| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
speedsensor on a E40d
Thread Tools | Display Modes |
#1 |
![]() Join Date: Dec 2009
iTrader: (0) Bronco Info: 1992 EB 5.0 1995 xlt 5.8l,1996 EB 5.0
The bronco I just bought has the wires torn on the elec 4wd shift motor,it also yanked out the speed synco wires ,has anyone ever relaced the speed sensor? if so can you tel lme how, I have a haynes but did not find any instructoins
| Sponsored Links | |
Advertisement |
#2 |
iTrader: (0) Bronco Info: '91 2wd Bronco "RoadQueen" 351w +ZF
Which year Bronco?
On my '91 the driven speedometer gear setup is part of it. And it wasn't on the E4OD, it was on the 1356E transfer case. It's now on a 2wd ZF. :) Alvin in AZ |
#3 |
![]() Join Date: May 2007
iTrader: (1) Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
Now clarify for me the Speed Sensor you inquire about in your 1992 Bronco:
You are not talking about the Vehicle Speed Sensor (VSS) that was installed in the Transfer Case Tail Housing which sends a usable AC Frequency Signal separately to the Cruise Control and PCM which controls both engine and E4OD functions in 1990/1991 Broncos? And you are not talking about a Vehicle Speed Sensor (VSS) that was combined with the ABS Sensor located on the rear differential which sends a usable AC Frequency Signal through the ABS Module to the PSOM, for speedometer/odometer functions, and is then sent to the Cruise Control and PCM in 1992 and later Broncos? Are you asking about a Synchronization Unit for "Shift on the Fly"? Truly I would not know about these things because I'm still trying to figure out what the "clicky" foot switch on my floor is for... ![]() |
#5 |
Thanks for all the great info
This is in My 95 its on the transfer case and its wired from the elec shift motor. Miesk5, I think the stuff you posted will get me through thanks,,Bo
#6 |
I used to know this stuff
![]() Join Date: Oct 2003
Location: USE FORD PARTS, let da ZONE handle ice scrapers
iTrader: (1) Bronco Info: 96 XL 5.0 E4OD, Man Xfer/Hubs
yw.. GL! btw, if you can, please take a pic or 3 of the sensor and post it here for others to see; not much info on this at all.
#7 |
x2 :)
Cool stuff you posted there Miesk5. :) Just pulled that whole works out of my '91 since I'm going ZF+2wd. What sort of pictures are needed? ...pictures of ~'95 stuff? ...where the connections are? A '91 module and its wiring harness laying on the ground, help any? ;) Alvin in AZ |
#8 | |
Miesk5 I'll try to get some better pics of the speed sensor itself tonight if you want them as reference. The pdf you posted is the first thing I have seen that even explained what my broken wire is for lol. ![]()
http://www.supermotors.org/users/drinkbrew 96 bronco xlt 5.8, pro-comp stage II 6" lift, M/T classic lock wheels, 35" BFG all terrains, k&n stage II FIPK, FlowTech headers, electric fan, MSD coil with mods, ford racing 9mm wires, MSD cap and rotor, warn premium manual hubs and more to come .
#10 |
yo Drink!
Again, we have snow and Comcast is too slow for me to stay connected; so, I can't see how you can repair the wiring without removing the rear cover, etc... I was thinking at first of a by-pass solution is based on jumping out that wire feed for magnetic clutch, but that won't work Basing it on 1356 Electric Shift Wiring Diagram Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at ylobronc.users.superford.org & 1356 Electric Shift Parts Break Out Diagram w/nomenclature Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net Maybe yoomooman can jump in and give you some hints since he rebuilt his ESOF |
#11 | |
If you have time; take pics of the speed sensor, its Connector with pin views; etc. also if you can, have time to remove the cover and get to the magnetic clutch so db can open his up and do da repair to the wiring? thanks! it will def help others too in da future ![]() |
#12 | |
on the 1356E so I can sell it. I'll be sure take and/or scan some pics in the process. :) Need a scan of the speed sensor right away tho? Wiring diagrams kick butt for connector wire positions and for the wire colors too. Found a few mistakes so far but nothing important really. :) Alvin in AZ |
#13 |
Alvin,
Take your time on the Speed Sensor pics... The mag clutch access is what drinkbrew needs tho TY! |
#14 |
FSB's airline pilot
![]() Join Date: Aug 2003
Location: hotels, Charlotte, Roanoke VA, the cockpit...time split equally between all of them.
iTrader: (6) Bronco Info: 1989 460 EFI/C6/BW1356 electric/6 inch Rough Country lift/York OBA/Warn hubs/electric fans/14 bolt
My truck will not shift into 4 LOW right now. It shifts into 4 HIGH just fine, but the light blinks when LOW is depressed. The neutral ground signal is actually 30 ohms, but even when a known good ground is applied to the red/white wires pin, it still does not shift into LOW.
The speed sensor measures 6000 ohms, way outside the 225-275 range it should be. I will replace it, and see if it fixes it.
-Will 064 tlx 98 http://www.supermotors.org/registry/...ail.php?id=819 ![]() The best electric fan writeup out there http://fullsizebronco.com/forum/showthread.php?t=40564 |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
