Super Easy Dana 60 SAS - F250 - FSB Forums
Thread Tools Display Modes
Old 10-05-2008, 01:13 AM   #1
bossind
Retired Staff
bossind's Avatar
Bronco Info: 1996 EB Bronco, 5.8, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
This is literally a bolt on SAS, I'm posting it for a point of reference. The dana 60 and brackets came from a 96 F350.
Like all ford SAS the TTB has to go!
Torch makes for a fast removal, here we cut the U bolts
Cutting the pivot bolts
This is the track bar bracket from the F350, interesting how it mounts behind the axle.
Slide the 60 under the truck
The painted leafs are off of the f350, non painted leafs are from the F250
Notice the arch difference between the leafs.
Springs are mounted and the Dana 60 is hung from them.
At this point we are 4 hours in.
Company.
bossind is offline   Reply With Quote
Old 10-05-2008, 02:15 AM   #2
ToddACimer
Engineer
ToddACimer's Avatar
Bronco Info: 11 F150 CC 4x4
That was too easy. Great pics. Are you going to be using the stock F350 track bar and steering too? Is this that D60 you posted a few weeks ago or is it another one?
Recipient of multiple driving awards from State and Local officials.
ToddACimer is offline   Reply With Quote
Old 10-06-2008, 10:34 PM   #3
bossind
Retired Staff
bossind's Avatar
These are the hubs off of the Dana 50, and if we are right they will bolt right on.
The spindle on the left is the dana 50 and the one on the right in the Dana 60 Dually.
Dana 50 left, 60 on the right.
Hub rebuilt with new bearings, selas and loaded with a new rotor.
Spindle installed
Just as we thought, the dana 50 hub bolted on with out issue
New bushings for the track bar
Check out the track bar!
Old 10-06-2008, 11:14 PM   #4
Need4racin
Banned
Bronco Info: 96 XLT 302/E4OD & 90 EB 302/AOD
oops, nvm
delete please.
Need4racin is offline   Reply With Quote
Old 10-06-2008, 11:23 PM   #5
scott 351 wins
scott 351 wins's Avatar
Bronco Info: 1985 xl 300/c6,f 250 tow rig,1946 rat rod ford truck
those hubs are from a ttb d50 or a solid dana 50?
Originally Posted by IronHorse! View Post
man somebody should be doing a product review on his mothers vagina hole it's popping out pure stupid
scott 351 wins is offline   Reply With Quote
Old 10-06-2008, 11:56 PM   #6
chambiec1
chambiec1's Avatar
Bronco Info: Chevy, dodge... No bronco
TTB 50... the solid D50 from the newer superduty trucks would be a different bolt pattern than the older 8-lug rigs.
My Superford
[dougs89] 1:57 am: i was flipping through channels and saw an old man with wood
[chambiec1] 1:57 am: like dick wood?
[dougs89] 1:58 am: no like big piece of wood wood
-Just call me "Casey"
chambiec1 is offline   Reply With Quote
Old 10-07-2008, 12:18 AM   #7
Worn Out F150
User that is Registered
Worn Out F150's Avatar
Bronco Info: 92 F150 Custom SCLB 4.9, M5OD, Sag pump, T-bird calipers, half complete 4x4 conversion
Originally Posted by Need4racin View Post
Why do the d50 ttb leaf springs look stiffer and more heavy duty than the f350 solid axle leaf springs?
Because they are
♪They see me trollin, they hatin... Moderatin and tryna catch me postin dirtay♪
Worn Out F150 is offline   Reply With Quote
Old 10-07-2008, 12:27 AM   #8
bigbrownbear
Formerly vt89gtvert
bigbrownbear's Avatar
Bronco Info: Brown 88 XLT, 302, c6, 32 BFG's
Two things, first it took me a while to figure out what the hell was on the end of the D60 spindle.
Second the difference in the back flange would make me a little scared to run that D50 on a D60.
I seam to recall a post by MR. N at some point in time covering this issue, but a quick search here and on PBB found nothing......
Poster formally know as VT89gtvert
"Depression is merely anger without enthusiasm"
"The problem with the gene pool is that there are no lifeguards"
bigbrownbear is offline   Reply With Quote
Old 10-11-2008, 10:57 PM   #9
bossind
Retired Staff
bossind's Avatar
Thats the only difference in the spindles between the Dana 50 and the dana 60 dually. So no need to change the spindles.
Old 10-12-2008, 01:28 AM   #10
jagular7
Bronco Info: 1992 Custom
With the leafs locating the axle, why run a track bar?
That only puts the suspension into a bind in the springs bushings as it cycles up/down, its also being pushed/pulled to the side from the track bar.
Jagular7
Lenexa, KS
jagular7 is offline   Reply With Quote
Old 10-12-2008, 08:21 AM   #11
bossind
Retired Staff
bossind's Avatar
These trucks are work trucks, not play trucks. The suspension doesn't move much. It keeps the axle center and takes the play out of the spring bushings and with out the springs would bend sideways,
Like when your using this.
Old 10-12-2008, 12:23 PM   #12
The Ric
MORTAL KOMBAAAAAAATTT!!!!
The Ric's Avatar
Bronco Info: 88 EB custom dents, and rust.
Hey Boss, you get to do this work on the clock?
Not to sure what to put in my signature anymore.
1988 Ford Bronco EB - 2010 Chevy Malibu - 2009 Cannondale Six5 - 2013 FELT F75X
The Ric is offline   Reply With Quote
Old 10-12-2008, 06:50 PM   #13
bossind
Retired Staff
bossind's Avatar
Nope just a hobby for now.
Old 10-15-2008, 12:27 AM   #14
RedBEAST
RedBEAST's Avatar
Bronco Info: 83, 302, t-18, Np-208
Very nice looks like it belongs there . . . . oh wait it does, are you eventually going to do a front RSK?
83 bronco 302 and 96 f250 hopped up powerstroke on 35's
RedBEAST is offline   Reply With Quote
Old 06-13-2009, 10:42 AM   #15
Slimline
Hey this thread has been very informative in my decision to purchase an f250. I plan to SAS and give it a bit of lift to run at least 38"s. I have a 96 f150 now with a 6 + 3 running 35"s but hate the TTB and want the 7.3 PSD. For better flex etc is it better to not run the trac bar? Will I be running the risk of damaging my front end components? Also, do the F350 springs lift it up at all or do they sag to pretty much the same height of stock?
Thanks,
Rob
Slimline is offline   Reply With Quote
Old 06-13-2009, 10:52 AM   #16
reptillikus
ate lug
reptillikus's Avatar
Bronco Info: 88ish bronco(?)/96 F250; both with D60s
You *need* the tracbar if you intend to drive it on the road. You can forget about flex; those trucks DO NOT flex AT ALL, with Ford's stupid A shackle setup on the front of the spring. Trust me, been there, done that.
The F350 springs are arched slightly higher, and are softer since the TTB requires a heaver spring rate to work. Youll only get about an inch of lift, but due to the nature of the suspension, its going to ride rougher. If you want it to ride decently, youll need to order a shackle reversal kit from someone like Sky Manufacturing, among others.
reptillikus is offline   Reply With Quote
Old 06-13-2009, 11:01 AM   #17
Slimline
Thankyou for the quick reply, that is good to know about the trac bar. I planned on doing a shackle flip for the rear, but was unsure what to do for the front other then getting custom leafs. I will have to look at a few different vendors and find some prices :) I live in Ontario Canada though which unfortunately limits where I can buy sometimes.
That is dissapointing about the flex of the 250 but I think it will still work ok. My f150 is a standard cab short box with the TTB and it actually flexes decently. Going from that to this extended cab long box will be a rough go but it will make my towing easier along with being a little more versatile as a truck. I posted a large thread over on pirate4x4 about whether or not I should get the truck. I do not get to offroad with my truck as much as I would like to, and mostly just go with the atv's. The truck has a 3 inch body lift installed currently and is running 35"s. I do not think it would take much to get it sitting on 38"s but my ground clearance wont be near the same :(
Old 06-16-2009, 11:49 PM   #18
RRWannabe
Bronco Info: its not one.
Is this the same after an RSK is installed as then you would trash that A shackle right?
RRWannabe is offline   Reply With Quote
Old 06-17-2009, 08:26 AM   #19
reptillikus
ate lug
Yep, A-shackle is discarded, and a new shackle that comes with the kit, is installed into the stock rear hangar. They flex better, but there is room for improvement. Mine is my daily driver/tow rig, so i am still running both sway bars, which doesnt help much for suspension travel either.
Old 06-17-2009, 11:44 PM   #20
RRWannabe
Well I was thinking An RSK with detachable sway bars and some type of detachable track bar and remove the over load leaf from the rear pack with a shackle flip. I want enough Height to run 37's will 4.5" get me there? I was also pondering a set of Alcan spring for the front with those pivot bushing in them depending on the price. I want to keep it low but with greater ground clearance. A 1000#+ motor up front concerns me about off camber situations.
Edit What RSK kit is that on your truck? (Brand and Hieght)
  FSB Forums > Bronco Discussions > Solid Axle Swaps
You may not post replies
Forum Jump
