| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
best year FSB 80-96?
Thread Tools | Display Modes |
#1 |
What are the better years for the FSB? Are any of them solid axle from the factory? I am in the market to buy an FSB 1980-96 and was wondering what my best option would be. I want 6" of lift and a strong v8.
86 Bronco II 4x4 w/4" Skyjacker suspension lift Looking to buy a late model FSB with 6" lift. I am located in Northern CA, near Chico. |
| Sponsored Links | |
Advertisement |
#2 |
![]() Join Date: May 2007
iTrader: (0) Bronco Info: 1990 EB FSB, 6.7L, MAF, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
I do not think of it as the best years of Broncos, but as best owners of Broncos. Clearly any Bronco can be very nice and have a lot of life left in it from an owner who took good care of it and appreciated it's existance.
And then there are the other ones... ![]()
1990 EB Bronco, 408 Stroker, MAF, Comp Cam, Edelbrock, Bassani, lots more...
#4 |
Chronic Broncitis
![]() Join Date: Oct 2006
iTrader: (6) Bronco Info: 90 xlt, 351w, e4od, stock 3.55 axles, sag, warn premiums, trans cooler, 33" bfg m/t, carbonated
It depends on how you plan to use it.
![]() The body style breaks are 78-79, 80-86, 87-91, & 92-96. If you look thru the Post a Picture of your Bronco you can see the different styles. As they get newer, wheel openings seem to get smaller. 1980 had an odd frame with holes in it. In 81 they went back to the solid frame. I think in 92 they went to the accordion style frame horns, so it can be trickier to add recovery points. 87 & some 88s with manual hubs had the top hat hubs that are expensive to replace, & require a lot of parts to swap to the more common hubs. Auto hubs are prone to fail, but they are easy to convert. The manual transfer cases seem to shift more reliably than the electric ones. I think Broncos with 302s had EFI before the 351s. As you move to newer trucks, the electronic systems become more advanced. I think 96 (Maybe 95?) is MAF (Which is more adaptable to intake/cam changes) & OBDII. 87-92 had rear antilock brakes, 93-96 have 4 wheel ABS. As mentioned above, 78-79 are the only years that came stock with front solid axles, which the rock crawlers like. The high speed desert guys seem to prefer the TTB front axle which is stock from 80-96. All full size Broncos had the removable tops, but the newer ones (92+?) have rear seat shoulder belt mounting points & 3rd brake lights, so they aren't supposed to be removed. The later years come with an E4OD 4 speed overdrive tranny. It's a heavy duty trans, but doesn't like heat & is expensive to rebuild. It's a good idea to add an external filter & cooler if you get one (Like this: Trans Filter, Cooler & THERMOSTAT install by Fireguy50 or this VOTE For Sept.'07 FOTM by Sixlitre -Post 173 Trans filter.) They did do some upgrades to the newest E4ODs, & when the older ones are rebuilt, they should include those upgrades. If you are using it primarily offroad, you might prefer an older truck with a C-6 (Non overdrive) trans. There were other trannies used as well & adrianspeeder's Bronco Tranny and T-Case Info thread has a bunch of trans/engine/year combo info. As for being lifted, you'd rather have extended radius arms than radius arm drop brackets. Blocks are definitely bad in the front, & aren't the best solution for the rear either. Take a look thru the lift section of Baba Looey's Favorite FSB Links for several links on the subject. For my use, if I was buying one today, I'd probably be looking at an 89 351w or a 78-79. The 89 is very similar to my 90, (Which I like a lot & have grown familiar with) but the 89 has a C-6 behind the 351. I don't drive mine much on the freeway, so I don't think I'd miss the OD. 78-79s are just cool, simpler (If you learned on carbureted engines anyway ), have larger wheel openings, & have solid axles. |
#5 |
Pushin tools for $$$
![]() Join Date: Dec 2008
iTrader: (0) Bronco Info: 85 FS Bronco 351w,C6,Atlas 4, D60 35 spline outers Ried knuckles , 14 bolt,5.38, Detroits,42"TSL
1985 was the best year because it was the last year you could get a carburated model, the wiring was still fairly simple to troubleshoot and fix, and mine came with a 9 inch from the factory. This is also the best looking body style since 78-79.
If I can just get it out of here I can fix it. |
#6 |
![]() Join Date: Jul 2006
iTrader: (0) Bronco Info: 86 Bronco 351/5.8L 385hp Ford Racing Crate Motor, 32" BFG AT's, and some other stuff.
Wrong. 1985 is the last year for a carbed 302. the 351 still came with a carb in 1986 and that is also the last year for the factory to use up the remaining 9" rears as well before going to the 8.8".
1986 Bronco Eddie Bauer 5.8L 4x4 1997 Chevy S10 Supercharged 4.3L http://www.supermotors.net/19921 |
#7 |
Wow, thanks for all the great info. Nice that people took the time to post. Love the 78-79 and the bronco II (I have two 1986 Bronco II) but I think I will keep an eye out for a bronco that someone did an SAS.... or take it on myself if I find the right deal. I like the 87-91 models
#8 |
iTrader: (7) Bronco Info: '89, 351, c-6, leaf sas in progress kp d60, 14bolt w/ disc brakes, lincoln locker, sky shackle flip
'89 is the best because that's what I have.
According to one moderator's interpretation of fsb.com rules, I am not allowed to state that I am worried about the future of my race in my sig. |
#9 |
iTrader: (0) Bronco Info: 1989 Bronco 5.0L 5 speed
I have owned a 1978,1980, 1985, and a 1989 model and they are all tough as nails it really just depends on what body style you like. I like the 78-79 full size and the 80-84 front ends better than any but its a matter of opinion. The great thing about fords in general is you can swap all different drivetrains/axles and have lots of options on transfer cases but its hard to beat a 302/NP205/9"rear on any model. But I can say I would love to have owned an early 60's/70's bronco but they are hard to find cheap...good luck
#10 |
![]() Join Date: Apr 2007
iTrader: (0) Bronco Info: 78 XLT, 429 Thunderjet, C6, shackle flip in rear, 4" springs in front,
I prefer my 78, but I might be biased. Solid front axle, minimal electronic crap, 9" rear axle. Best of all, it came factory with no cat convertors.
#12 | |
Nothing is alright
![]() Join Date: May 2005
iTrader: (2) Bronco Info: 96 XLT 302/E4OD & 90 EB 302/AOD
I like the 85-86 efi 302 eddie bauer broncos. Pretty cool to have the classic looking 80-86 style.
#14 |
YANK MY
![]() Join Date: Nov 2006
iTrader: (0) Bronco Info: 89 Bronco EB 5.0L AOD, 33" Mud Country's, 2" budget lift,Ford 9" w/Aussie locker
When I was looking I wanted an 87.5- 89 with a 351 efi and a C6 transmission.I never found it and settled for 302/aod which I paid $900.00 and daily drove for a year before I made it my trail rig.
My reason's were (even though I didn't find one) . 1. Can't beat the 351efi/C6 combo 2. 9'' swaps right in ( you lose rabs) 3. I already owned an 89 f150 and had lots of parts
![]() Getting the Bronco ready to hit the trails now and hopefully I learned my lesson, LOL.
#15 | |
Have a nice day meow.
Really you need to ask yourself, EFI vs Carb, and Factory Straight axle or IFS (with possible SAS). The rest is really easy to change up. from 80-96 you can swap out the front clips to make them look like whichever bodystyle you like, the only problem is with the 80-86 with the rear quarters being different.
#16 |
The best year by far is the 1992.
It was the first year of the last body style. Fuel Injected and still had the big 351. Auto locking hubs, nicer interior.. Oh.. I also own one. |
#17 | |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
