| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
miss firing
#1 |
miss firing
i have a 1992 bronco with a 302 in it and i changed the wires and its miss firing really bad. the engine is also shaking the car really bad at idle. its also making a poping sound a lot. any ideas?
MY THROTTLE IS AN ON/OFF SWITCH |
| Sponsored Links | |
Advertisement |
#2 |
![]() Join Date: May 2009
iTrader: (0) Bronco Info: 1991 F250 4x4, 351W, ZF5, 1356 tcase, 4.10 LS rear, Hooker headers
did u put wires in exactly the same place? also make sure they are all seated on distributor and on the plugs?
Sold the bronco, got something close! [Gillamonster] 10:16 pm: i made him pay me gay 78'460] 11:12 pm: lol i thought i was gay. just my opinion |
#3 |
yeah i checked the haynes manual for the firing sequence and i put the wires on in the right order. and i checked that everything was on real tight but still nothing. i just bought the truck about two months ago and i just changed the wires. the order the previous owner had them on was different from what the manual said. it has a rebuilt motor in it so im thinking it might be different. i tried them in both the right order and what was previously on there and nothing seems to work.
#4 |
you might have bad wires. where'd u get them from? take 'em back and see if new ones work better. did u change plugs? or do anything different?
#5 | ||
Satyr of the Midwest
There's an "older" firing order and a "newer" firing order for the 5.0L engines.
Newer: 1-3-7-2-6-5-4-8 Older: 1-5-4-2-6-3-7-8 Notice the "3-7" and "5-4" are essentially "swapped," and that the distributor rotor rotates counter-clockwise. Have you pulled the plugs and made sure that they're all in decent shape? You could have a broken plug or one(s) that isn't/aren't firing correctly, dumping fuel into the exhaust system & contributing to the unevenness at idle.
SigEpBlue Wheelin' across Michigan from Ida to Grand Rapids, baby! ![]() Quote:
#6 | |
iTrader: (0) Bronco Info: 1993 EB, 5.0, E4OD - All stock for now. Replaced the 88 that the drunk totalled :(
#7 |
i put new plugs in about a week ago so those are good. i tried both codes sigep said and niether worked. i also pulled the new wires off and put the old ones back on and still nothing. now it wont even turn over. something is seriously messed up now.
#8 |
Sounds like it may be something more. But if it ran ok before you changed the wires, then you must have gotten something wrong, like the location of the wires.
#10 |
the wires are in in the right order for the firing order so its not that. i got it to start up today but it was running like garbage. i put a new cap and roter in but its flooded now so i pulled the plugs and im gonna let it air out for a while and see if that helps.
#11 | |
balls deep with my
![]() ![]() Join Date: Feb 2003
iTrader: (3) Bronco Info: pile of parts
Like I said, from what you have posted it ran fine, you changed the plug wires and it no longer runs. this means the wires are not installed correctly. ![]() |
#12 |
iTrader: (0) Bronco Info: 1996 Ford Bronco XL 302 W/E4OD
Just because the manual shows it that way doesnt make it correct, I have a Haynes, a Chiltons, and the ford CD and one of them is incorrect. so recheck your plugs locations on the cap
#13 |
I suppose he could do a very rudimentary check: run a pseudo-compression test with a degree wheel on the crank snout; I say "pseudo-" since he'd not really be checking compression, but he'd at least be able to see in which order the cylinders are on their compression stroke. That way, he can a) ascertain that each cylinder is actually compressing the gases (to some degree at least), and b) he can see where the rotor is pointing on the distributor cap and then relate it to the crankshaft position. Should come out with a right-on firing order, regardless.
#14 | ||
You must keep in mind a few points about any used vehicle when attempting to work on it:
Here is the procedure for getting it straightened out: (you may need help, as another pair of hands make this a lot easier, but it can be done solo on an FSB,)
Don't forget to set your base-timing after you get it running smoothly. It is possible that someone installed an "old" firing order camshaft. Since these engines are batch-fire fuel injection, they will still run ok with that cam installed. SEFI would not run well at all, though. Good luck. |
#16 |
Kinda like reconnecting the fuel line after setting your timing on an early body style Bronco. Putting out a fire while you're hovering over the motor is exciting.
#18 |
i did something different to check my number one position for the rotor. i pulled the number one spark plug and put a hanger in the hole and turned the crank shaft till it was at its highest point. then i checked the rotor and it was pointing to the number one position and i have the wires going from the cap to the plugs counter clockwise in the correct order. i also checked the timing and it is right on. so far i have put in new plugs, wires, cap, rotor, coil and it is still firing up really hard and running rough. i cant figure out what the problem is and its driving me crazy.
#19 |
Number 1 on TDC (Top Dead Center happens twice for each combustion cycle. To make sure #! is at TDC, if you are going to put something inside the cylinder, just put your finger over the spark plug hole and when you feel pressure, then stick your hanger in there to get the top. Then pull your cap. Wherever it is pointing, that is #1. I bet someone in the past stabbed the dizzy in wrong and adjusted the wire locations on the cap to compensate.
#20 | |
balls deep with my
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
