what i was refering to is the rear spring hangers are outboard of the frame correct. the front spring hangers are directly under the front of the frame so how can they be parallel? unless of course the frame is narrower where the rear spring hangers are bolted up compared to the front frame horns.
You can get them locally at Napa and Autozone. Poly bushings for leaf springs are nothing terribly special. Just make sure that you get ones the correct width and diameter for your springs.
Pulled the bolts out of the front as well as the pan hard bar and the sway bar. I wish I was talented enough to post pictures on here from an iPhone but I'm not haha. The truck got taken away for 250$ today.
I'm waiting for my dad to come back so I can go to auto zone and get some bushings. I just beat 2 of the bolts out but I rotated the sleeve in the other 2.
People made it seem harder than it actually was. I drilled a ton of holes around the center sleeve in the bushing, then pushed/smacked out the center price. Then I sawzalled the bushing in half and it came out by hand.
Something like that. I have tube for spacers between the frame rails too. Its not done being welded yet, and theres a ton of slag from the plasma cutter.
Gotta cut off the excess material.
TTB out.
EDIT: Also figured out my driveshaft situation. The D60 accepts a 1330 U joint on the yoke for some reason, but the drive shaft yoke takes a 1350. Weird. I'm not too sure about the rear end as I haven't messed with it yet. Figure that out later.
The rear hanger can't really move forward any more, so I'm gonna move the front back about a half an inch and cant it backward some to give me a better shackle angle.
Hey man. You could either move the front shackle backwards half an inch or so OR move the rear hanger forward an inch or so. Either way get that angle around 40-45 :rockon . On a side note. Did you just bend the sky manufacturing sides in a slight bit to get them to be the width of the bronco frame?? I am either going to go Sky or make my ow hanger not 100% sure yet!
The sides on the hanger were already bent in about an inch for the F350 frame. I boxed the frame. There's a few pictures a couple of
Posts ago.
The sky kits a bit expensive but it's worth it. I don't really trust me abilities to build something like that since if it comes apart it'll probably wreck the truck and/or then kill me haha
Hey I am wondering if yoy can take a measurment of the width of the sky hanger. Like between where it bolts to the frane. just wondering how much i would need to add to box the frame. thankd alot man
Ya. Thats what I plan to do as well. Box the frame and bolt everything on!
Related Threads
Bronco Forum - Full Size Ford Bronco Forum
3.9M posts
99.4K members
Since 2003
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
