vote for FSB JBG vote for FSB performanceoiltechnology.com
Go Back   FSB Forums > Bronco Discussions > Technical Write Ups
Old 11-17-2009, 05:32 PM   #61
hav24wheel
has more time than $
hav24wheel's Avatar
Bronco Info: 351M/C6/203/205, 44 Rockers,locked D60 front welded 10.25 rear 5.38 gears
Glad u figured it out. Mine is a slow mover too, but hasn't been but 125* tops. I've only drivin to and from work (25 miles, 15 miles of it on the hwy at 70 mph). I do plan on pulling a 7000 pound load with it this weekend though (about 50 miles one way) so I'll see how hot it gets then. I'll let u know how it does. (mine is a F-150, not a bronco)
94 F150, 5.0, E4OD, stock for now.
my supermotors page http://www.supermotors.net/users/hav24wheel
hav24wheel is offline   Reply With Quote
Old 11-17-2009, 10:13 PM   #62
Shadofax
Pick Pick Pick
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" Iroks, 4.56etc.
Sounds good. Make sure you provide detail on the truck as well. I do plan to "set the stage" with what all my truck has for cooling for comparison with readings others like yourself provide. And for some reason I was thinking you are in Cali., but I see you're in ND, so now I understand why you aren't exactly seeing temps much off the bottom either. Wait till winter, your gauge is going to start working counterclockwise.
______________________
http://www.supermotors.net/registry/628
"TheJuice...yes, that was my name. I come back to you now at the turn of the second decade...my name is Shadofax"
Shadofax is offline   Reply With Quote
Old 11-17-2009, 10:42 PM   #63
hav24wheel
hav24wheel's Avatar
Yep up here in ND. Gets kinda cold from time to time. Lol. This weekend will be the first time I've ever pulled a trailer with this rig, as I've only had it a month or so. I did install a Transgo shift kit in my trans though, so that might be helping in keeping it cool, I'll find out forsure on sunday. I'll put up the specs on the cooling system then too.
Old 11-18-2009, 06:19 PM   #64
Shadofax
Pick Pick Pick
Shadofax's Avatar
Log so far:
11/17/09 sunny 50*, roads clear, local trip to store, 4mi. each way, 120* max.
11/18/09 sunny 54*, roads clear, local trips, 2 very short stops, 26mi. total, just over an hour, just a hair under 150* after the second stop is when it finally built to this temp and stayed there. So the tranny is slow to warm when outside temps are cooler.
I'm beginning to think outside air will keep it at 150* or less during winter, unless going through snow or going into mountains. just won't build heat. I'd also guess that a summer 90* day would see the same driving produce around 185* temp (this is where the front cooler has to start earning it's money since the outside air is much warmer and not helping nearly as much with cooling.
Old 11-18-2009, 06:22 PM   #65
liltimmy08
Loves his auto hubs
liltimmy08's Avatar
Bronco Info: 1996 XL 302, Rebuilt E40D, Transgo shift kit, 32" BFG's
Originally Posted by Shadofax View Post
I'll go get ya a pic of what the gauge looks like installed, but it basically is just like Dave's.
Edit:
Looks good, same place I have mine in the bronco.
"If money grew on trees, The branches on mine wouldn't have no leaves"
liltimmy08 is online now   Reply With Quote
Old 11-18-2009, 09:05 PM   #66
BigBlue89Bronco
BigBlue89Bronco's Avatar
Bronco Info: '89 351W-C6-BW1356-rebuilt w/igt. bump 33"Pro Comp M/T -4" Lift Coming
Please excuse me in advance for possibly a retarded question, and thread-jack.
Will this write up be the same for a C6?
BigBlue89Bronco is online now   Reply With Quote
Old 11-18-2009, 10:10 PM   #67
Shadofax
Pick Pick Pick
Shadofax's Avatar
The discussion on the temp gauge and wiring would certainly apply. but, I don't know if the C6 would have the drivers side test port for the sensor, you'd have to go peek for yourself. The E4OD is "based" off a C6, just with OD and electronics, so I dunno???
Old 11-18-2009, 10:25 PM   #68
hav24wheel
hav24wheel's Avatar
I have one on my C6 in my off road rig, I used that line tap that comes with a !&. Guage. I'll go look whitch line I have it in in a coupole min.
Old 11-18-2009, 10:35 PM   #69
hav24wheel
hav24wheel's Avatar
On my C6, I have it hooked up to the rear trans cooler line. I really don't remember why I chose that one, but it works good. O and sorry bout the typos in my last post, I'm on my Blackberry, and it wasn't lettin me see what I was typing. It should have said B&M guage kit, not !&. Guage kit. Lol.
