| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
swapping e40d for c6 in 88 351?
| Sponsored Links | |
Advertisement |
#2 |
Guest
meh...were it me I'd swap the c6 for an AOD. The E4OD is completely and utterly computer controlled...you'll either need a ECU from a truck that came with your engine and the E4OD tranny..you can always buy a standalone unit like the baumanator...http://www.baumannengineering.com/tcs.htm...IMO it's too much work...
#3 |
Some assembly required!
![]() Join Date: Aug 2004
iTrader: (23) Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
The first two things that come to mind are that you'll need a rear axle with a tone ring in it like an 8.8 or a 10.25, and you'll need the right ECM to run it, and the associated wiring. Probably need the E40D cross member too, plus the correct shift linkage.
#5 |
iTrader: (0) Bronco Info: 1992 Bronco XLT ready for test drive
If you can get the E4OD for cheap, buy it and keep it. There are people looking for them and you can make some money on the deal.
1997 Expedition - Daily driver at this point 1992 Bronco XLT - Soon to be double duty truck 1993 F150 - Offroad/plow truck 1993 Ranger - Wife's truck I have an addiction to wrenching, and there is no cure. |
#6 | |
iTrader: (0) Bronco Info: 1993 EB, 5.0, E4OD - All stock for now. Replaced the 88 that the drunk totalled :(
#7 | |
![]() Join Date: Dec 2003
iTrader: (0) Bronco Info: Tore down, Beat down, just F*CKED.
I am in the process of doing this right now. Fortunately. I have a 90 Bronco that was the donor, and everything that was on the 90. I have put onto my 88. All wiring from the engine compartment to the rear of the chassis.
Rescue Bronc, I believe has done this swap as well. For me, and the way I am doing it. It hasn't been easy. Course, I am doing an engine build as well. LOL, I am going to be doomed with problems. ![]() The main parts you will need is the engine wiring harness, ECU and the E40D together. I was informed that you can splice in the O/D button, so , you wouldn't need the chassis wiring. And deal with the behind the dash wiring. I said screw it, I have all of it, I am using it. You wil have to drill new holes on the chassis for the E40D's crossmember. Driveshafts that went with the E40D. I am sure I am missing something, maybe someone else will chime in. Best bet is to get the whole vehicle that you are getting the tranny from if possible IMO.
88'/90'/91 XLT Bronco,393W w/Pacesetter headers,35X12.5 BFG KM2 M/T's,7inch Rough Country Lift,D44 Locker , Locked 8.8, 4:11 gears E4OD ![]() Quote:
#8 |
iTrader: (5) Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
it isn't that hard
hell I installed a E4OD into a 1979 4x4 and installing one in my fourdoor bronco which is also a 1979 if you can read a schematic installing it in a 88 will be pretty straight forward the 88 already has a tone ring on the rear that started in 1987 not real sure if that is needed for the ECM if you have a VSS on the Tcase if you find a donor rig for the tranmission crossmember 89-91 be easies however 92-96 stuff should work as well find a ECM for 351/E4OD the transmission has its own harness no need to change the chassis harness you do need to add the pins in the ECM plug on your original harness (thus the schematic) Fireguys site has the schematics and pinouts listed
Trent NORTH COUNTRY SPECIALTIES Picador (1979 4door Bronco) 79 Ford CrewCab 4X4(My Dually Project) 79 Ford Bronco and My Boat |
#10 |
SOD BUSTERS Member
![]() Join Date: Apr 2004
iTrader: (14) Bronco Info: '92 Street Queen, '78 Beater
I am wanting to go the other way in my '92. Maybe we could trade some parts?
I am not quite ready to do it yet though.
![]() '92 Eddie Bauer- 6" lift, 351W, 4" Stainless Exhaust, 18" Weld Wheels, Subaru WRX seats '78 Custom- 4" Superflex Lift, Mild 460, 8 Point Cage, 4.10 Gears, 35" MTZ's |
#11 |
iTrader: (0) Bronco Info: 1988 Bronco Custom 351
maybe we could trade some parts here in the future. if you are in south bend thats not to far from yorkville il. i'm not quite ready to do anything with my trans just yet though. i'm sill looking for a set of gt40 heads. got any?
#12 | |
How do you address the VSS?
How do you address the Vss? I am installing a 94 5.8, E4OD, and BW transfer into my 79 Bronco. I was thinking on keeping my 205 until I seen the problem you run into. That will save me a-lot of aggrevation. I have the 94 as a donor so I have everthing I need except a way to address the VSS. Also does your 460 have the 1/4 inch hose that comes off the intake and goes to the radiator? If so how did you address that while keeping the 79 radiator?
I think your truck is Awesome, you are quite talented. Thanks. Quote:
#13 |
I think your truck is Awesome, you are quite talented. Thanks. |
#14 | |
the rear axle sensor is intended for the ABS and in 92 also did the duty for the cruise and ECM via a little conversion box my year of 460 didn't use the 1/4" hose so that issue never came up |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
