1990 Bronco SAS Project - FSB Forums
Thread Tools Display Modes
Old 03-18-2010, 06:07 AM   #1
2000F150SAS
2000F150SAS's Avatar
Finally getting pictures to everyone. Since finishing the SAS on my 2000 F150 my son wanted to do his 90 Bronco. As you watch our project remember this will only be a street and beach truck.
Thanks, John & John Jr.
[IMG][/IMG]
New oil pan gasket and oil pump installed
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
New engine crossmember, thanks for the help GKR.
[IMG][/IMG]
79 Dana 44, complete rebuild and ready to go in.
[IMG][/IMG]
1/2" steel plate for the use of TTB Coil Springs (More pictures to follow on this)
2000 F150 with SAS.
79 F150 Dana 44 w/4:88's and Manual Hubs
9.75 w/Disc Brakes & Posi w/4:88's
4.2L, 5 Speed, Manual Transfer Case
37"x12.5"x16"s, 38"x15"x16"s (Some day)
2000F150SAS is offline   Reply With Quote
Old 03-18-2010, 12:45 PM   #2
Mud-Nut
Mud-Nut's Avatar
Bronco Info: '79 F150
Looks good, really good. Nice work so far!!!
But, after going this far, you should tell your son to order some coils. TTB coils will be way too stiff for that solid axle. The leverage from the TTB design requires stiffer coils. Your sons Bronco is going to ride like crap with TTB coils. Just though I should give you a heads up. We we did a SAS on a Ranger, we used to TTB lift coils and ran into this issue.
2001 F250 Superduty
- 7.3L Powerstroke, ZF6 Swap, 5.5" Lift, 37" BFG's, and TW Tuned!
1979 Ford F150 - 14B FF, HP D60, Custom R/A, 460BBF, C6, 39.5" Boggers, and so on...
My Build Thread/Wheeling Pics! - GouletFilms.com
Mud-Nut is offline   Reply With Quote
Old 03-18-2010, 02:13 PM   #3
Shadofax
Owned 19yrs, now for 20
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
true, except maybe for the deaver ttb coils. I'd bet they are reasonble. If he's looking for beach and street he won't need anything too soft.
______________________
Click my supermotors link for tech on TCase, SAS, OBA, Soft Top, Overhead Console, Stock bumper Winch install, much more..:
http://www.supermotors.net/registry/628
Shadofax is offline   Reply With Quote
Old 03-18-2010, 11:18 PM   #4
AUBronco
AUBronco's Avatar
Bronco Info: 89 EB 302/ AOD/ 4:56/ Aussie Rear/ L/S front/ 3G/ 2.5" Lift/ 35" M/T's
Interesting. You planning on going with a low lift sas? If not why rebuild the cross member.
Patrick
89 EB Bronco: 302, AOD, 4:56's, Rear Aussie Locked, Front L/S and Warn Hubs, 35" M/T's, 2.5" lift . Sliders. More to come.
My supermotors page
AUBronco is offline   Reply With Quote
Old 03-19-2010, 05:55 AM   #5
2000F150SAS
That's are reason for using the TTB Springs, we want it to ride and handle stiff because it a street truck. I have the 79 springs in my 2000 F150 SAS and are to soft for me since i only do street and beach driving. I may switch to his setup once i feel how his Bronco rides.
2000 F150 with SAS.
Old 03-19-2010, 05:59 AM   #6
2000F150SAS
Reason for removing the orginal crossmember was to make access to the oil pan, since we had to replace the gasket. A lot of work to remove the orginal crossmember but still less work then trying to remove the pan with the member in.
2000 F150 with SAS.
Old 03-19-2010, 04:30 PM   #7
Mud-Nut
Mud-Nut's Avatar
Fair enough.... Sounds good dude.
Keep us updated.
2001 F250 Superduty
Old 03-23-2010, 05:33 AM   #8
2000F150SAS
First, I'll have updated picture this weekend. Planning on having the rear in with the jack stands under the rear instead of the frame.
Second, with a total of 7"-8" suspension lift will i have to lengthen the driveshaft? Remember it's street and beach truck.
Thanks.
2000 F150 with SAS.
Old 03-24-2010, 09:11 PM   #9
GearHead
GearHead's Avatar
Bronco Info: 95 xl 351 d60/10.25
The fabtec 8" 2wd ttb springs ride like a dream on the road. Flex halfway decent too. I had them for several years on my old bronco.
Five generations with an unlocked door and a loaded burgular alarm.
http://www.superford.org/registry/ve...il.php?id=2616
GearHead is offline   Reply With Quote
Old 03-24-2010, 09:13 PM   #10
GearHead
GearHead's Avatar
As for the drive shaft, it will also depend on how far forward you move the axle also. you'll probably have to wait till the axle is in and weight on it to see.
Old 03-25-2010, 05:18 AM   #11
2000F150SAS
GearHead!
Why 2wd TTB Springs over the 4wd?
Thanks.
2000 F150 with SAS.
Old 03-25-2010, 01:11 PM   #12
Brent484
Brent484's Avatar
Bronco Info: 89 Bronco
I really like the cross member. When i did mine i hated the bulky stock one
Brent484 is offline   Reply With Quote
Old 03-25-2010, 01:14 PM   #13
2000F150SAS
Thanks. We hated it also. I'll have updated pictures Monday, Spring Buckets modified and installed, shocks installed, brakes installed, etc.
2000 F150 with SAS.
Old 03-25-2010, 03:34 PM   #14
Dan Theman
Banned
Bronco Info: '89 351 c-6 leaf sas kp d60wzip locker 14bolt 42x15x15 rockers 5.38s
lotta work for a street and beach truck.
Dan Theman is offline   Reply With Quote
Old 03-25-2010, 03:46 PM   #15
benmarquart
benmarquart's Avatar
Bronco Info: 1993 Bronco, 351w A40D, 31 Mud Terrains
Someone could say the same for something we are either A. Throwing against the rocks or B. Throwing it into mud pits.
To each their own.
I will say I am damn jealous of how fawking clean and rust free the undercarrige is! wth man? lol
The only way to do things is....Go big or Go home!
benmarquart is offline   Reply With Quote
Old 03-25-2010, 03:51 PM   #16
2000F150SAS
To each their own.
Itís only way too much work if your not having fun. Besides this is my sonís first Bronco and reading all the SAS Project's on this site got him motivated to do something different in this part of NC.
We bought it from the orginal owner i work with here in NC. Has the typical rear fender well rust but that's it. The best thing is we only paid $1600 with 125k miles.
2000 F150 with SAS.
Old 03-25-2010, 10:37 PM   #17
Dan Theman
Banned
To each their own.
Some one could say that, but they'd be wrong. Not knocking the build. I think it's a great hobby, and a great father son bonding experience. I'm just saying seems like a waste to put in all that work for the street and beach. I'm sure there's stuff to climb in N.C.
Old 03-25-2010, 10:46 PM   #18
GearHead
GearHead's Avatar
Thanks.
I might be wrong, but I don't think that company makes a 6".
Anyway, several people on this site have run them and seemed pretty happy.
Thats where I got the idea to use them. I think they gave me about 7" lift.
Old 03-27-2010, 08:14 PM   #19
88-BrOncOxLt
88-BrOncOxLt's Avatar
Bronco Info: 88 bronco xlt 4x4 302
from the pictures that truck looks in great shape body wise..but why only a street and beach truck?
88-BrOncOxLt is offline   Reply With Quote
Old 03-28-2010, 07:20 PM   #20
2000F150SAS
We just like the solid axle look and to have somthing different then everyone else. I'm really glad i'm doing this project with my son since he just jointed the Army, college and working wasn't doing it for him. Once he leaves for boot camp in June i'm going to repair the rust in the rear quarters, remove the spare tire carrier and make a new rear bumper with tire carrier. Will post updated pictures Monday.
2000 F150 with SAS.
  FSB Forums > Bronco Discussions > Solid Axle Swaps
You may not post replies
Forum Jump
