I got tired of looking for these replies whenever one of the regular questions comes up. So I'm throwing them here to be refined & reused as needed. These are by no means the complete answers to these questions, but are meant to be taken as part of the info available. It's better to read the complete threads that contain the other answers too.
Feel free to correct mine or add your own. Post it up here & I'll add it to the contents in post 1. Just use the same Q & A format. If you have more info on something that's already there, just use the same number as the original question, & I'll add it on the same line. If we all kick in answers to these common questions, we should be able to cover a lot of ground.
....0- Contents (Post 1)
....1- What year Bronco should I buy? (Post 2)
....2- What are common problems to watch out for when buying a Bronco? (Post 2)
....3- How do I fix my back window? (Post 3)
....4- How do I post pics? (Post 4)
....5- How do I add a little picture under my name at the left of the screen? (Post 5)
....6- How do I change the stuff under my name at the left of the screen? (Post 5)
....7- How do I add a signature under my posts? (Post 5)
....8- Why doesn't my signature always show up? (Post 5)
....9- How do I Bleed My Brakes? (Post 6)
....10- My Rear ABS light comes on (87-92). Why? (Post 8)
....11- My Rear brakes drag (87-92). Why? (Post 8)
....12- Will 33 inch tires rub on my Bronco? (Post 9)
....13- What do the axle gear ratio numbers mean? (3.55:1, 4.10:1, etc.) (Post 10)
....14- Which gears are higher or lower? (Post 10)
....15- What gear ratio do I have? (Post 10)
....16- If I change the rear gears do I have to change the front too? (Post 10)
....17- How do I choose the right gears? (Post 10)
....18- Where can I find info about my Holley carburetor? (Post 11)
....19- Why does my engine stumble when I step on the gas? (Post 11)
....20- Why won't my tailgate open even if the window is rolled all the way down? (Post 12)
....21- I'm going to visit the Los Angeles area. What is there to do? (Post 13)
....22- My Bronco doesn't have an exterior tire carrier. Can I add one? (Post 14)
....23 -My Bronco won't turn over (Won't crank, start, make the Rrrr Rrrr Rrrr sound), but makes a screeching, grinding, clicking, or buzzing noise, or no sound at all, when I try to start it. Why? (Post 15)
....24 -My starter keeps running. Where do I start? (Post 16)
....25 -My bronco won't start. It cranks over but has no spark, why? theramsey3 (Post 17)
....26-What Transfer Case Do I Have? Ziggy (Post 21)
....27-I found a 2wd transmission that I want to use. Can I simply unbolt the tailhousing and bolt on a t-case adapter? Dustball (Post 22)
....28- I'm trying to start a vehicle that has been sitting for a long time. What should I do? (Post 23)
....29- My truck has a vibration. How do I check U-joints? (Post 24)
....30- How do I test my hubs? (Post 25)
....31- How do I know my transfer case is engaging? (Post 25)
....32- How Do I Operate My Manual Hubs? (Except for 87 to Early 88 Flange Type Hubs) miesk5 (Post 26)
....33- How do I test my 96's Automatic Locking Hubs? miesk5 (Post 26)
....34-How do I test my 96's Manual Locking Hubs? miesk5 (Post 26)
....35- How Do I Test Manual Locking Hubs? (Except for 87 to Early 88 Flange Type Hubs) miesk5 (Post 26)
....36- How Do I Troubleshoot the Borg Warner 1356 Electric Shift-On-The- Fly (ESOF) Transfer Case & Locking Hubs? miesk5 (Post 26)
....37- Will Changing Just Two Tires to a Different Size (Diameter/Circumference) &/Or Air Pressure Difference Affect My Bronco in 4x4 Mode?
..........miesk5 (Post 26)
....38- Why do I need 75 posts to see the classified section? (Post 27)
....39- Should I install a Flex Fan on my Bronco? (Post 28)
....40- Do I need 30 Posts to start a Thread on FSB? (Post 29)
....41- How do I ask questions without 30 Posts? (Post 29)
....42- My posts don't seem to be counting. Why? (Post 29)
....43- I am new here. How do I get started? (Post 30)
....44- What is Top4x4 & what is the voting about? (Post 31)
....45- How do I check for bad u-joints? (Post 32)
....46- My driveshaft makes a "ringing" sound. Why? (Post 32)
