| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
infamous clunk
#1 |
iTrader: (1) Bronco Info: 96 Bronco XL, 302c.i., 6" lift, 35" bfg
infamous clunk
i have developed the infamous clunk when i put it in gear.
: especially reverse. i'm not exactly sure what to search for to find the answers i need. i somewhat remember reading about it, but i don't remember what the problem was. ![]() can anyone help me out or point me in the right direction. thank you mike |
| Sponsored Links | |
Advertisement |
#2 | |
IM FAT, YOUR UGLY!
iTrader: (4) Bronco Info: '85 FS - 5.8 351 (Edelbrock 1406 4brl) - C6+NP208 - Shorties - Flowmaster 40 - Stock Height
U-joints going out on the driveshaft, slip shaft needs greasing or 3rd member is warn and loose. get under and see if there is any side to side movement with the ujoints on the shaft, there shouldnt be any side movement at all.. than grease your slip-joint (search) and go from there...
'85 Custom - 351w - Edelbrock 1406 - CompCam Cam - Edelbrock Timing Chain -
Shorty Headers - Magnaflow Cat + Flowmaster 44 - C6+208 - 31" Tires [DD] '84 XLT - 302 - Stock - Flowmaster 44 - C6+208 - 32" Tires |
#4 |
Driving Stuff Henry Built
![]() Join Date: Oct 2006
iTrader: (7) Bronco Info: -90 xlt, 351w, e4od, 3.55:1, sag, warn hubs, trans cooler, 33" bfg m/t, -73 351m, 3 speed, 35s
When you check the u-joints as Spiked described, park it on a flat spot, block the wheels & put it in neutral. That way the driveshaft will be free to move if the u-joints are bad.
Pepe`s Bronco Build -At Gilla's in Oregon, Waitin' for the Sun -Click for the thread Baba Looey's Favorite FSB Links........................Common Replies to FAQs ![]() “Don't find fault, find a remedy.” -Henry Ford |
#5 | |
It's BTW Not AKA!
iTrader: (0) Bronco Info: 92 F-150 4x4, 302, BBK Shorties, Flowmaster Duals, M5OD, 2" Rancho Coils, 33x12.50 M/Ts
My money is on u-joints or the slip shaft.
1992 F-150 4x4 East Coast Firefighting- Only the Best http://www.supermotors.org/vehicles/...il.php?id=4768 Quote:
#6 |
Hi, what is the slip shaft? I have a bad clunking when the Bronco is moving up and down. I had my friend rock the rear of my 96' Bronco while i was under the truck and the rear drive shaft would clunk pretty good when it was moving in and out of the tranfer case. Is this the slip shaft that plugs into the transfer case? Is it even suppose to slide in and out like it did? The rear drive shaft was sliding in and out about 1/2" into the transfer case when the truck was bouncing up and down.
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
