art carr style shifter??? - FSB Forums
Thread Tools Display Modes
Old 02-24-2010, 02:08 AM   #1
JERAD121
JEEP CREEP
JERAD121's Avatar
Bronco Info: JEEP ZJ!!
ive got a 95 with the e4od can i use ane art carr style shifter in it. ive only seen them for the c6 trans. is there one made for my trans. or am i SOL?
JERAD121 is offline   Reply With Quote
Old 02-24-2010, 02:45 AM   #2
GKR
GKR's Avatar
Bronco Info: 79 Bronco XLT, 95 Bronco XLT, 96 Bronco XLT
96 with E4OD. When you order, you just specify the application and they will send you the correct end.
GKR is offline   Reply With Quote
Old 02-24-2010, 08:45 AM   #3
SoCalFSB
OMG its almost a
SoCalFSB's Avatar
Bronco Info: 1990 XLT, 351, and a bunch more
Greg's bronco always brings teh sex! I always wondered if they made a gate shifter for the E4OD, now I know!
Did you mount that straight to that sheetmetal or is there some sort of metal cage underneath the shifter?
SoCalFSB is offline   Reply With Quote
Old 02-24-2010, 10:47 AM   #4
GKR
GKR's Avatar
Old 02-24-2010, 11:45 AM   #5
JERAD121
JEEP CREEP
JERAD121's Avatar
Cool thanks man. Love the center consol. That's prettyclose to what I want to build
Old 02-24-2010, 01:36 PM   #6
Robs79bronc
Robs79bronc's Avatar
Bronco Info: 79 Bronco 400 4" lift, 38.5 mickey thompson baja claws, cut fenders
Yeah that is bad ass right there...
Robs79bronc is offline   Reply With Quote
Old 02-25-2010, 09:19 AM   #7
TimmyD
TimmyD's Avatar
Bronco Info: 1991 work in progress and 1996 Prerunner
Where did you order this shifter? Does this shifter allow you to bypass the computer to manually shift?
TimmyD is offline   Reply With Quote
Old 02-27-2010, 02:52 AM   #8
lifeinthesouth
Bronco Info: '95 5.0l e4od
I've always wondered... what do you do with all the stuff (stock shifter) on the column after installing the Art Carr.
--Mike
lifeinthesouth is offline   Reply With Quote
Old 02-27-2010, 10:46 AM   #9
Dustball
shibby
Dustball's Avatar
It's a mechanical shifter, does the exact same thing as the column shifter except in a different location. It doesn't have anything to do with the transmission electricals.
Dustball is offline   Reply With Quote
Old 02-27-2010, 01:07 PM   #10
GKR
GKR's Avatar
I just removed everything I could. You end up with the little nub on the column. I got the dashmounted overdrive butten from a mid 80's Bronco and mounted that in my dash. Just took the wiring from the column shifter and tied it into the button.
Old 02-27-2010, 05:01 PM   #11
PWMTN
PWMTN's Avatar
Bronco Info: Stretched 96 5.8 with many desert mods.
E4OD aftermarket shifters have 3 positions. For OD control you need to add a switch. If you want it to be a manual controlled tranny you need to buy a valve body. Most guys like a reverse body which gives you 1,2,3 and the thing will no longer shift automatically. You can use these shifters with a stock tranny and it will be D,2,1 just like stock.
PW
PWMTN is offline   Reply With Quote
Old 02-27-2010, 05:06 PM   #12
JERAD121
JEEP CREEP
JERAD121's Avatar
sweet thanks for the info guys I should be ordering one soon once i get my tax return.
Old 02-28-2010, 06:46 PM   #13
TimmyD
TimmyD's Avatar
So does this shifter bypass the computer? I called summit and they said the E40OD doesn't bypass the computer. I felt like they were not very sure of themselves though. They said my best bet was to go with a C-6, vaulve body and shifter to get around the computer.
Old 02-28-2010, 07:44 PM   #14
PWMTN
PWMTN's Avatar
[quote=TimmyD;2309718]So does this shifter bypass the computer? I called summit and they said the E4OD doesn't bypass the computer. I felt like they were not very sure of themselves though. They said my best bet was to go with a C-6, vaulve body and shifter to get around the computer.[/QUOTE
E4OD is computer controlled. The shifter has noithing to do with the computer. As I said you can install a manual valve body so you can control the shifts. The torque converter would still be controlled by the computer unless you install a manual switch setup.
The C6 is a 3 speed and has no torque converter lockup. A different tranny.
The C6 and E4OD shifter are the same item, but when used with the E4OD you need a switch to control the "OD Off" command. Read the other comments they are correct.
PW
Old 02-28-2010, 09:44 PM   #15
TimmyD
TimmyD's Avatar
Here is my issue. I have a 1996 Bronco with an E40OD. I've been racing it for almost a year now (transforming it from a pre-runner to race truck). recently I ripped out the dash and instument cluster and added new auto meter gauges in the new fabricated dash. my problem now is it won't shift properly after second gear. I had a transmission guy say that the E40OD is computer controlled and the truck is in safe mode.
I guess what I need to know is, being that my wiring harness no longer exists, is there a shifter and valve body that I can swap out without changing my transmission? Currently I can maually shift first and second just fine but when I go into drive it won't let me get over 3K RPM's. Real Wierd.
Old 02-28-2010, 10:53 PM   #16
justin
BRONCO WIZARD
justin's Avatar
Bronco Info: 96 XLT/5.0/E4OD
You removed the PSOM, probably responsible for some, if not all of your problems.
You have enemies? Good. That means you've stood up for something, sometime in your life.
-Winston Churchill
justin is offline   Reply With Quote
Old 02-28-2010, 10:58 PM   #17
Dustball
shibby
Dustball's Avatar
I agree.
The fuse for your radio is also for the speedometer and E4OD. No speedometer = no E4OD shifts.
Old 02-28-2010, 11:00 PM   #18
fbm1344t
fbm1344t's Avatar
Just swap to a c-6 and it should solve your problems, definitly need the comp in order to shift right.
95 F-150 XL, rebuilt 300/M5OD 3G
D44 SAS,35" General grabbers
9k winch, custom bumper
fbm1344t is offline   Reply With Quote
Old 03-01-2010, 01:12 AM   #19
TimmyD
TimmyD's Avatar
I guess I'm in the market for a C-6. Any suggestion on where to get one or is anyone selling one?
Old 03-01-2010, 09:08 AM   #20
Wheelin-Idaho
All over craiglist for dirt cheap, & tougher then nails...The shifters only run about 150-200 for them as well.
Just exploring the mountains in my trusty ol' Ford....
Wheelin-Idaho is offline   Reply With Quote
  FSB Forums > Bronco Discussions > BroncoSpeed
You may not post replies
Forum Jump
