Sky Manufacturing shackle Flip w/pics 56k warning - FSB Forums
Thread Tools Display Modes
Old 04-06-2004, 01:29 PM   #1
southrnpride69
southrnpride69's Avatar
Bronco Info: 1989 bronco 302, M5od, np208, 9" lift, extended radius arms, SAS, d44 dual battery,shorty headers
This is a very easy install and cheap wy of gaining lift.
The kit come with everything you need, the new hangers, grade 5 bolts washers and nyloc lock nuts.
first things first youll need to get some paint on the hangers I used automotive primer and flat black paint from a rattle can
A couple of tools that will make your life easier are an air chisel, impact wrench, and a grinder.
The first step after painting is to make sure you have a safe work area
If you dont have a set of those things above BUY SOME they are only 25 bucks and mine are 6 ton stands
Once everything is up and secure you are rady to begin removing the old hangers.
First thing is to remove the axle and rear springs to give you a little more room
this is where the impact wrench comes in those bolt can be difficult.
Once you have room to work it is time to remove the old shackles. They are rivoted on so you will have to get the rivots off. an air chisel works but there is ample room to get a 4.5 inch grinder in there so whatever is convienant for you I like spark so here I am
Once the rivots are all ground off I used a shop hammer to knock the hangers off of the frame and a round punch to knock out the rivots.
The Sky MAN hangers are designed to match the original bolt holes but you will need to run a 1/2 inch drill bit through the hole to ream them out so the bolts fit.
This next part I didnt get pics because I found out I needed a new gas tank and was Pissed sorry guys.
To boly the hangers on you will need to drop the gas tank so you can reach the inside of the frame. This is pretty sinple there are about 6 bolt on the front and rear of the skidplate. remove them and the tank will drop enough to reach the fuel lines disconnect them and move the tank out of your way.
after that simply bolt the hangers through the existing bolt holes make sure it is torqued down and replace the springs on your truck.
Reinstall your gas tank,and axle and youre in business. remember to bleed your brakes when reattach the brake line to your axle.
I didnt reuse the factory ! inch block and my pinion angle is near perfect. The flip does also move you axle forward about 1 inch.
Here is a base line of where I started this measurement is with the factory block
and here is the end result WITHOUT the factory block
Here is a comparison of the factory hangers and the sky man hangers notice tha difference in thickness
Now here are some other opinions / lessons learned
1. I recomend buying extended brake lines
2.I have heard people say they are worried about something breaking If you are worried about that weld the hangers to your frame but I dont feel It is neccassary
3. This is also a good time to replace old bushings in your spring and shackles.
4. if you still have the factory bolts hold the springs REPLACE them with a good new grade 8 bolt mine were severly worn
5. This flip can also be done with hangers from a F-250 or 350 but for the price ($150) shipped to your door These are well worth it they are well made very beefy and you dont have to go to a junk yard and spend all day removing them.
Also there are some more pics on my Superford account. I hope this helps some of you guys
89 EFI 302 M5OD-np208 8" lift
long tube headers and dual exhaust
35x12.50 wrangler MTRs
Stone Crusher steering
Warn Brushguard w/8000 lb warn winch
coil sprung SAS 4.09 gears w/traclock
extended radius arms superwinch supreme hublocks
8.8 rear 4.10 gears w/guick lock
shackle flip, Dual optima blue tops.
My sfo page
southrnpride69 is offline   Reply With Quote
Old 04-06-2004, 01:35 PM   #2
jrdbronco
I killed Kenny...again
jrdbronco's Avatar
Bronco Info: '92 bronco 351W E4OD BW1356, D44 SAS, 4.56 r/p f&r, spooled D60, 9" of lift, cutout flares
looks good, thanks
92 bronco with lots o' goodies
Originally Posted by Johnski at RITS
I ABSTAIN FROM ABSTAINANCE
Originally Posted by Ogeechee4x4 at RITS
Hey come here, I've got wood
my superford page
HIT IT ~N~ GIT IT OFFROAD!!!
jrdbronco is offline   Reply With Quote
Old 04-06-2004, 01:39 PM   #3
PaulT
Master of the Estate
PaulT's Avatar
Bronco Info: '71, 4" lift, Rebuilt 302, Edlebrock carb/intake, MSD ignition & dizzy
Great shots, thanks for sharing.
"I like sparks" + "need a new gas tank" =
PaulT is offline   Reply With Quote
Old 04-06-2004, 01:41 PM   #4
jrdbronco
jrdbronco's Avatar
so he likes playing with fire . so do i. although sparks near a bad tank might make me kinda nervous
my superford page
Old 04-06-2004, 01:56 PM   #5
southrnpride69
yeah that sucked I first smelled the gas leaking right after I finished grinding.
My sfo page
Old 04-06-2004, 11:46 PM   #6
Drilim
FSB's Bastard Child
Drilim's Avatar
Please tell me instead of the grade 5 hardware that came with the kit, You went and bought grade 8 hardware and hardened washers....
Other then that, It looks good.
-Zach
http://www.superford.org/registry/ve...il.php?id=3814
Originally posted by Keith_L
But it'll get better with more strokes and at higher speeds...
Originally posted by RavenTBK
With my luck, I'd end up putting undue stress on my balls and screwing them up to the point it will take a helluva lot more than $115.00 to get them fixed.
Drilim is offline   Reply With Quote
Old 04-07-2004, 12:20 AM   #7
chevytofordconverzon
chevytofordconverzon's Avatar
Bronco Info: 79 351m
great! thanks...im lookin to put those on my beast, looks like my tail pipe is gona be in the way though. I figure ill cut it off right near the springs and add one of those after market chrome deals and point it down and out...
DIRTBAG
79 xlt 33`s ( headers, 4.09 front 3.50 rear gears brand new paint, all scratched up duckt tape and a prayer
chevytofordconverzon is offline   Reply With Quote
Old 04-07-2004, 09:30 AM   #8
stangmata
WTF,O
stangmata's Avatar
Bronco Info: Bronco-less
Nice!
You have any before and after pics of the entire truck?
stangmata is offline   Reply With Quote
Old 04-07-2004, 09:45 AM   #9
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E40D, D44 SAS w/Trutrac, Detroit locked 8.8, MAF conv, Tweecer tuned..
I didn't know you had to drop the gas tank to do that...That sucks.
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 04-07-2004, 09:59 AM   #10
GearHead
GearHead's Avatar
Bronco Info: 95 xl 351 d60/10.25
you dont have to jer, but at least remove the bumper. unless you got really small hands.
Five generations with an unlocked door and a loaded burgular alarm.
http://www.superford.org/registry/ve...il.php?id=2616
GearHead is offline   Reply With Quote
Old 04-07-2004, 10:16 AM   #11
jermil01
jermil01's Avatar
okay, that's what I thought.
Old 04-07-2004, 01:10 PM   #12
GearHead
GearHead's Avatar
but those two front bolts of that bracket are a lot harder to get to with the tank in the way.
Old 04-07-2004, 02:14 PM   #13
jrdbronco
jrdbronco's Avatar
calling all midgets!!!!
my superford page
Old 04-07-2004, 03:11 PM   #14
HiLander
HiLander's Avatar
Bronco Info: '96 Bronco XLT - 351ci
Looks good, man.
What did you use to add lift to the front of the truck?
HiLander is offline   Reply With Quote
Old 04-07-2004, 03:26 PM   #15
TTBlows
TTB Hater of course
Didn't Phil already do a write-up on this?
Totally Twisted and Broke makes me a saaaad Panda
"You can almost see the dismay on Phil, Paul & Bob's faces when Trautwig is talking....and the pause in their voices after he stops....after which they pick-up the pieces of his non-sensical commentary and continue with their telling of the story that is the Tour de France! "
TTBlows is offline   Reply With Quote
Old 04-07-2004, 05:20 PM   #16
southrnpride69
Stangmata I have before and after pics on my superford the after pic is in the shackle flip folder, you cant tell much difference though because it already had the 6 inch lift
chevytofordconverzon I had to cut the tail pipe off but it was rusted out any way so I just cut it behind th muffler.
Drilim I used the grade 5 I dont think it will be bad the plate against the frame Is 3/8 plate so it wont flex the pressure will be distributed evenly to all 4 bolts If I ever do think it will be a problem I will go back and weld the hangers in place.
Jermil You probably could go in from the back if you remove the bumper but the Gas tank givs free and easy access to the bolt holes
My sfo page
Old 02-21-2005, 06:14 PM   #17
badass1tonf100
Hit it n' Git it
badass1tonf100's Avatar
Bronco Info: 4 wheels, 1tons, 3 sticks, sheet metal & some tubing.
when you take off from the light does the wheel hop like its trying to gain traction ? im seriously thinking to do the swap but id like to know more before i do i have read all forum in reguards to it.
badass1tonf100 is offline   Reply With Quote
Old 02-21-2005, 08:41 PM   #18
GearHead
GearHead's Avatar
i havent noticed any wheelhop on the street. or the trail for that matter yet.
thats running 36's 4.88's and a locker.
Old 02-21-2005, 09:19 PM   #19
collinsperformance
I got tools-i can fix it
Bronco Info: 1983 Full Size Bronco
i driven mine about 30 miles now--no wheel hop on the street. it rides great. i hoping the new springs come in to lift the front a couple inches to lessen the rake some.
mike
collinsperformance is offline   Reply With Quote
Old 02-22-2005, 10:49 AM   #20
csn.rebel
A True Sailor
csn.rebel's Avatar
Bronco Info: 88 Bronco, 351 roller .030 over, GT40P heads, AOD, 6" lift, True Dual exhaust, 35" Dualler MT's
Hey Southern, mine come in this week and next week i should have my new rear bumper, so what i am getting at is you busy next week? Got a nice warm shop, and a coffee maker
My 88'
csn.rebel is offline   Reply With Quote
  FSB Forums > Bronco Discussions > Technical Write Ups
You may not post replies
Forum Jump
