The 408 Stroker is finally built and installed in the truck. Still need to finish the MAF Upgrade and decide on whether to change to an AKCO Lighting EEC for tunability. Then initial break-in and onto the Dyno for a custom chip. Target is 350+ HP and 500+ TQ at the flywheel.
MAF Upgrade
Ford F150 EEC - WAY1 (F5TF-12A650-JB)
Pro-M Racing 75mm Mass Air Meter
RJM Injection Technologies Truck MAF Conversion Harness
Distributor Mount TFI Module
Single Narrow Band Oxygen Sensor
DynoJet Performance Tune w/Custom Chip
Engine
Factory Ford 351W Block, Bored 0.030, Honed, Decked
Eagle Forged 4340 Steel Crankshaft
Eagle Forged 4340 H-Beam Connecting Rods
SRP Forged 31cc Inverted Dome Pistons
Speed Pro Plasma Moly Rings
Clevite H Series Main and Rod Bearings
Pioneer SFI Race Harmonic Balancer
Pioneer Heavy Duty Flexplate
Fully Balanced Rotating Assembly
AFR 185cc Outlaw Street Cylinder Heads
Full Head Porting
Fel-Pro Performance Head Gaskets
Comp Cams Xtreme Energy Hydraulic Roller Camshaft 35-351-8
Comp Cams Pro Magnum Retro Fit Hydraulic Roller Lifters
Comp Cams Hi-Tech Push Rods
Comp Cams Pro Magnum Full Roller 1.6 Rocker Arms
Cloyes Double Roller Timing Set
ARP Main Studs
Milodon 4x4 Oil Pan
Milodon Oil Pick-up Tube
Melling High Volume Oil Pump
Modified Lokar Flexible Oil Dipstick
Aluminum Performance Water Pump
High Torque Mini Starter
Super Duty Poly Motor Mounts
Ford Racing Tall Polished Aluminum Valve Covers
ARP SS 12-Point Fasteners Throughout
Intake
Custom Air Intake w/K&N Filter
Edelbrock Performer Intake Manifold
Intake Porting
BBK 56mm Twin Throttle Body
Exhaust System
Bassani SS Ceramic Coated Equal Length Headers
Remflex Exhaust Gaskets
Bassani SS Y-Pipe w/SS High Flow Cat
Bassani SS High Flow 3” Cat Back Exhaust
Fuel System
Holley/Walbro 255 lph In-tank Fuel Pump
Accel High Impedance 42 lbs/hr Fuel Injectors
Professional Products Powerflow Fuel Rail
Professional Products Adjustable Fuel Pressure Regulator
BBK Rail Mounted Fuel Pressure Gauge
Canton Racing Products High Flow Fuel Filter
Ignition System
MSD Pro-Billet Distributor
MSD Steel Distributor Gear
MSD Cap & Rotor
Distributor Mount CCD TFI Module
MSD 6A Ignition Control
MSD Ignition Harness
MSD Ignition Noise Filter / 26 KUFD
MSD Blaster TFI Coil
Accel 300+ 8.8mm Race Wires
DEI Protect-A-Boot Spark Plug Heat Shields
NGK Spark Plugs
1 Gauge Power/Ground Wire Upgrade
408 Stroker, Edelbrock Intake, AFR 185 Heads, Comp Cams Extreme Energy Cam.
All Forged Internals, Fully Balanced Rotating Assembly, Blueprinted and Full Porting.
Professional Products Fuel Rail, Adjustable FPR, Accel 42 Lbs/Hr Fuel Injectors and RJM Injection Technologies MAF Upgrade Harness.
Crossover fuel line modification due to interference with ECT Sensor.
Pioneer SFI Race Harmonic Balancer and Milodon 4x4 Oil Pan.
Custom Bassani Y-Pipe modification to fit around Milodon Oil Pan.
4" Rancho lift, Bushwackers, Holbrecht Side Bars, 4.56 Gears and 33x12.50x15 BFG AT KO on Alcoa Wheels.
More pics to come. :thumbup
MAF Upgrade
Engine
Full Head Porting
ARP Main Studs
Milodon 4x4 Oil Pan
Intake
Intake Porting
Exhaust System
Fuel System
Ignition System
MSD Cap & Rotor
NGK Spark Plugs
