronco 300i6/4spd more bondo than metal. 82 bronco 351w/c6 texas truck, 78 351m t18 and 33's
take the panel off and there's a small two wire connector attached to the harness in the tailgate next to the latch handle i used a wire to jump connections and taped it up
Providence has given to our people the choice of their rulers, and it is the duty, as well as the privilege and interest of our Christian nation to select and prefer Christians for their rulers."
John Jay, first chief justice of the supreme court, Oct 12, 1816. consequently appointed by Geroge Washinton himself.
whoa5oh is offline   Reply With Quote
Old 10-14-2010, 05:02 PM   #4
fishinkid08
fishinkid08's Avatar
Bronco Info: 94 5.0 xlt white on white
how do you take the panel off the knob for the headlights is in the way
fishinkid08 is offline   Reply With Quote
Old 10-14-2010, 10:24 PM   #5
BeastBronk
BeastBronk's Avatar
Do a search for the proper way.
I first took that panel off when I first got the truck and did not now how to do it. I just pulled the knob,which I dont recommended doing.
EDIT: http://fullsizebronco.com/forum/show...headlight+knob
EDIT #2: I didnt realize I linked you to your own thread.
Old 12-05-2014, 06:03 PM   #6
leatherneck
Bronco Info: '94' XLT
BeastBronk, your three images don't pull up!
leatherneck is offline   Reply With Quote
Old 12-05-2014, 09:06 PM   #7
Steve83
Banned
Steve83's Avatar
After 4 years, his IS account is probably gone. Click this & read the caption:
http://www.supermotors.net/registry/media/929775
Old 12-05-2014, 09:23 PM   #8
leatherneck
I've read that several times and still trying to grasp it.
The main goal right now is to get the dash switch to work.
I tested the switch terminals ohms and removed the ground to make sure it was clean.
I'm receiving power to the switch and no corrosion. The ground bolt was tight and the site shinny.
Old 12-05-2014, 10:20 PM   #9
Steve83
Banned
Steve83's Avatar
What ground bolt?
Old 12-05-2014, 11:05 PM   #10
leatherneck
It is for the dash switch and is attached to the driver side of the kick panel.
Old 12-05-2014, 11:19 PM   #11
leatherneck
G-201 L. Kick
Old 12-06-2014, 01:56 AM   #12
Steve83
Banned
Steve83's Avatar
The serial-switched polarity-reversing circuit used for the t/g & passenger windows is more complicated than it looks, and it requires BOTH switches be installed & functional when in their OFF positions. So the lack of response when using the dash switch doesn't exclude the possibility that the fault is in the the t/g key switch, the interlock switch, or any of the wiring. You have to check virtually everything: full logic of each switch; continuity of each wire (or voltage under load); battery voltage AND ground under load at the dash.
Old 12-06-2014, 06:27 PM   #13
leatherneck
WOW, I haven't even put a dent in it. My door windows roll up fast while my t/g using the eye is a lot slower.
Old 03-01-2015, 03:38 PM   #14
BeastBronk
BeastBronk's Avatar
Re-uploaded pics
  FSB Forums > Bronco Discussions > Technical Write Ups
You may not post replies
Forum Jump
