HELP! Removing intake manifold... - FSB Forums
Thread Tools Display Modes
Old 03-01-2008, 06:09 PM   #1
OU812?
I have a 1990 bronco with a 5.8L and im having trouble getting off the intake manifold. Im replacing the passenger side valvecover/ gasket and must get the intake manifold off to get at it. There is a star pattern screw down "in" the manifold that i cant get at. I know it's size is T40. I have the socket but it is too wide.A torx screwdriver would work but no autoparts stores within 20 miles have the right size. Anyone else had this problem or suggestions of how to get at the screw???? ANy ideas would be appreciated.
OU812? is offline   Reply With Quote
Old 03-01-2008, 06:18 PM   #2
KC200787
Kitteh Commandaar!
KC200787's Avatar
Bronco Info: 2006 F150 Lariet 4x4 ECSB - 5.4 Trition
if you got the torx bit w/ the socket attachment, pop out the torx and use a 1/4" socket (or whatever fits it nicly) to put the torx bit in. then go after it with a ratchet.know what I mean?
KC
My Supermotors PageMy vehicles:
DD - Truck: 2006 Ford F150 Lariet, Ext. Cab, 5.4, Auto, 82K
Truck: 1995 Ford F150, Ext. Cab, 5.0L, 5sp, 189k miles, 4x4, 31" Trailblazer Mud Terrains - currently broken
KC200787 is offline   Reply With Quote
Old 03-01-2008, 06:23 PM   #3
Jackson112784
Jackson112784's Avatar
Bronco Info: 90 bronco, rebuilt 302/aod, 4inch lift, 33's, 4.10 gears posi front and rear
they also make a t-handle screw driver with that T40 bit, thats what I use. It fits right down in there
Jackson112784 is offline   Reply With Quote
Old 03-01-2008, 08:51 PM   #4
j. r. Nice
Forward Some Money
j. r. Nice's Avatar
Bronco Info: '89 Bronco, 5.8, MAF, Summit shorties, Bassani SS, AOD, Tru-trac posi, Stocker
You dont have your location posted, but the specialized bit is also available from the Cornwell tool dude. Probably available from Snap-Off etc too.
j. r. Nice is offline   Reply With Quote
Old 03-01-2008, 08:58 PM   #5
rocknbronco
rocknbronco's Avatar
Bronco Info: 88 XLT
I second that Sears sells em if you break it just take it back no truck to track down....
My Rig
88 XLT 351 Winsor C6(AOD 1st and 2nd,2k Torker Converter,Stage 2 Shift Kit) Borg Warner 1356 K&N Air Filter 33x12.50 Goodyear Wrangler MT/R's Warn Premium Hub Uniden CB Hidden Hitch Valley Ball and some body damage.
rocknbronco is offline   Reply With Quote
Old 03-01-2008, 10:02 PM   #6
Sixlitre
Practicing Infidel
Sixlitre's Avatar
Bronco Info: 86 Eddie Bauer; EFI 5.0 liter, AOD, optimized ignition system, external tranny filter, urethane bush
If'n you needs it off like this weekend, try this
Sixlitre
My Superford site
http://www.superford.org/registry/vehicles/detail.php?id=4970&s=17328#content
Sixlitre is offline   Reply With Quote
Old 03-01-2008, 10:04 PM   #7
KC200787
Kitteh Commandaar!
KC200787's Avatar
Thats what I was trying to describe in my first post. Works pretty good, but it would be nice to have the right tool for the right job.
KC
Old 03-01-2008, 10:07 PM   #8
SigEpBlue
Satyr of the Midwest
SigEpBlue's Avatar
Location: Ida & Grand Rapids, Michigan, a.k.a The Unemployment Capital of America
Bronco Info: 1993 EB, 5.8L, BIO0 MAF, GT40Ps, Mustang cam, GT40 Intake, Custom Headers, Moates QuarterHorse
If it's the factory 5.8L manifold, THIS is the best tool:
Can you tell I hate the factory manifold setup?
SigEpBlue
Wheelin' across Michigan from Ida to Grand Rapids, baby!
Nemo nisi per amicitiam cognoscitur -- No one learns except by friendship.
Originally Posted by Adlai Stevenson
Isn't it conceivable to you that an intelligent person could harbor two opposing ideas in his mind?
SigEpBlue is offline   Reply With Quote
Old 05-27-2014, 08:30 PM   #9
arashishozen
Bronco Info: 1988 Eddie Bauer 302
Sarcasm? I'm contemplating using a hammer right now
arashishozen is offline   Reply With Quote
Old 05-27-2014, 09:14 PM   #10
jowens1126
Thread Killa
jowens1126's Avatar
I use a magnetic screwdriver extension and a 1/4" Torx Bit
jowens1126 is offline   Reply With Quote
Old 05-27-2014, 09:34 PM   #11
panabax
panabax's Avatar
Bronco Info: '96 Eddie Bauer 351, M112 Supercharge, C&T beams, Deaver J40s, 4.56 gears, disc brakes, hydroboost
I just had to deal with this. Harbor Freight has 1/4" drive torx bits which will fit in the space provided provided you use a 1/4" extension. It was only like $8 or so for a set of 5 or 6 bits including the T40 you need. I had a 3/8" drive bit and it was no go.
Baxter
Sent from AutoGuide.com App
My family came to this country from Texas!
panabax is offline   Reply With Quote
Old 05-28-2014, 01:39 AM   #12
BikerPepe`
(this space for rent)
BikerPepe`'s Avatar
Bronco Info: '90 Custom, 302 (275hp/340ftlbs.), AOD, 4.56's, 31's, TTB Aussie Locker
GHETTO STYLE!
BikerPepe` is offline   Reply With Quote
Old 05-28-2014, 05:32 AM   #13
Tiko433
Tiko433's Avatar
Bronco Info: 88 XLT 3in body lift , 33s
Thumbs up
I went with 1/4 drive set up but taped it to keep it together. Hey Bikerpepe you should sell those on EBay
Tiko433 is offline   Reply With Quote
Old 05-28-2014, 01:26 PM   #14
BikerPepe`
BikerPepe`'s Avatar
purely a one-off.
Old 05-28-2014, 01:53 PM   #15
FORDMAN147000
FORDMAN147000's Avatar
Bronco Info: 1989 FSB 31 IN TIRES 351W C6
I was able to take the socket and use a magnet put it in through the front of the intake then take a 6in ext and connect them togeather under the manafold, once i figured it out it was simple
FIGHT CRIME, SHOOT BACK
FORDMAN147000 is offline   Reply With Quote
Old 05-28-2014, 03:38 PM   #16
VaMark
VaMark's Avatar
Bronco Info: '88 5.0L EFI, Stage 2 AOD, Yukon 4:88 grs (Locker (R), LSD (F)), 3" BL
GHETTO STYLE!
Nice! lol
I have one of those 3/8"-drive sockets with the T40 bit permanently set inside of it. I put it to my bench grinder and ground-down the socket until it was skinny enough to fit in the upper plenum's channel.
Mark (http://www.supermotors.net/registry/26113)
'88 5.0L EFI - Stage 2 AOD - Yukon 4:88 grs (locker in rear, LSD in front) - 33" tires on Procomp rims - 3" Body Lift
VaMark is offline   Reply With Quote
You may not post replies
Forum Jump
