hi,
a couple months ago i got a really good deal at a local shop for a d44 and to install it. i brought it in 2 weeks ago they stared 1 week ago and the sas was done 3 days ago. i dont really have any progress pictures but i have before and after pictures. just wondering what you guys think about it.
thanks
It keeps the axle centered under the bronco. If it's to short and not parallel with the drag link you will get bad bump steer. Meaning your bronco will drive like crap.
That and I don't care fore the radius arm brackets just welded to the frame like they are, they should have been bolted up the side of the frame. Maybe even some misalignment spacers at the bracket would be nice too. The bump steer from that short of a track bar is going to be nuts. They should be at the same angle and with in a few inches in length of your drag link.
I think you hold the record for the shortest track bar ever! :rofl:
I don't think asking them is going to do much for you. If they knew it would have been done right to begin with, that or they did not want to invest the time and effort.
I don't notice any bump steer but probably because I don't know what it should feel like.
And my speedometer bounces at certain speeds now, I can get exactly when a little later
It shouldn't really drive any different that your old set up. If it's not steering correctly than you may have a castor issue, plus that super short track bar.
but there are 2 abs sensors in the front and one in the back. the back one is also the speedometer sensor. since the new axle does not have the abs sensors and the abs light is not on. if he disabled the abs would that affect the speedometer?
thanks
If the ABS light is not on, either he pulled the dash light or disconnected the computer and ABS pump under the coolant reservoir. If it's disconnected, there are a couple wires that have to be connected for the speedo to work. Take a look.
I think he just needs to loose the shim they put in and reinstall the factory wedge.
That may also be why his spedo is jumping, since U-Joints aren't constant velocity.
Angelo, here is the problem with the track bar.
(Red is track bar, green is drag link)
Those two arcs should the same size and there centers should be parallel with each other for them to be in phase. As yours is your front axle is going to move left to right as your suspension cycles far more than your drag link, giving you bump steer.
I'm also concerned about just welding the radius arm brackets on.
That's right, that was actually a nice drawing Gack had because it shows that the arcs get more out of sync the more the suspension travels. So if your suspension isn't going to travel much (short, stiff coils, low travel shocks) you likely won't notice it as much.
I would have a brace welded between these two plates. Also, as mentioned, you might want to have some kind of 1/4" plate bolt to the side of the frame and to the one side. (Covering the weld)
he doesnt remember the brand, he swapped this axle in a f150 awhile ago, and then he upgraded it to a d60. the springs and axle are from that f150. all i know is that they are 4 in lift springs and before they were put on my truck they were red.
Looks like it flexes pretty good. If you measure the distance from the bump stop to the axle and then the distance from the trac bar in the center, which is more. If the bump is more, you could hit the bar if you hit a bump or curb at speed. What will hit the bar? It almost looks like the diff cover will.
If you shocks are bottoming out before hitting the bump stops, you should get spacers under the stops. They are really easy to make from 3" x 3" by 1/4" square tube.
That is as far as it will go, if you are going slow. If you hit a bump fast, it can go higher unless the shocks run out of travil. But the shocks really shouldn't be used as bump stops.
