| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
460 swap with tall valve covers.. How to do A/C and Heater?
Thread Tools | Display Modes |
#1 |
Ive got Squatty D's old 78 Bronco and Im starting to get it ready for the road. The truck came with a 460 and has the tall valve covers to clear the roller rockers. I have a complete A/C unit from a 1978 Bronco but there is no way its going to clear the valve covers. Is there any smaller A/C and heater units people are using for this?
| Sponsored Links | |
Advertisement |
#2 |
iTrader: (2) Bronco Info: '78 Bronco, EFI 460, rollcage, 60fr/ 14rr, welded both ends, OBA, winch, yata yata....
Delete the a/c & get the standard heating system from a non-a/c truck. Try to cut out the whole area of the firewall where the blower motor bolts to from the donor truck. Saves having to fabricate a panel. Do a search, I'm sure there are plenty of write-up's on it. I did it, was pretty easy if you get all the parts. Here's a pick of the firewall cut from the donor (white);
If it ain't broke, keep trying to fix it!!!! |
#3 |
iTrader: (5) Bronco Info: 78 Bronco-408ci, 6" Superflex lift, 4.56s, Detroit lockers, C6 wide ratio slushbox, twinsticked 205
From the way I read it, I think he wants to install an A/C system. Depending on how tall the valve covers are, you might be able to clear them with a small body lift when you install your factory A/C. Otherwise, if you can locate a complete dealer installed A/C system, that would work too. Also check out http://www.vintageair.com/
Light travels faster than sound. That is why some people appear bright until you hear them speak. |
#5 |
iTrader: (0) Bronco Info: 78 Bronco, 76 F250 Highboy
Its easy to cover over Bob, I pulled out my fan motor and ran my air intake inside the cab through the hole with a tube and a filter inside
#7 |
Don't Fence Me In.
Yeah, its a big ol hole. Brother cut a piece of diamond plate to cover it up.
#8 |
Yep, its a big ass hole. If you can find it, the dealer installed economy a/c box fits under the dash. There is also a deluxe dealer installed box that took up a larger space under the dash and you had to relocate the glovebox.
You could also go with one of the hot rod a/c companies like classic air or vintage air.....they have nice kits, pricey though. Do you really need a/c in Michigan? |
#9 |
iTrader: (0) Bronco Info: Well it's not a Bronco but it is a 1979 F150
I would try to fit as small a valve cover as possible. maybe try double stacking gaskets with stock valve covers. You probably sell the tall ones and get some stock ones cheap and pocket a few bucks in the process. Just my .02
1979 Ford F150 4x4 400M T18 NP205 1971 Chevy K5 4x4 350 SM465 NP205 |
#10 |
Thanks for the info guys. I grabbed a complete under dash setup from a 1971 F100 I will try first. It would be nice to come across one of those dealer installed setups that Justin mentioned.
#11 |
If possible you might just be able to hacke the valve cover and have it welded up. Just make sure there's still enough clearance for the rockers. I have tall Motorsport valve covers and I'm pretty sure that the roller rockers and studs don't need all of the room that the covers provide. Just a thought...
Steve Johansen Island Rock Crawlers Member 4X4 Assoc of BC Member |
#12 |
![]() Join Date: Apr 2007
iTrader: (0) Bronco Info: 78 XLT, 429 Thunderjet, C6, shackle flip in rear, 4" springs in front,
Seems to me like when I had my a/c box out, there was a lot of dead space in there. Maaybe you can cut the bottom down flat, to clear the valve covers.
#14 |
its an off road rig ....who cares ??? no I don't know about that yet, I haven't finished it ?? I was setting it up for the mud bogs but now I'm putting that project even farther back on the to-do list and starting a new one ?? I have an aluminum tubbed jeep body on a shortened chevy frame coming tomorrow, I am putting a 460 in it with 8 lug axles and 44's under it, I figure it will be a ton lighter then I could ever make the bronco, and I'll go in another direction with the 78, its a never ending battle on which way to go with her ????
![]() Hows your Big Blue Monster Doing, hey my new toy is almost the same color ![]() ![]() |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
